eLightbars Home
Make a contribution
Lightbar in garage set up/power supply
Post new topic   Reply to topic    eLightbars.org Forum -> Collectible lighting
Author Message
vista1
PostPosted: Tue 19-Aug-2008 19:14    Post subject: Lightbar in garage set up/power supply Reply with quote
Currently have a fed sig vista mounted in my garage, I have a switch box and signal master control box to operate the light.
I don't know how I should power it, will be used for fun in the garage.
Do I just use a battery or do I buy a power converter?
Want to be safe and do it the right way but not spend a lot.
Need advice!!!
Thanks!
Back to top    URL
NPS Ranger
Contributing Member
PostPosted: Tue 19-Aug-2008 19:28    Post subject: Reply with quote
If you use the search function you will find numerous threads on this same topic, i.e. using a regulated power supply, using a battery with a trickle charger, using a battery booster, etc etc.
Back to top    URL
Display posts from previous:
Post new topic   Reply to topic    eLightbars.org Forum -> Collectible lighting All times are GMT - 6 Hours
Page 1 of 1
