eLightbars Home
Make a contribution
1998 Ford F-150 Install help.
Post new topic   Reply to topic    eLightbars.org Forum -> Non-lighting warning equipment
Author Message
crash-o-matic
PostPosted: Tue 19-Aug-2008 17:14    Post subject: 1998 Ford F-150 Install help. Reply with quote
Does anyone know if there is an exixting hole in the firewall to run power cable thru? Really dont wanna drill if I dont have to....
Thanks all!
Back to top    URL
Harrison
Regular
Regular
PostPosted: Wed 20-Aug-2008 08:41    Post subject: Reply with quote
in my 2000 model, there's a grommet above the brake pedal, its about 2" in diameter, and it doesn't have any wires running through it. In the engine compartment, it is locates to the left side of the Brake Booster
Back to top    URL
lean mac
Regular
Regular
PostPosted: Wed 20-Aug-2008 11:51    Post subject: Reply with quote
I have a 99 and like Harrison stated, there is about a 2" grommet above your pedals, exactly where he said.
Back to top    URL
engine69
PostPosted: Wed 20-Aug-2008 12:32    Post subject: Reply with quote
theres a grommet where they stated...and thats where i have run all of my wires but there is another grommet right under the drivers seat..you have to take the seat out and cut the carpet to get to it
the only problem i have had with the engine compartment grommet is the tubing around the wires has started to warp from the heat of the engine.
Back to top    URL
lean mac
Regular
Regular
PostPosted: Wed 20-Aug-2008 14:43    Post subject: Re: Reply with quote
Isnt that the intended purpose of the tubing? To protect the wires from effects of heat... Laughing Wink
Back to top    URL
will_545
Regular
Regular
PostPosted: Wed 20-Aug-2008 19:51    Post subject: Reply with quote
I ran some of mine in the fender found a rubber grommet on the passanger side kick panel. Also since every thing is mounted on the back wall of the cab I used one of the drain pluges in the floor.
Back to top    URL
crash-o-matic
PostPosted: Thu 21-Aug-2008 04:12    Post subject: Reply with quote
Yes, I found the grommet in the firewall where the first poster said it was. Dont know how I missed it! Thanks guys!
Back to top    URL
engine69
PostPosted: Thu 21-Aug-2008 14:55    Post subject: Re: Reply with quote
yeah but now whenever i look at it i think it looks like crap...and i have no motivation to go change it out cause it runs from the battery across and then down to the grommet
Back to top    URL
Display posts from previous:
Post new topic   Reply to topic    eLightbars.org Forum -> Non-lighting warning equipment All times are GMT - 6 Hours
Page 1 of 1
