| Author |
Message |
John Hearne Regular
Posted: Sun 2-Nov-2008 09:28 Post subject: CenCom Traffic Advisor Question |
| How do you configure a CenCom so that the traffic advisor activates in the \"Flash\" mode when a button other than \"Flash\" is activated? (For instance when the pursuit switch is moved to position two or when SW7 is activated) |
| Back to top URL |
cajunblitz Professional Upfitter
Joined: 12 Apr 2006 Posts: 765 Location: Saint Martin Parish, Louisiana
Posted: Sun 2-Nov-2008 10:49 Post subject: Re: CenCom Traffic Advisor Question |
| [quote:517c225645=\"John Hearne\"]How do you configure a CenCom so that the traffic advisor activates in the \"Flash\" mode when a button other than \"Flash\" is activated? (For instance when the pursuit switch is moved to position two or when SW7 is activated) |
In the programming, uncheck the \"Cancel Flash\" box under the desired slide switch position to activate \"Flash\" mode on the T/A.
Sound right?
cajunblitz |
| Back to top URL |
Andy L. Moderator
Joined: 21 Aug 2005 Posts: 2871 Location: Hart, Michigan - by some big sand dunes
Posted: Mon 3-Nov-2008 07:36 Post subject: |
The \"Cancel Flash\" will only turn off the flash mode if it is already activated.
What type of TA are you running? Traditional, 2-Wire, WC?
On the Traditional setup you will find a specific section under the slide switch positions that allows you to activate flash 1, flash 2, or flash 3. |
| Back to top URL |
John Hearne Regular
Posted: Tue 4-Nov-2008 21:42 Post subject: |
| I will most likely be buying a new traffic advisor, the 10 head TIR InnerEdge version which is a three wire model IIRC. |
| Back to top URL |
Andy L. Moderator
Posted: Sun 9-Nov-2008 16:11 Post subject: |
| With the 3-wire style the CenCom just switches outlets 8,9, and 10 to control the TA. You will be able to program the unit to activate the outlet that controls \"flash\" with any other push button or slide switch position. |
| Back to top URL |
John Hearne Regular
Posted: Mon 10-Nov-2008 08:44 Post subject: |
| Thanks for that info. My plan is slowly coming together.... |
| Back to top URL |
liberal noob Regular
Posted: Mon 10-Nov-2008 16:38 Post subject: Re: |
| [quote:f90260aac4=\"John Hearne\"]Thanks for that info. My plan is slowly coming together.... |
Stop rubbing your hands. |
| Back to top URL |
John Hearne Regular
Posted: Tue 11-Nov-2008 19:55 Post subject: Re: |
| [quote:1aff32092a=\"liberal noob\"]Stop rubbing your hands. |
That's fine but I'm still stroking my mustache... |
| Back to top URL |
