| Author |
Message |
dynastar666 Turbo Poster
Joined: 24 Mar 2007 Posts: 2193 Location: Ithaca, NY and Burlington, VT
Posted: Mon 11-Aug-2008 14:46 Post subject: Grover Stuttertone problem. |
| We have a set pair Grovers on our tanker that no longer work. For a while they were putting out a pathetic squeal and recently they all together stopped making any noise. I was told it is possibly the diaphragm but after looking them over today and problem shooting we realized you can hear the solenoid clicking but no air is coming out. I would assume if it's just the diaphragm you would be able to hear/feel air moving through the horns. Anybody have any experience with these? I know very little about them. |
| Back to top URL |
R. Dodd 10-75 E.L. Professional Upfitter
Joined: 16 Sep 2006 Posts: 1922 Location: Oakland, NJ
Posted: Mon 11-Aug-2008 14:55 Post subject: |
| the horn is two pieces the front trumpet and the back part. Seperated by the rear mount piece. Loose the two parts and unscrew the back part then tighten the front trumpet part and then test. do this little by little. I just did this on my engine because it sounded like a dying goose |
| Back to top URL |
Rofocowboy84 Turbo Poster
Joined: 12 Jul 2007 Posts: 2684 Location: Montgomery County, PENNSYLVANIA!!!
Posted: Mon 11-Aug-2008 21:07 Post subject: |
Better yet, admit to the fact that they're dead, buy a new pair, and send the old ones to me, I'll even pay for shipping!  |
| Back to top URL |
Posted: Mon 11-Aug-2008 21:10 Post subject: Re: |
| Rofocowboy84 wrote: |
I already tried convincing my Chief to do that but to give them to me! He refuses to get them fixed anywhere because he thinks they'll get broken again. We think that the problem started after people were turning the trumpets, could this be? R. Dodd, I'm going to try what you suggested tomorrow morning and I'll update this post with the results. |
| Back to top URL |
Posted: Mon 11-Aug-2008 21:30 Post subject: |
| if people played with them then thats the case because i did that when i way trying to figure out which way they were messed up |
| Back to top URL |
firecar96 Regular
Joined: 07 Jul 2008 Posts: 54 Location: Muskegon Co, MI
Posted: Mon 11-Aug-2008 21:51 Post subject: Re: Grover Stuttertone problem. |
| dynastar666 wrote: |
I worked on a truck last week that was doing the same thing. Does the horn system have a fill tank and compressor or does it run of the air brakes? Let me know, I may be able to help. |
| Back to top URL |
Posted: Mon 11-Aug-2008 21:56 Post subject: Re: Grover Stuttertone problem. |
| firecar96 wrote: |
I am 99% sure it runs off of the air brakes because we could not find a separate compressor. |
| Back to top URL |
firecar96 Regular
Posted: Mon 11-Aug-2008 22:22 Post subject: |
| The lines that run to the horns , are plastic or metal? |
| Back to top URL |
wildwelder87 Regular
Posted: Mon 11-Aug-2008 22:30 Post subject: |
First thing to check would be the supply line going to the solenoid, then check if the solenoid is actually working. All our trucks here use a manual pull valve, we're old school! And you can adjust the tone of the horn(s) higher or lower by screwing the bell/trumpet of the horn in for a higher tone, or out for a lower tone. |
| Back to top URL |
Posted: Mon 11-Aug-2008 22:52 Post subject: |
| The lines are plastic/rubber, the solenoid seems to be working. If the line is taken from the air brakes does it just tap into the compressor and tank for them? |
| Back to top URL |
firecar96 Regular
Posted: Tue 12-Aug-2008 03:17 Post subject: |
It sounds to me like you have a hole in one of the lines. The reason you are not hearing any leaking air is because the tank fills from the brakes which only fill when the engine is running. "I'm assuming. I don't know a ton about air brakes."
What you need to do is remove the air line that connects from the air brake junction box to the air tank and use a compressor to push air through it and listen for leaks, then if none are found, do the same with the line that runs from the air tank to the horn it self.
If you do locate a hole in the line, look around to see if there is somthing close to the line that produces a pretty good amount of heat.
The truck I worked on last week, had a similar problem. You could hear the solenoid click but no air. After a little bit of trouble shooting I found a large hole in the line between the compressor and air tank, right against one of the connections. The compressor was producing more heat than normal which was being transferred across the plastic air line, which eventually became weak and gave way. Being that the department didnt want to replace the compressor, I came up with the solution of installing a steal brake line in place of the plastic one, so it would act like a heat sink and transfer the heat instead of absorbing it. The compressor, steel line and air tank all act as a large heat sink now. I also took apart the compressor and cleaned the air intake which was plugged up with stuff. I figured that was what was producing the heat that weakened the air line but replaced the air line with a steel one just incase. |
| Back to top URL |
firecar96 Regular
Posted: Thu 14-Aug-2008 14:54 Post subject: |
| So have you had any luck with the air horns? |
| Back to top URL |
Posted: Thu 14-Aug-2008 21:07 Post subject: |
| I just thought of something. If the horns do run off the truck's air brake system, and there was a leak, the parking brakes would automatically lock up due to low/no pressure in the system. If the truck's pressure gauge shows it holding then there's not an air leak, they most likely have their own air system or the solenoid could be bad. |
| Back to top URL |
911tech Regular
Posted: Fri 15-Aug-2008 00:46 Post subject: |
| Quote: |
If your horns are run off the trucks air brake system chances are that the protection valve has gone out. This is the valve that cuts the air supply to the horns if the pressure in the tank drops below the safe operational psi, or if the horns develop a leak. This is basically just a pressure acctuated check valve in the air line to the horns (same as a tractor protection valve on an 18 wheeler). It should be mounted close to the tank, if not on the connection at the tank itself. If this has gone out your solenoid will click but there is no air supply, or a very small amount if the protection valve is going but not totally gone. I would remove the air line at the solenoid and try to give it a small air burst from a compressor, if the horn sounds 10 to 1 its the protection valve. If this is the case check the lines that run from the tank to the solenoid for leaks to make sure the valve is't just closing to protect the service brakes, and if there is no leaks put in a new protection valve and you should be ready to roll.  |
| Back to top URL |
Posted: Fri 15-Aug-2008 08:30 Post subject: |
| I'm going to work on them today and I'll let you know, it's been a busy week and this is the first free day I've had. |
| Back to top URL |
Robert W. Regular
Joined: 27 May 2008 Posts: 713 Location: Hartford, CT
Posted: Fri 15-Aug-2008 09:22 Post subject: |
The stutter tones have not been our best friends lately.
