| Author |
Message |
opskmallory Regular
Posted: Tue 21-Oct-2008 14:30 Post subject: CSP690 v UPS64LX |
So it might be a little too late to ask this question (since I already bought a 690). The 64LX which I already have is a 75 watt power supply. I wanted to make my HAW's brighter, so I figured a 90 watt PS would be the way to go. I opted for the CSP690 because it's 90 watts and unregulated, so more power would go to the HAWs if only 4 outlets are being used.
I was just thumbing around the product bulletin for Whelen PS's and discovered that the CSP690 only puts out 15 watts per outlet, regardless of how many outlets are being used. I would figure since the UPS64 is only a 75 watt PS, that naturally, it would put out less power than a 90 watt PS. But after reading, it says that the UPS64 actually puts out 18.75 watts per outlet.
Is this information correct? According to the bulletin, my only option for getting my strobes brighter is to step up to an ISP series PS, and nearly double the price.
Does this seem correct? Anyone with extensive strobe knowledge, please let me know.  |
| Back to top URL |
Andy L. Moderator
Joined: 21 Aug 2005 Posts: 2872 Location: Hart, Michigan - by some big sand dunes
Posted: Tue 21-Oct-2008 14:44 Post subject: |
The switching on the 690 is 2x4. I may be incorrect but I believe if you activate the bank of four outlets and connect only two strobes you'll get more power out of them. It seems like I remember reading that on here before.
How many HAW's are you trying to power? The CSP240 maybe a good solution if you're only powering 2 HAWs. That would give you 20W per channel. |
| Back to top URL |
opskmallory Regular
Posted: Tue 21-Oct-2008 15:15 Post subject: |
| Just 4 strobes. That's why I figured a 690 would be good, since 2 of the 6 outlets would not be used, thus give a little more juice to the remaining 4. |
| Back to top URL |
TxFire Administrator
Joined: 19 Aug 2005 Posts: 3000 Location: Cedar Creek Lake, Texas
Posted: Tue 21-Oct-2008 16:43 Post subject: |
| I once had this dilemma!! I played with it to no end and ended up on the 64LX unit. On the 6/90, I activated only the 4 outlets with 4 clear tubes and it was a good output, but switched over to the 64lx unit and for some reason, the WOW effect kicked on. Not sure why...but the ol trusty 64lx seems to one tough unit!! |
| Back to top URL |
kitn1mcc Frequent Poster
Joined: 17 Sep 2006 Posts: 1127 Location: Old Lyme CT
Posted: Tue 21-Oct-2008 17:01 Post subject: |
| when i used to do alot of HAW in plow truck (before LEDS) i would only use the ups64c then xlt they are one of the best P/S on the market |
| Back to top URL |
C17LVFD Regular
Joined: 17 Oct 2007 Posts: 210 Location: Baltimore, MD
Posted: Tue 21-Oct-2008 18:00 Post subject: |
I know your dilemma as well... I ended up going to all LAWS, but previously, I went through many a power supply... and the best ones I found were the ISP94 and ISP188.... 4 or 8 outlets 90 or 180 watts respectively... so that's 22.5 watts per tube... they're bright as all get out and blink capable with my favorite pattern....Actionflash!
Good Luck!
Seth
PS: I have an ISP94 if you're interested |
| Back to top URL |
grfd711 Moderator
Joined: 16 May 2007 Posts: 3318 Location: Gravel Ridge, AR
Posted: Tue 21-Oct-2008 20:50 Post subject: |
Got a UPS-64LX sitting next to me right now.
Power rating:
75 watts @4 lamps
40 watts @2 lamps
As a former owner of a UPS690, only 15 watts per head, regardless of how many your running (per the label). Now, I have no clue about the thing Andy was talking about. |
| Back to top URL |
RCurley Regular
Joined: 07 Sep 2005 Posts: 224 Location: Bridgeport/Shelton/Naugatuck, CT
Posted: Wed 22-Oct-2008 22:50 Post subject: |
the ups64lx is an awesome pack. i ran 2 of thenm in my old car for years before i moved onto the ISP188.
i would personally go with the ups64lxa though. 75watts, all the scanlock patterns, and it will sync to any syncable product from whelen. including a second usp64lxa |
| Back to top URL |
grfd711 Moderator
Posted: Thu 23-Oct-2008 16:38 Post subject: |
Boy, you can say that again.  |
| Back to top URL |
chris Hansen Member
Posted: Fri 31-Oct-2008 11:34 Post subject: |
| I can't find anything that says max 15 watts per head on my csp 690. |
| Back to top URL |
opskmallory Regular
Posted: Sat 1-Nov-2008 08:00 Post subject: Re: |
| [quote:91b6ec584d=\"chris Hansen\"]I can't find anything that says max 15 watts per head on my csp 690. |
The max wattage is specified on the Whelen Power Supply product bulletin. |
