| Author |
Message |
MarkClements Frequent Poster
Joined: 25 Oct 2006 Posts: 1577 Location: Platteville, WI
Posted: Fri 24-Oct-2008 07:34 Post subject: Question on Avalanche dash lights |
I need find a good spot to tap into the dash lights on a 2002 Chev Avalanche. I installed a switchbox and want the backlights tied in with the dash to make them dimmable.
Install gurus.... where is the best place to tie it in? |
| Back to top URL |
tekguy Regular
Joined: 04 Jan 2008 Posts: 154 Location: los angeles california
Posted: Fri 24-Oct-2008 19:29 Post subject: |
| radio?????????????????????????? |
| Back to top URL |
Posted: Fri 24-Oct-2008 19:59 Post subject: |
I'm wondering if anyone out there has done one or knows what color wire to tap and where? Its too bad they don't have a lighted ashtray or something under the dash thats easy to get to. I really don't feel like taking the dash apart again  |
| Back to top URL |
rescue76_822 Turbo Poster
Joined: 15 Oct 2005 Posts: 2467 Location: Corbin, Ky The Whitley, Knox, Laurel..Tri County Region
Posted: Fri 24-Oct-2008 20:54 Post subject: |
| the radio fuse or dash fuse might be a good place. |
| Back to top URL |
Pj Turbo Poster
Joined: 18 Aug 2005 Posts: 2371 Location: Federal Plaza, Manhattan, New York County, NY, USA, Earth
Posted: Fri 24-Oct-2008 21:20 Post subject: |
The 2002 is similar to the 02 Tahors/burbs...and many of the tricks don't work or isn't documented well.
However.... (if its there), tap into the side fuse panel and look for the radio fuse. There should be a label on the back side of the access cover. I know my Avalanche (04) has a couple of different places where the radio has a fuse, depending on the sound system installed.
My ignition is taped at the underhood fuse panel. |
| Back to top URL |
pondfly Contributing Member
Joined: 28 Dec 2007 Posts: 319 Location: Unincorperated Wood Dale, IL
Posted: Sat 25-Oct-2008 17:23 Post subject: |
| Go to www.chevyavalanchefanclub.com and do a search. I have it done in my Avy, but I wont see it for a couple of days and pull it up. |
| Back to top URL |
mhpf15 Regular
Posted: Sun 26-Oct-2008 09:09 Post subject: |
| i'm not sure but if you tap into the fuse in the fuse panel going to the dash, or radio, that's just gonna be 12v, and it's not gonna dim the panel. you may have to take the headlight switch out and take a volt meter and run the dimmer dial up and down while checking voltage to find the wire that causes the lights to dim. |
| Back to top URL |
Posted: Mon 27-Oct-2008 20:40 Post subject: |
Found it....
The following info is for model year 02 only!
All wires found in the radio harness unless noted.
Wire Color
Radio 12V Orange
Radio Ground Black
Radio Ignition Dark Green
Radio Illumination Brown
Factory amp turn-on Pink (amp is behind glove box)
LF Speaker +/- Tan-Gray
RF Speaker +/- Light Green-Dark Green
LR Speaker +/- Brown-Yellow
RR Speaker +/- Dark Blue-Light Blue
No power antenna for 02's. |
| Back to top URL |