On one of the apparatus, with electronic solenoids, they solenoid would click, but it would get stuck closed, so you had to give it a squirt of WD-40 and step on the air horn pedal a couple of times and then it would work. Sometimes people would leave the station and continously step on the pedal until it started working about 1/4 mile down the road.
The other issue we had was with manually activated ones, you would pull the cord, get a small huff of air, but for the most part nothing. You could hold the chain, and you would just hear air moving, and for holding the chain for 10 seconds, you would get a split second of a semi audible horn sound. The problem we came up with for that was the diaphragm, which had become worn, and they only worked if someone had their hand on them and was twisting them.
Our newest apparatus has Hadley's new "emergency horn". They have stutter tones, but this new model produces a "unique noise". It his hard to describe but it is like a really really high pitched stutter tone and I am concerned it will make drivers crap their pants more than anything else. But so far no problems, and they are only about 10" long, so much shorter than the grovers
Hope those situations help. |
| Back to top URL |
T Niss Regular
Joined: 26 Sep 2007 Posts: 83 Location: Londonderry Fire / Middletown, Dauphin County PA
Posted: Mon 18-Aug-2008 20:50 Post subject: |
| We just had those "new" Hadley''s removed and went back to the Grover Stuttertones because that is what a Fire engine should have (along with a "Q" and power call)!!!!!! |
| Back to top URL |
Dennis S Member
Joined: 16 Jun 2008 Posts: 41 Location: Los Angeles, CA
Posted: Mon 18-Aug-2008 21:28 Post subject: There is only one Stuttertone Horn |
| Glad to see that Hadley was tossed. They have always seemed like crappy air horns, cheaply made and sounding no better than a poor truck horn. Wolo has a so called "stutter" horn also, and like almost all Wolo stuff looks cheap, it is made in China, and it is almost as expensive as a real Grover. If you want a stuttertone horn, buy Grover, do not over tighten the bell, or you can damage the diaphragm, and forget the junk. I still believe, that the best air horn, for being both loud and very aggressive, is the Martin Horn 2297, but it costs about what a Q2 costs. |
| Back to top URL |
bisho1p Regular
Joined: 20 Aug 2005 Posts: 960 Location: Richmond, VA and Morgantown, WV
Posted: Fri 22-Aug-2008 03:34 Post subject: |
How do you "tune" the grover to get that stuttertone sound. My grover only sounds like the stuttertone if you give a real quick blast, but if you lay on it, it sounds more like a trombone...  |
| Back to top URL |
CanonNinja Regular
Posted: Fri 22-Aug-2008 09:15 Post subject: Re: |
| bisho1p wrote: |
sounds like its not getting enough air. Mine is the same way, and I'm running 1/4" air line. I'm going to up it to 3/8 or 1/2" and the sound should maintain |
| Back to top URL |
Posted: Fri 22-Aug-2008 15:05 Post subject: |
| Try running 3/8" tubing from the tank to the pull valve/solenoid, then 1/4" from the valve to the horn. That's all you should need, I set mine up that way and it's really loud. It's a model 1024 Grover which is the same size as a Stuttertone(24.5") but it just makes a regular truck horn sound. |
| Back to top URL |
bisho1p Regular
Posted: Fri 22-Aug-2008 21:26 Post subject: Re: |
| bisho1p wrote: |
I cleaned the diaphragm and readjusted and it sounds MUCH louder. Definitely kept this jerk this morning from merging into the side of me....  |
| Back to top URL |
Posted: Fri 22-Aug-2008 21:31 Post subject: |
| After looking everything over and trying everyone's suggestions I think it is the protection valve, now all we need is a new one! |
| Back to top URL |
firechief24 Member
Posted: Wed 27-Aug-2008 15:55 Post subject: Re: |
| T Niss wrote: |
Amen Brother!!!!!!  |
| Back to top URL |
911tech Regular
Posted: Wed 27-Aug-2008 16:59 Post subject: |
Here is a few:
Sealco
Midland
Midland
Midland
Just match up the one you currently have on the truck, or the part numbers in the cross reference at the bottom of each page. You can also contact the closest Heavy Duty Truck Shop, and they should be able to get one for you. |
| Back to top URL |
