eLightbars Home
Make a contribution
NYPD Aero Twinsonic GOT IT TODAY !!!!!!!
Post new topic   Reply to topic    eLightbars.org Forum -> Collectible lighting
Author Message
WPD8908
Regular
Regular
PostPosted: Sun 29-Apr-2007 05:37    Post subject: NYPD Aero Twinsonic GOT IT TODAY !!!!!!! Reply with quote
I have a chance to buy an old NYPD Aero twinsonic from this guy 170 shipped, but its untested he says he bought it from a salvage company... should I chance it or pass it.
Edited Accordingly
here is what I got in the mail.. It looks like an old NYPD lightbar model # RMVF-2Z. Its beat up.. PICS here
Back to top    URL
Doug (MD)
Moderator
Moderator
Location: ** THE MD IS FOR MARYLAND ** Columbia, Maryland (USA)
PostPosted: Sun 29-Apr-2007 05:51    Post subject: Reply with quote
FYI, it's actually known as an AeroTwinSonic.
Back to top    URL
mychvycaprice9c1
Regular
Regular
PostPosted: Sun 29-Apr-2007 18:59    Post subject: Reply with quote
have you seen any pictures of it? The lenses are the important part.
They're fairly easy to fix if its a motor or a chain, theres lots of twinsonics still around to steal parts from if it came to that.
Back to top    URL
Ford-Dealer
Frequent Poster
PostPosted: Sun 29-Apr-2007 19:23    Post subject: Re: Reply with quote
[quote:611765962b=\"mychvycaprice9c1\"]have you seen any pictures of it? The lenses are the important part.
Actually...the chains are different lengths. Twinsonics are 54\" long, and the NYPD AeroTwin is only 47\" long. That having been said, MOST AeroTwins are longer...but the NYPD ones aren't Cool
Back to top    URL
WPD8908
Regular
Regular
PostPosted: Sun 29-Apr-2007 19:30    Post subject: Re: Reply with quote
[quote:ba940931dd=\"mychvycaprice9c1\"]have you seen any pictures of it? The lenses are the important part.
lenses are cracked in a few places and there is a chunk missing on one endcap
Back to top    URL
cmb56
Regular
Regular
PostPosted: Sun 29-Apr-2007 22:23    Post subject: Reply with quote
If you think it is worth it, the AeroDynic is still in manufacture so you should be able to get new domes for the AeroTwinSonic from Federal.
Back to top    URL
mychvycaprice9c1
Regular
Regular
PostPosted: Tue 1-May-2007 06:56    Post subject: Re: Reply with quote
[quote:50612121f0=\"Ford-Dealer\"]Actually...the chains are different lengths. Twinsonics are 54\" long, and the NYPD AeroTwin is only 47\" long. That having been said, MOST AeroTwins are longer...but the NYPD ones aren't Cool
wow, good to know!
Can you post the pics here? Does it have mounts? Lenses can be changed and repaired, but its a pain sometimes, how does it run?
Back to top    URL
WPD8908
Regular
Regular
PostPosted: Tue 22-May-2007 06:12    Post subject: Reply with quote
The guy still hasnt contacted me back on how he wants payment sent.... Still waiting.. Payment sent and bar is on its way.. Ill keep ya guys updated
Back to top    URL
WPD8908
Regular
Regular
PostPosted: Wed 6-Jun-2007 16:49    Post subject: PICS PICS PICS Reply with quote
bar works Great, I just need to do a little house cleaning, any advice on how to restore it would be greatly appreciated
here is the model number plate:
Broken Lenses Crying or Very sad
Red Film Instead of a red Bulb Rolling Eyes
Back to top    URL
mychvycaprice9c1
Regular
Regular
PostPosted: Wed 6-Jun-2007 18:07    Post subject: Reply with quote
doesent look too terrible. You'll need to locate some replacement lenses, check with ChargerLighting here, he usually has some pieces around. If not, ebay or others here might have some spares. Make sure you figure out the right sections (They're \"handed\", a piece will work for the front of one side or the back of the other)
Once you locate and end cap and a couple lenses, you'll have to remove the top chrome pieces, split the lenses apart carefully, install the new lense sections and put it all back together. If you try a search of the site, there should be some tips and advice on how to do this easily and what works best for it.
Keep us posted on the progress!
Back to top    URL
NPS Ranger
Contributing Member
PostPosted: Wed 6-Jun-2007 18:51    Post subject: Reply with quote
Correct bulbs are:
outer revolving: 4464 & 4464R (these are 60 watts each, many people incorrectly substitute 4416 which is 30 watts. No 7400's or 7600's please!)
inner flashing: 4414 (clear 18 watt with a faceted \"flood\" type outer glass lens, as opposed to a \"spot\" lamp like the 4416)
Good luck!
Back to top    URL
Phil
Regular
Regular
PostPosted: Wed 6-Jun-2007 19:40    Post subject: Reply with quote
Is there a good source for all those bulbs?
Back to top    URL
maxim2eng
Regular
Regular
Location: Roland, OK (formerly of Central VA; raised in KY)
PostPosted: Wed 6-Jun-2007 20:17    Post subject: Reply with quote
I noticed in the pics that the amber sections were facing forward (speaker housing gave it away). When you install new domes, red faces forward--amber to rear. (correct, all?)
Back to top    URL
WPD8908
Regular
Regular
PostPosted: Wed 6-Jun-2007 20:25    Post subject: Re: Reply with quote
[quote:ae88729e48=\"maxim2eng\"]I noticed in the pics that the amber sections were facing forward (speaker housing gave it away). When you install new domes, red faces forward--amber to rear. (correct, all?)
I dont think this guy knew what he had.. He had no idea what type of light this was
Back to top    URL
NPS Ranger
Contributing Member
PostPosted: Wed 6-Jun-2007 20:32    Post subject: Reply with quote
The clear versions aren't hard to find, the 4414 is a common bulb in emergency building lighting. Also try frontierlighting.com, moyerelectronics.com, topbulb.com, there must be others.
The red 4464R is VERY hard to find and when you do will most likely be lacquered clear bulbs. Maybe John Dorgan has a source.
Back to top    URL
cmb56
Regular
Regular
PostPosted: Thu 7-Jun-2007 07:58    Post subject: Reply with quote
I still do not know exactly what NYPD used for sealed beams in their 24RMVF-2Z, but my 24RMVF bought from Federal in 1989 had 4416 in the rotating and 4414 in the flashing positions.
It is the speaker housing that is backwards. The 24RMVF was delivered with the motor facing forward and NYPD had them mounted that way.
Back to top    URL
strobar
Regular
Regular
PostPosted: Mon 11-Jun-2007 03:15    Post subject: Reply with quote
WOOW!! Poor domes...! Shocked
Concerning the red bulb, I use a red plastic lens, the same used on PAR36 spotlight Idea , I'll take a picture asap.
Back to top    URL
SARGEEK
Regular
Regular
PostPosted: Tue 12-Jun-2007 15:27    Post subject: Galls Reply with quote
Do you all remember when Galls was selling NYPD areo-dynic bars used in their catalog? I was trying to sell my twin-sonic so I could by one.
The sold out before I could get one.
Back to top    URL
NPS Ranger
Contributing Member
PostPosted: Tue 12-Jun-2007 16:21    Post subject: Reply with quote
I remember when their catalog was 4 pages long on regular paper, 11x17 folded in half.
Back to top    URL
Display posts from previous:
Post new topic   Reply to topic    eLightbars.org Forum -> Collectible lighting All times are GMT - 6 Hours
Page 1 of 1
