eLightbars Home
Make a contribution
my Tacoma with LX4's, vertex driving lights - updated 10-08
Post new topic   Reply to topic    eLightbars.org Forum -> Installs and member rides
Author Message
kohan25
Regular
Regular
PostPosted: Fri 25-Apr-2008 08:46    Post subject: my new Tacoma with LX4's and scanner - updated 10-08 Reply with quote
It is simple for now with the grille lights but I just bought it and am thinking of something by the RVM
http://s249.photobucket.com/albums/gg215/kohan25/?action=view&current=grillelts.flv
Double din dash kit worked perfect for my single din stereo and Uniden scanner (external speaker located below).
Back to top    URL
Mike - Tac 2
Contributing Member
PostPosted: Fri 25-Apr-2008 08:53    Post subject: Reply with quote
How about an Xtreme 9 or MicroMax Xtreme II?
Back to top    URL
jhook
Regular
Regular
PostPosted: Fri 25-Apr-2008 08:56    Post subject: Reply with quote
Nice truck ,so many options a guy could do have a look at the new (edit )soundoff ghost lights that are coming out 2 of those mounted to the back lip of your hood would look good.Or interior mount a Xtreme 6/9 dash light for some off axis warning.Also don't rule out the small but big punch of the ultralite dash lights.Par 36's in the fog lights would give some great off axis as well.thanks Mike for the correction
Back to top    URL
Mike - Tac 2
Contributing Member
PostPosted: Fri 25-Apr-2008 08:58    Post subject: Re: Reply with quote
[quote:5584107e14=\"jhook\"]Nice truck ,so many options a guy could do have a look at the new federal ghost lights that are coming out 2 of those mounted to the back lip of your hood would look good.Or interior mount a Xtreme 6/9 dash light for some off axis warning.Also don't rule out the small but big punch of the ultralite dash lights.
I think you mean Sound Off Ghosts... Smile
I like them, except for snow buildup on the hood.
Back to top    URL
Pat H.
PostPosted: Fri 25-Apr-2008 09:06    Post subject: Reply with quote
Kohan25,
Please keep your same topics consolidated in one thread and not seperate; ie, one vehicle one thread. I have combined your two posts for you. Also, any additional vehicle info should be added to this thread. Thanks
Admin
Back to top    URL
kohan25
Regular
Regular
PostPosted: Fri 25-Apr-2008 10:51    Post subject: Reply with quote
Sorry. Thanks for fixing.
Now that I am paying for truck and the $ gas for it, it will be hard to buy more lights now. I still have 2 more LX4's that I have to make a custom bracket for and mount in front of the rvm as I tried looking for a housing and they are not sold as a part.
Back to top    URL
kohan25
Regular
Regular
PostPosted: Tue 14-Oct-2008 10:30    Post subject: updated tacoma with rear leds and vertex drl's Reply with quote
Here is my Tacoma with probably the final install of lights. I couldnt resist the vertex lights and since I dont really use the stock driving lights much I thought it would be a great place for them. I think they look great and fill the reflector pretty well. I also installed 4 blue Tir4 type lights in the rear hooked up to a sho-me flasher. These were knock-off interior lightbar modules that fit perfectly in the back window with double stick tape on the bottom. I also have 2 amber modules but have not hooked them up yet.
http://s249.photobucket.com/albums/gg215/kohan25/?action=view&current=frontlights.flv
http://s249.photobucket.com/albums/gg215/kohan25/?action=view&current=rearlights.flv
Back to top    URL
Redsquirrel
Regular
Regular
PostPosted: Tue 14-Oct-2008 13:10    Post subject: Reply with quote
I like it. Simple and effective. Any thought of intersection/side warning?
Back to top    URL
Robert W.
Regular
Regular
PostPosted: Tue 14-Oct-2008 15:42    Post subject: Reply with quote
How about syncing the Vertex's
Overall great install, clean very low profile, and it matches the exterior color of the car!
Back to top    URL
kohan25
Regular
Regular
PostPosted: Wed 15-Oct-2008 07:50    Post subject: Reply with quote
I think I do have them syncd? although it does not look like it because with the grille lights flashing it makes it hard to tell. I connected both sync wires together and went through the patterns and came up with the alternating slow to fast flash pattern(whatever name that is). I was going to put them on a separate switch when I get time.
I want to keep the look as stealthy as possible. I keep the dash light in my door pocket and use mostly during the day for extra warning.
Even though I love the leds, I dont think I will be adding anymore to the front, rear or sides. I think I am done for now.
Back to top    URL
Robert W.
Regular
Regular
PostPosted: Wed 15-Oct-2008 08:39    Post subject: Reply with quote
I see the problem... I think you have the lights on ModuFlash, which is a non-syncable pattern. Even if the wires are connected they won't sync.
You have to select a pattern that is syncable (listed on the install guide). Typically it is just signalalert, comet flash, double flash, a slow single flash, and ping pong (there may be others, but those are the only ones that come to mind). It is kind of annoying, but when I decide to get my vertex's, I will probably run them through the ULF44 already installed.
EDIT: found the guide... Whelen has them listed as \"6 LED Hideaways\" (huh?):
http://www.whelen.com/install/142/14208.pdf
Your choices are:
SignalAlert, CometFlash, DoubleFlash, SingleFlash, ComAlert, LongBurst, and PingPong
Back to top    URL
kohan25
Regular
Regular
PostPosted: Wed 15-Oct-2008 09:48    Post subject: Reply with quote
Thanks for the info. I will have to try again to synch them. I kind of thoughts they were off.
Back to top    URL
Display posts from previous:
Post new topic   Reply to topic    eLightbars.org Forum -> Installs and member rides All times are GMT - 6 Hours
Page 1 of 1
