eLightbars Home
Make a contribution
Hide Away Strobe / LED Placement Photo Database
Goto page 1, 2  Next
Post new topic   Reply to topic    eLightbars.org Forum -> Installs and member rides
Author Message
AdvancedWarningLight
Contributing Member
PostPosted: Sat 12-Jan-2008 22:21    Post subject: Hide Away Strobe / LED Placement Photo Database Reply with quote
I thought it would be cool if we posted pics of tube placement to use as a reference.
08 Superduty
03-06 Silverado Tails in reverse lights
I will post more. Please add your pics
Back to top    URL
OTFD122
Frequent Poster
PostPosted: Sun 13-Jan-2008 07:36    Post subject: Reply with quote
Replcing an 07 Tahoe's DRL w/ a HAW:
07 Tahoe reverse lamp:
02 Impala front cornering light:
Back to top    URL
Field79
Regular
Regular
PostPosted: Sun 13-Jan-2008 08:25    Post subject: Reply with quote
97 Mustang Rear Tails
97 Mustang Front Corners
06 F-350 Front
Unknown Year Chevy Malibu
I got more, just need to dig up some of the pics.
Matt
Back to top    URL
Mike - NEE, LLC
Contributing Member
PostPosted: Sun 13-Jan-2008 10:39    Post subject: Reply with quote
2005 Dodge Durango taillight strobes
Back to top    URL
ka8ypy
Regular
Regular
PostPosted: Wed 6-Feb-2008 00:05    Post subject: Reply with quote
2004 F-150
Front head light:
From behind:
From the side:
Tail light: Brake light and back-up light (there is also one mounted in the lower "reflector" that has no light mounted in it.
Dan
Slick Top Solutions
Back to top    URL
FireEMSPolice
Frequent Poster
PostPosted: Mon 25-Feb-2008 21:25    Post subject: Reply with quote
I thought this should be in here
1998-Present
Ford Crown Victoria (Tail light)
Image courtesy: Hugh A.
Back to top    URL
cajunblitz
Professional Upfitter
PostPosted: Sat 8-Mar-2008 19:42    Post subject: Reply with quote
2007 Tahoe Replacing DRLs with Whelen Hide-A-Halo Crown Vic LEDs.
cajunblitz
Back to top    URL
Andy L.
Moderator
Moderator
PostPosted: Sat 8-Mar-2008 21:08    Post subject: Re: Reply with quote
cajunblitz
How did those end up working in that spot? Did you use the Running light / turn signal functions as well or just the warning?
Back to top    URL
cajunblitz
PostPosted: Sat 8-Mar-2008 23:29    Post subject: Reply with quote
Actually what I did was leave the trucks turn signals the way they are, and tied the warning outputs of the controller into the amber LEDs. I combined the outputs of each channel to fire like this:
When the right LED flashes blue, the left LED flashes the same pattern at the same time in AMBER, and vice-versa. Kinda like an X-pattern within the same heads. The customer loves it.
Kinda like a dual color warning HideAway LED before they were produced. I'd like to see Whelen go this route with the HideAway LEDs, like NOVA is doing, but it does present a heating issue. NOVA is releasing the new 2-3 color HideAway LEDS with ribbon heatsinks that can be shaped and formed to accomodate placement of the head.
cajunblitz
Back to top    URL
cajunblitz
PostPosted: Tue 8-Apr-2008 17:46    Post subject: Re: Reply with quote
Rescue290 wrote:
cajunblitz
VIDEOS PLEASE!!!
This is kinda crude, but here's a video I did while building this truck.
http://img531.imageshack.us/my.php?image=dscn2373tr2.flv
cajunblitz
Back to top    URL
Mike - NEE, LLC
Contributing Member
PostPosted: Tue 8-Apr-2008 18:14    Post subject: Reply with quote
Hey Cajunblitz:
How hard is it to remove the headlights from the 2007 Tahoe. I have two installs on a 2008 Tahoe and 2008 Suburban. Just looking for info on headlight and grille removal. Thanks.
Mike
Back to top    URL
cajunblitz
PostPosted: Tue 8-Apr-2008 19:34    Post subject: Re: Reply with quote
Mike - NEE, LLC wrote:
Hey Cajunblitz:
Mike
Mike,
Not hard, just a little time consuming. I don't recommend removing the headlights without taking the fascia off, because the bottom headlight brackets can scratch the fascia if you pull them out at the wrong angle.
