eLightbars Home
Make a contribution
2006 Ford Crown Vic Questions...
Author Message
badge22
New member
New member
PostPosted: Sat 12-Nov-2005 10:55    Post subject: 2006 Ford Crown Vic Questions... Reply with quote
A customer I am working with didn't order the options I had hoped for on their new car. Can someone help me out with the following:
Where is a good place to tap into the hornring for a SS2000?
Where is a good place to tap into a park kill?
Where is a good place to get keyed power, just enough to throw a relay?
I just want to make sure that I don't cause any problems with any possible changes for this model years wiring.
Thanks in advance!
Back to top    URL
Pat H.
PostPosted: Sat 12-Nov-2005 11:07    Post subject: Reply with quote
Who are you doing the install for, Mike?
Back to top    URL
Brent-WATTCO
Regular
Regular
PostPosted: Sun 13-Nov-2005 00:38    Post subject: Reply with quote
Ah
Hornring, Parkkill and ing source..
If only Ford would listen to me that these things should be standard drops from their harness....
Back to top    URL
EVModules
Contributing Silver Member
PostPosted: Sun 13-Nov-2005 01:43    Post subject: Reply with quote
Did you check to see if there's a single wire & multiple wire connector under the glove box (not behind, below)? It should be visible. If so, you'll find horn-ring & ignition there. Park kill at the steering column, only with a park kill module.
Back to top    URL
badge22
New member
New member
PostPosted: Sun 13-Nov-2005 09:50    Post subject: Drop Reply with quote
Sean,
There is a drop, but it's just some 14ga wires. Not the standard drop that has the conectors that accept the bullet connectors.
Thanks
Back to top    URL
badge22
New member
New member
PostPosted: Sun 13-Nov-2005 09:51    Post subject: Re: Reply with quote
[quote:4f084040d3=\"Brent-WATTCO\"]Ah
Yeah, apparently Chysler has been listening!!!
Back to top    URL
Brent-WATTCO
Regular
Regular
PostPosted: Sun 13-Nov-2005 12:53    Post subject: Re: Reply with quote
That is true - now if they can actually start delivering the cars that woudl be nice - alot of departments around me have them on order - but the transmission problem is a major worry.
[quote:6967f0c6bc=\"badge22\"][quote:6967f0c6bc=\"Brent-WATTCO\"]Ah
Yeah, apparently Chysler has been listening!!! Back to top    URL
Display posts from previous:
Page 1 of 1
