| Author |
Message |
Lammrover Regular
Joined: 30 Oct 2005 Posts: 263 Location: Canton, Ohio
Posted: Sun 27-Nov-2005 20:17 Post subject: What's the scoop on this PS? |
I don't know much about strobe power supplies.
Would this one provide 25 watts, to each tube, 50, less...
It looks ideal for me but how does it compare to the more popular 60 watts?
EDIT: Was having a little issue with the link
http://www.lshlights.net/catalog/4__50_watt_hide-a-way_strobe_kit_whelen_s450cccc_2121294.htm
THANKS!
| Back to top URL |
Hugh A. Uber Poster
Posted: Sun 27-Nov-2005 20:33 Post subject: |
Umm, was there supposed to be a link, pic, or more info?  |
| Back to top URL |
Pat H. Administrator
Joined: 19 Aug 2005 Posts: 9545 Location: Phillips County, Montana
The model CSP450 will give you 12.5 watts per head with four strobes connected; it will put out 25 watts per head if only two strobes are connected. If you are only going to need a four outlet; go with the UPS64LXA. It is a 75 watt regulated power supply and will give you a consistent 18.75 watts per head. Or go with the CSP690. If you are only going to be using two strobes; then the CSP240 will work for you. |
| Back to top URL |
Lammrover Regular
Posted: Sun 27-Nov-2005 21:33 Post subject: |
So a strobe power supply delivers its maximum wattage divided by the number of lights/heads to each light/head?
Also, a friend of mine has a new TOMAR 4 head neobe hide-a-way system for $200. Would that be a better value than what I could get for $200 from Whelen?
Thanks! |
| Back to top URL |
STT Installer Regular
Posted: Sun 27-Nov-2005 21:58 Post subject: |
Basically you got it...
Regulated/Unregulated: With a unregulated power supply, you receive an equal share of the power to each head connected, i.e. 4/40 PS would provide 20w per head if only 2 were connected. A regulated power supply will provide a consistent amount of power regardless of whether you have 2, 4, 6 or 8 head attached. Key in point in the Whelen CSP690. Even if you only have 2 heads connected, the 6x90 PS will only provide 22.5 w per head. Kinda nice considering anything more is generally considered too much (READ melting tail light lenses).
The Tomar PS is generally a 4x60 PS. If you like the Tomar Neobe pattern, it's a good deal. I personally like it but prefer a bit more punch than just 15 w per tube. |
| Back to top URL |
