| Author |
Message |
ff168577 Regular
Joined: 02 Jul 2008 Posts: 70 Location: Levittown, Pa
Posted: Tue 28-Oct-2008 20:37 Post subject: excalibur |
A gentleman from my firehouse has an excalibur that I installed about 2 years ago. We recently ran into a problem with it. When we turn on one out of the 2 switches(does not matter which one) we get a weird humming backfeed noise in the lightbar. There is power going to the switch box, and all the connections are ok. Could there be moisture in the lightbar in the circuit or one of the connections? Is the main circuit block or relay bad? Any idea's or suggestions let me know. Thank you
Tim |
| Back to top URL |
C3Chuck Regular
Joined: 31 Aug 2005 Posts: 244 Location: St. Louis, MO
Posted: Tue 28-Oct-2008 21:41 Post subject: |
First thought was that you have a bulb out. Thermal flashers like the Tridon will make an odd buzzing/screach when one side has no load.
Can you describe what's in the bar, flasher, strobes, options? |
| Back to top URL |
ff168577 Regular
Posted: Tue 28-Oct-2008 21:58 Post subject: |
| It has 5 slow speed rotators, 4 rear flashers. It can not remember if it has alleys or takedowns. |
| Back to top URL |
Robert W. Regular
Joined: 27 May 2008 Posts: 907 Location: Hartford, CT
Posted: Tue 28-Oct-2008 22:28 Post subject: |
When you turn every feature on what actually comes on?
The last time I had humming/screech that didn't result from a bad feed the power lines connected to the office were surging and the sound of the surging was being played through the speakers. It was a very loud humm/screech, then it would start sounding like the world's largest relay was slapping on and off |
| Back to top URL |
ff168577 Regular
Posted: Wed 29-Oct-2008 16:19 Post subject: |
| When I turn on the two switches that control the lightbar, nothing works. Nothing works when I turn on either switch. I figured the relay took a dump, and that was the issue and that was where I was going to start. |
| Back to top URL |
