| Author |
Message |
Credicon Regular
Joined: 01 Dec 2005 Posts: 181 Location: Ontario, Canada
Posted: Thu 30-Oct-2008 08:04 Post subject: LED Arrow Stick Control |
I am looking for a arrow stick control that will control 8 LEDs, but I need it to be a small unit, that doesn't require an control head, and can be controlled from 3 trigger wires (Left, Right, Warn) (where left &right together produce center out) as my current setup only allows that.
I have looked around but can't really find anything other than one that comes built in to some Whelen Dominators.
Any help on recommendations would be great.
| Back to top URL |
cajunblitz Professional Upfitter
Joined: 12 Apr 2006 Posts: 766 Location: Saint Martin Parish, Louisiana
Posted: Thu 30-Oct-2008 08:27 Post subject: |
SoundOff Ultralite will work like that.
Check it out:
SoundOff Ultralite
cajunblitz |
| Back to top URL |
Credicon Regular
Posted: Thu 30-Oct-2008 08:38 Post subject: Re: |
[quote:1111b5fd79=\"cajunblitz\"]SoundOff Ultralite will work like that.
Check it out:
SoundOff Ultralite
cajunblitz |
that's for a full arrow stick, I already have an 8 Head arrow stick, I just need the controller. |
| Back to top URL |
Redsquirrel Regular
Joined: 21 Jul 2008 Posts: 54 Location: Georgetown, MA
| Back to top URL |
Posted: Thu 30-Oct-2008 09:06 Post subject: Re: |
[quote:3abefe4e01=\"Credicon\"][quote:3abefe4e01=\"cajunblitz\"]SoundOff Ultralite will work like that.
Check it out:
SoundOff Ultralite
cajunblitz |
Excuse the ring. I misread the post.
cajunblitz
| Back to top URL |
EVModules Contributing Silver Member
Joined: 20 Aug 2005 Posts: 1631 Location: San Gabriel Valley, Ca
Posted: Thu 30-Oct-2008 12:27 Post subject: |
I have a module that allows you to use any single momentary button to scroll thru the patterns (1-2-3-off-1-2-3-off...etc). I made it to address the space issues of a particuliar application of a department. Worked out very very well and a cheap controller too at only $44.
Sean |
| Back to top URL |
Credicon Regular
Posted: Thu 30-Oct-2008 12:42 Post subject: |
| anyone know if the whelen dominator arrow stick controllers can be purchased separately? |
| Back to top URL |
Redsquirrel Regular
| Back to top URL |
A-TAD Member
| Back to top URL |
Credicon Regular
Posted: Thu 30-Oct-2008 15:46 Post subject: |
| im actualy just looking for one that comes out to 3 or so wires that you put power to for left, right, and warn... |
| Back to top URL |
Robert W. Regular
Joined: 27 May 2008 Posts: 907 Location: Hartford, CT
Posted: Thu 30-Oct-2008 16:41 Post subject: |
| I think what you are looking for is something like the Dominator (Not the TAM83 model - that has a controller( or Ultra light that uses an internal controller on the bar. I have looked for the same thing you are (a TA controller that lets you use your own swithces) and so far nothing. The closest I have found is that that the TACTLD1 (Whelen's LED Controller) has a wire coming out the back that will let you activate it remotely to flash mode by giving that wire power when the unit is off. |
| Back to top URL |
DaveCN5 Contributing Member
Joined: 13 Jan 2007 Posts: 4241 Location: Fairfield County, CT
Posted: Thu 30-Oct-2008 16:54 Post subject: |
| Closest you are going to get is the Whelen UFM8 |
| Back to top URL |
Robert W. Regular
Posted: Thu 30-Oct-2008 18:04 Post subject: |
I forgot about that guy... I have never really seen them used.. but that would do what you need when it is in traffic advisor mode.
The only thing about that is it is not a true controller, you have to install power and ground for each light, as apposed to switching lights either through positive or negative.
If you haven't bought anything yet, then you should probably get something like the sound off ultralight or the dominator with internal controller - those would not need any extra controllers and the functions could be controlled through switches. |
| Back to top URL |
rescue_oz Frequent Poster
Joined: 21 Aug 2005 Posts: 1706 Location: Sydney Australia
Posted: Fri 31-Oct-2008 01:18 Post subject: Re: |
| [quote:be4a9fd6f6=\"DaveCN5\"]Closest you are going to get is the Whelen UFM8 |
Its not small but it does the job.... |
| Back to top URL |