There are some 7MM screws in the fenderwells, and some push-lock fasteners. remove those. There are 10MM screws that hold the bottom of the fascia corners to its metal supports under the truck. Remove those.
Remove the top 10MM bolts on the grill.
After you can access inside the fenderwell inserts, look where the fascia meets the fender inside, there are 2 10MM bolts with an alignment piece inset there. Use a long 1/4 ratchet extension and swivel and remove those bolts. If you'ge gotten everything, the fascis should slide forward and off the bumper.
You'll see the lower plastic bracket/bolt for the headlights on the bottm of them. Just loosen them, and remove the ones on to. The headlight should come away from the truck now.
I'm writing from memory, so hopefully if I left something out, someone will add to it.
cajunblitz
Back to top    URL
fyredawg
Regular
Regular
PostPosted: Tue 22-Apr-2008 06:23    Post subject: Re: Reply with quote
1998-Present
Thats in the incorrect location, should be just below the factory bulb
Back to top    URL
Lac Man
Contributing Platinum Member
PostPosted: Fri 25-Apr-2008 20:25    Post subject: Re: Reply with quote
1998-Present
Correct...
Not that bad of a location though, compared to some that I've had to re-do! Rolling Eyes
Back to top    URL
eastfire510
Contributing Member
PostPosted: Sun 6-Jul-2008 23:13    Post subject: Reply with quote
Is it possible that someone could post pictures of the correct CVPI strobe placement in the tail/reverse and corner lights? I am doing a project in about a week and would like to know what the heck im doing Very Happy
Back to top    URL
hawkspringsfire
Contributing Member
PostPosted: Sun 13-Jul-2008 22:05    Post subject: Reply with quote
2003 Ford Escape Fog Light Placement.
2003 Ford Escape Tail Light Placement
Back to top    URL
ff168577
Regular
Regular
PostPosted: Tue 15-Jul-2008 11:29    Post subject: Re: Reply with quote
1998-Present
Correct...
That is personal preferance I believe. I always believe that the futher away from the factor bulb exspecially the brake light the better so that way the bulb does not get drowned out.
Back to top    URL
hfd163
Regular
Regular
PostPosted: Sun 27-Jul-2008 21:28    Post subject: 07 impala Reply with quote
Anyone have pictures of installs on 07 or newer Chevy Impala HAW in headlight or Tail Lights?
Back to top    URL
Mike - NEE, LLC
Contributing Member
PostPosted: Sun 10-Aug-2008 17:04    Post subject: Reply with quote
2008 Chevy Suburban / Tahoe HAW in DRL housing.
Back to top    URL
R. Dodd 10-75 E.L.
PostPosted: Sun 10-Aug-2008 17:09    Post subject: Re: Reply with quote
id like to make sugestion to use plug-in so the tube is all the way in the headlight because there is a decent gap between the outer and inner layer
Back to top    URL
KFD236
Regular
Regular
PostPosted: Sun 10-Aug-2008 17:46    Post subject: Reply with quote
since you put those HAWs where the drls are what do you do with the drl lights? Do you cut them or take the bulb out and stuff them somewhere out of the way? Always wondered
Back to top    URL
Mike - NEE, LLC
Contributing Member
PostPosted: Sun 10-Aug-2008 17:46    Post subject: Re: Reply with quote
I thought about that, but I used the factory hole, which I believe is larger than 1 inch. I did throw a bead of silicone around the bulb too.
Back to top    URL
R. Dodd 10-75 E.L.
PostPosted: Sun 10-Aug-2008 17:57    Post subject: Re: Reply with quote
Take the bulb out and tap them up really well. Do not cut the plug off, the ground for the turn signals are tie in with the plugs
Back to top    URL
R. Dodd 10-75 E.L.
PostPosted: Sun 10-Aug-2008 18:00    Post subject: Reply with quote
cut a peice of plastic and cover the hole after placing the plug-in strobe in then silicone the plastic
Back to top    URL
Pimpala03
Moderator
Moderator
PostPosted: Fri 22-Aug-2008 18:01    Post subject: Reply with quote
2003 Chevy Impala. These were already done when I got the car, or else I would have put them closer to the reflector.
Back to top    URL
Display posts from previous:
Post new topic   Reply to topic    eLightbars.org Forum -> Installs and member rides All times are GMT - 6 Hours
Goto page 1, 2  Next
Page 1 of 2
