eLightbars Home
Make a contribution
Is it possible to switch out these two PA300s?
Post new topic   Reply to topic    eLightbars.org Forum -> Non-lighting warning equipment
Author Message
Hearno
New member
New member
PostPosted: Mon 4-Aug-2008 18:12    Post subject: Is it possible to switch out these two PA300s? Reply with quote
I have a newer PA300 in my vehicle but it has the Hi-Lo tone, I purchased an older PA300 with Priority tone online but the connectors are differrent. Is it possible to get the older one with Priority in with some harness or am I out of luck? See pics below... The difference is a 10 pinconnector and a 12 pin connector, maybe someone knows before I get the pics up..
Front and rear of new with Hi-Lo
Front and rear of old with Priority
Back to top    URL
Respondcode3
Regular
Regular
PostPosted: Mon 4-Aug-2008 18:47    Post subject: Reply with quote
You will have to change connectors.
Back to top    URL
dmitry103
Contributing Member
PostPosted: Mon 4-Aug-2008 19:58    Post subject: Reply with quote
You need new connector. It's a relatively easy task to rewire something like this:
Left to Right
Top Row: 12-two way radio speaker; 11-empty; 10-horn
Upper middle Row: 9-two way radio speaker; 8-empty; 7-horn ring
Lower middle Row: 6-POS (+); 5-Chassis Ground; 4-Neg (-)
Bottom Row: 3-Speaker 100 Watt; 2-Speaker 58 Watt; 1-Speaker Common
Back to top    URL
Hearno
New member
New member
PostPosted: Mon 4-Aug-2008 20:02    Post subject: Reply with quote
Thanks for the help so far. Does anyone know where I can get the new connector?
Back to top    URL
dmitry103
Contributing Member
PostPosted: Mon 4-Aug-2008 20:15    Post subject: Reply with quote
Of course.......................here :
1)http://cgi.ebay.com/FEDERAL-SIGNAL-SS2000-PA300-Power-Cable-Harness-NEW_W0QQitemZ300245917776QQihZ020QQcategoryZ53293QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
2)http://cgi.ebay.com/PA300-wire-harness-cable-wiring-12-pin-connector_W0QQitemZ320282651834QQihZ011QQcategoryZ67225QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
3)http://cgi.ebay.com/Federal-Signal-PA300-Siren-Plug-Connector-Harness-N-R_W0QQitemZ110276637854QQihZ001QQcategoryZ36347QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
hope this helps Wink
Back to top    URL
Pat H.
PostPosted: Mon 4-Aug-2008 20:17    Post subject: Re: Reply with quote
Instead of Ebay, just go to Radio Shack. Thats where I bought mine in the past.
Back to top    URL
dmitry103
Contributing Member
PostPosted: Mon 4-Aug-2008 20:21    Post subject: Re: Reply with quote
The ones in my area stock one/two of each connector, or sometimes not even have any.
But yeah "DO IT YOURSELF" is always the cheapest way !
Back to top    URL
Jasonc
Regular
Regular
PostPosted: Mon 4-Aug-2008 22:03    Post subject: Reply with quote
You could just do the phaser modification on your hi-lo PA300 and have both Hi-lo AND priority for about $5 Wink
Back to top    URL
ToneFreak
Regular
Regular
PostPosted: Mon 4-Aug-2008 22:23    Post subject: Re: Is it possible to switch out these two PA300s? Reply with quote
Hearno wrote:
First PA300 I've seen with a bat handle toggle switch.
Back to top    URL
Bonanno
Regular
Regular
PostPosted: Mon 4-Aug-2008 22:41    Post subject: Reply with quote
really that is the 1st one you've seen with that? The Crown vics my Town's PD uses has that switch and also one of my engine's has one with that switch.
Back to top    URL
hawkspringsfire
Contributing Member
PostPosted: Mon 4-Aug-2008 22:43    Post subject: Re: Is it possible to switch out these two PA300s? Reply with quote
I think all of the newer ones are made that way?
Back to top    URL
jc420
PostPosted: Mon 4-Aug-2008 23:36    Post subject: Reply with quote
I think the PA300 with priority tone is way better than the Hi Lo.
Good Choice to switch out.
Back to top    URL
SBfirefighter08
Regular
Regular
PostPosted: Tue 5-Aug-2008 15:52    Post subject: Re: Reply with quote
How is that done? We have a PA300 on one of our rescue trucks and I hate the Hi-Lo tone on it.
Dan
Back to top    URL
Respondcode3
Regular
Regular
PostPosted: Tue 5-Aug-2008 16:00    Post subject: Reply with quote
All the pa300's with the new connector have the metal toggle..
Back to top    URL
Hearno
New member
New member
PostPosted: Tue 5-Aug-2008 16:14    Post subject: Re: Reply with quote
Yeah, how bout you give up that info!!
Back to top    URL
Jasonc
Regular
Regular
PostPosted: Tue 5-Aug-2008 16:33    Post subject: Re: Reply with quote
Drill a hole in the faceplate and drop in a pushbutton (momentary recommended, push on - push off type will work as well). Solder the two wire leads of the pushbutton to either side of R24 on the mainboard. Now, when your siren is in yelp position, pressing the button will yield the Priority tone. Be careful soldering, as these newer PA300s use mini-sized components.
Much cheaper than buying a new PA300, plus you have both hi-lo and Priority.
Back to top    URL
Hearno
New member
New member
PostPosted: Tue 5-Aug-2008 17:44    Post subject: Reply with quote
http://www.radioshack.com/sm-buy-the-momentary-switch-on-http-wwwradioshackcom--pi-2062496.html
Will this switch work? So I just need two solder two wires from the end of that switch into the "R24" part and when I activate the switch it will make a priority tone?
Back to top    URL
Jasonc
Regular
Regular
PostPosted: Tue 5-Aug-2008 22:45    Post subject: Re: Reply with quote
10-4, that switch will work and your right about the soldering part. BTW, red pushbuttons look cooler Wink
Back to top    URL
TheHealer
Regular
Regular
PostPosted: Fri 8-Aug-2008 18:58    Post subject: Reply with quote
Someone correct me if I'm wrong, but you could just match up the correct wires, according to function, and remove the pins from the newer siren connector and replace them in the older harness, they are both using AMP pins. If you look in the connector you will see a little reatining tab that holds the pin in its connector. I usually use a small scratch awl to bend the tab in and the pin slides right out of the connector. Pry the tab back out to its original position and snap it back into the other connector and you're good to go without spending anything! Hope that helps!
-Pete
Back to top    URL
SCTRAFCOP
Regular
Regular
PostPosted: Tue 12-Aug-2008 19:13    Post subject: Reply with quote
What gauge of wire should one use for this secret-squirrel priority tone upgrade?
Back to top    URL
Jasonc
Regular
Regular
PostPosted: Tue 12-Aug-2008 21:37    Post subject: Re: Reply with quote
The smallest you can get (preferably already attracted to the pushbutton when purchased). This is in the tone generator circuit and carries no appreciable current or voltage.
Back to top    URL
SCTRAFCOP
Regular
Regular
PostPosted: Wed 13-Aug-2008 07:49    Post subject: Reply with quote
That is a good mod to know about. I wonder why there are so many variables with the same model of siren. I've got a PA300 with the old harness but with priority tone. I had to pull strings in order to snag it. Most of ours have hi-lo instead. Half of our cars have the new harness and half have the old.
Back to top    URL
Display posts from previous:
Post new topic   Reply to topic    eLightbars.org Forum -> Non-lighting warning equipment All times are GMT - 6 Hours
Page 1 of 1
