eLightbars Home
Make a contribution
Knob Replacement
Post new topic   Reply to topic    eLightbars.org Forum -> Non-lighting warning equipment
Author Message
Joe S.
Regular
Regular
PostPosted: Fri 14-Jul-2006 13:56    Post subject: Knob Replacement Reply with quote
How easily can the rotating knob on a siren that selects the tones be replaces with another one? The one on my old PA300 Silver Face is circular and kind of hard to turn. When it's hot outside and my hands are sweaty or even slightly moiste from anything (drink, etc. - no dirty jokes, please Razz) I can't grip it well enough to turn it on! I would like a knob something like this..
Back to top    URL
Joe S.
Regular
Regular
PostPosted: Thu 20-Jul-2006 23:57    Post subject: Reply with quote
Anyone have any experience with this??
Back to top    URL
ATVrescue24
Contributing Member
PostPosted: Fri 21-Jul-2006 09:41    Post subject: Reply with quote
You might wanna try Ebay.
Or post a wanted post for a Knob.
Pete
Back to top    URL
Mick (firewolf)
Contributing Member
PostPosted: Fri 21-Jul-2006 11:30    Post subject: Reply with quote
Try Priority One Emergency on here - they gpt me a replacement knob for my V-Con. I think they have access to pretty much any mfr, but I wouldn't swear to it. If they can get you what you want, they're great to work with.
http://www.elightbars.org/bb/profile.php?mode=viewprofile&u=165
Back to top    URL
Pat H.
PostPosted: Fri 21-Jul-2006 11:40    Post subject: Re: Knob Replacement Reply with quote
The problems sounds more with the underlying switch mechanism (pot?); it sounds like it is sticky. Not the knob itself.
Back to top    URL
Bill Skinner525
Moderator
Moderator
PostPosted: Fri 21-Jul-2006 17:27    Post subject: Reply with quote
Pat (as usual)is right, if the knob is sticky open the unit up & clean the PA300 selector knob. If you want to replace the knob a single set screw holds it in place & a pointy type replacement knob can be found for a few bucks at radio shack. The shaft is 1/4" and a knob that size will work. The older PA300's have an open wafer type selector which will get dirty over time, silver faced units are generally the older type. New PA300's use an enclosed selector which can still be cleaned by shooting contact cleaner in the shaft from the outside. Removing & totally cleaning the knob then shining it up with Armour-All might really help.
If not I have Factory & after market selector knobs in my shop for the PA300 if you are interested
Back to top    URL
zfire2
Regular
Regular
PostPosted: Fri 21-Jul-2006 22:13    Post subject: Reply with quote
It sounds like a bad Potentiometer. You should open the siren and look at what size pot it is. Take it out and bring it to your local radioshack. They sell all different types. Buy a new one, solder the two or three wires back to it and replace the knob. This should do it but you should check to make sure that it is a pot that the knob attaches to.
A pot looks like this:
http://www.radioshack.com/product/index.jsp?productId=2062357&cp=2032058.2032230.2032275&parentPage=family
Back to top    URL
Bill Skinner525
Moderator
Moderator
PostPosted: Fri 21-Jul-2006 22:18    Post subject: Reply with quote
The only pot on a PA300 is for the Volume control for the PA function, there is an on/off click power function for this switch, but the pot only controls PA volume. Once again all points lead to a bad/dirty selector switch on the PA 300. Based on years of working these units I can say, it is the most used control on the unit & thus usually the first one to act up
Back to top    URL
Joe S.
Regular
Regular
PostPosted: Sat 22-Jul-2006 03:24    Post subject: Reply with quote
So, it's not supposed to be that tough to turn? It's the only siren I've owned..
Back to top    URL
Pimpala03
Moderator
Moderator
PostPosted: Sat 22-Jul-2006 03:56    Post subject: Reply with quote
The knob on the PA300 should be about as easy to turn as a on/off light switch in a house.
Back to top    URL
Blaine B.
Turbo Poster
PostPosted: Sat 22-Jul-2006 15:47    Post subject: Reply with quote
Open it up, use brake cleaner on the switch mechanism, then spray with a bit of white lithium out of the can.
Back to top    URL
Bill Skinner525
Moderator
Moderator
PostPosted: Sat 22-Jul-2006 15:56    Post subject: maybe not Reply with quote
Blaine..... Brake cleaner(great for brakes) is a little caustic for some switches, Contact Cleaner is what it's called and that's what you should use. As far as the grease goes..well
fine if you get it on the mechanical points of the selector switch, but if it gets all over the switch contacts you just got what you cleaned dirty.
Just my 2 cents, but I've worked on over a hundred PA300's, been doing electronic & control work almost 30 years...age & experience do have some benefits...lol
Back to top    URL
Blaine B.
Turbo Poster
PostPosted: Sat 22-Jul-2006 17:17    Post subject: Reply with quote
I wasn't saying you were wrong, just figured the guy had some brake cleaner (who doesn't?) and he could just use that, in a small dose. My understanding is that brake cleaner is not harmful to electronics...
Back to top    URL
Bill Skinner525
Moderator
Moderator
PostPosted: Sat 22-Jul-2006 17:54    Post subject: Reply with quote
I understand, but I can tell you that not all Brake Cleaners are OK for sensitive electronics or contacts. A can of contact cleaner from Radio Shack is a safer route
Back to top    URL
tvsjr
Banned user
PostPosted: Sat 22-Jul-2006 18:11    Post subject: Re: Reply with quote
Bill's right... if nothing else, the hydrocarbons in brake cleaner will attack most wiring and plastics.
Back to top    URL
ToneFreak
Regular
Regular
PostPosted: Mon 24-Jul-2006 00:59    Post subject: Reply with quote
The PA300 is still in production, and you should be able to order replacement parts from Federal. Go to their web site and you should be able to find a link and an e-mail address to their service department.
Back to top    URL
Joe S.
Regular
Regular
PostPosted: Mon 24-Jul-2006 04:29    Post subject: Reply with quote
thanks for the tips and suggestions
Back to top    URL
Display posts from previous:
Post new topic   Reply to topic    eLightbars.org Forum -> Non-lighting warning equipment All times are GMT - 6 Hours
Page 1 of 1
