| Author |
Message |
magillapd Contributing Member
Joined: 18 Aug 2007 Posts: 84 Location: Fort Worth, TX
Posted: Sun 2-Nov-2008 16:37 Post subject: FS Vector Smart Pod Question |
Forgive me if this has already been asked, I tried to search but my computer was getting hung up.
I have a smart vector and one of the smart pods is acting all kinds of funky. It will not return to the home position and doesn't want to rotate. IT will light up in TD mode or Alley, but it's not aimed in the right place. It was working just fine eariler, then when I turned it on again....this is what happened.
The other pod works just fine.
Any help would be appreciated. |
| Back to top URL |
lightbarsforsale.com Regular
Posted: Mon 3-Nov-2008 12:35 Post subject: my thoughts |
| my experience has been the chip - circuit board - in the pod has been bad |
| Back to top URL |
EVModules Contributing Silver Member
Joined: 20 Aug 2005 Posts: 1631 Location: San Gabriel Valley, Ca
Posted: Mon 3-Nov-2008 20:25 Post subject: |
The black position sensor that senses the rotator position, swap it out with another pod and see what it does. If the problem migrated to the other pod, you have a bad sensor which needs to be replaced.
If it's still with the same pod, go to the board and swap the motor harness. If it migrates to the other, either the cable's bad or the circuit board's bad.
Sean |
| Back to top URL |
Posted: Mon 3-Nov-2008 21:01 Post subject: |
| Ok, thank you. I will try that. I bought those pods on Ebay as is, and until now they worked great. |
| Back to top URL |
JDH Regular
Joined: 27 Aug 2005 Posts: 427 Location: Maitland, Fl.
Posted: Tue 4-Nov-2008 09:59 Post subject: |
| Check the connections on the board from the rotator/lamp pods. I have had weird things happen with mine as you discribed. I found that sometimes the connectors do not make good contact. |
| Back to top URL |
