eLightbars Home
Make a contribution
2008 Chevy Trailblazer
Goto page 1, 2  Next
Post new topic   Reply to topic    eLightbars.org Forum -> Installs and member rides
Author Message
DispDave
New member
New member
PostPosted: Sun 2-Nov-2008 19:57    Post subject: 2008 Chevy Trailblazer Reply with quote
First - let me say thanks to all for the forums and information. The lessons learned from here are what prompted a lot of my plans for this vehicle. All LED's are red.
Whelen LIN3's in grille and Avenger at passenger visor.
Close up of Avenger
Thanks to 10-75 Emergency Lighting for the stealth plate bracket
Whelen LIN4's in both rear sides.
Whelen Dominator in top and LIN3's on rear gate. (Dominator can be shut off via Cencom to work in back)
Cencom and M/A-Com M7100 control head (800 trunked)
Vertex control head for both VHF & UHF radios
Side panel in rear now contains an always on and keyed power fuse panels.
Cencom and M7100 radio mounted in rear hidden storage.
Here's the obligatory video - first one I've taken with the camera so apologies for the quality.
Back to top    URL
Bonanno
Regular
Regular
PostPosted: Sun 2-Nov-2008 20:17    Post subject: Reply with quote
Very nice... good job.
that took balls to drill right in the back hatch, I was expecting to see a license plate bracket, but was wrong.
Back to top    URL
pdk9
Regular
Regular
PostPosted: Sun 2-Nov-2008 20:19    Post subject: Reply with quote
nice ride. u have any plans to sync the lins in the grill (i.e. x-pattern).
2 things i might done are lx4's instead of lin4's to punch through the tint in the back sides and center the avenger (just below rvm or on dash)...maybe a diff flash pattern for the d4, but thats just my personal pref. other than that, looks good. drive safe
Back to top    URL
pdk9
Regular
Regular
PostPosted: Sun 2-Nov-2008 20:24    Post subject: Reply with quote
PS, i see a dodge in the garage....i hope we'll be seeing a lighting setup for that soon? Wink
Back to top    URL
honkerburger
Regular
Regular
PostPosted: Sun 2-Nov-2008 21:19    Post subject: Reply with quote
How you mount the avenger?
Back to top    URL
emtnfirefighter
Regular
Regular
Location: Old Bridge, NJ - its better then the new one!
PostPosted: Sun 2-Nov-2008 21:25    Post subject: Reply with quote
Can u take pics of the lin4's mounted inside the back side windows?
Here's my 2008 Trailblazer..
http://www.elightbars.org/bb/post51145.html
Back to top    URL
Klein36
Frequent Poster
PostPosted: Sun 2-Nov-2008 21:51    Post subject: Reply with quote
very nice. i like your flash pattern on the grille lights. IMO, don't snyc them. i am all against syncing lights. +1 for moving the avenger to the RVM area. i know that radio head is there...just a thought. very nice install. Very Happy Very Happy
Back to top    URL
RolnCode3
Regular
Regular
PostPosted: Sun 2-Nov-2008 22:43    Post subject: Reply with quote
How are the lin's held against the grill? Been thinking about moving my TIR's from inside the grill to outside...
Back to top    URL
Bonanno
Regular
Regular
PostPosted: Sun 2-Nov-2008 22:46    Post subject: Reply with quote
Leave the avenger where it is. Its all personal choice. I'm like you, I have my talon mounted in the same spot on my Explorer.
Back to top    URL
KFD236
Regular
Regular
PostPosted: Sun 2-Nov-2008 23:33    Post subject: Reply with quote
I like it. I like the look of the avenger under the visor. They made visor mounts for a reason. I am for synching but at a pattern like that you don't really need to. How did you key switch one of those fuse blocks? Stupid question but when you say key switch you mean those electronics and whatever tied into the fuse block come on when whe you turn the key either to acc or start it?
Looks great keep up the good work with that charger.
Thanks
Matt
Back to top    URL
usdemt
Regular
Regular
PostPosted: Mon 3-Nov-2008 01:27    Post subject: Reply with quote
Wow great job. Looks like you are a season pro. Those are some super heavy wires running from that fuse block for all the LED's you are running. I suspect they are to something else but I would make sure that the fuse blocks can handle that amperage. Also find some scrap plastic and shim the top LIN 3's you would be surprised how much power you lose when you point them slightly up or down.
I love the radio mounting. What do you do when you want to transmit? I am thinking I might have to do the same but I will have to figure out something for the mic.
Back to top    URL
DispDave
New member
New member
PostPosted: Mon 3-Nov-2008 05:48    Post subject: Re: Reply with quote
[quote:1e0278f0cc=\"pdk9\"]PS, i see a dodge in the garage....i hope we'll be seeing a lighting setup for that soon? Wink
Nope - that's the personal ride. Trailblazer is my work ride.
Back to top    URL
DispDave
New member
New member
PostPosted: Mon 3-Nov-2008 05:50    Post subject: Re: Reply with quote
[quote:21a4a31700=\"Klein36\"]very nice. i like your flash pattern on the grille lights. IMO, don't snyc them. i am all against syncing lights. +1 for moving the avenger to the RVM area. i know that radio head is there...just a thought. very nice install. Very Happy Very Happy
I'm a tall guy and prefer the avenger on the passenger side but regardless the radio head is centered. Need to be able to reach that Smile
Back to top    URL
DispDave
New member
New member
PostPosted: Mon 3-Nov-2008 05:53    Post subject: Re: Reply with quote
[quote:193a8ec6ca=\"usdemt\"]Wow great job. Looks like you are a season pro. Those are some super heavy wires running from that fuse block for all the LED's you are running. I suspect they are to something else but I would make sure that the fuse blocks can handle that amperage. Also find some scrap plastic and shim the top LIN 3's you would be surprised how much power you lose when you point them slightly up or down.
The mic is remoted to inside the center console/armrest. Just the head up there.
Back to top    URL
60a
Regular
Regular
PostPosted: Mon 3-Nov-2008 06:03    Post subject: Reply with quote
I love it, especially the way you mounted the Vertex radio above the mirror. Fantastic job!
Back to top    URL
kitn1mcc
Frequent Poster
PostPosted: Mon 3-Nov-2008 08:11    Post subject: Reply with quote
verry nice
Back to top    URL
Robert W.
Regular
Regular
PostPosted: Mon 3-Nov-2008 11:40    Post subject: Reply with quote
Dang that is a clean install... way to find creative places for things..
Back to top    URL
kiwibagpiper
Regular
Regular
PostPosted: Mon 3-Nov-2008 12:13    Post subject: Reply with quote
Mmm I want one Twisted Evil
Back to top    URL
Klein36
Frequent Poster
PostPosted: Mon 3-Nov-2008 22:48    Post subject: Re: Reply with quote
[quote:0914d81f39=\"DispDave\"][quote:0914d81f39=\"Klein36\"]very nice. i like your flash pattern on the grille lights. IMO, don't snyc them. i am all against syncing lights. +1 for moving the avenger to the RVM area. i know that radio head is there...just a thought. very nice install. Very Happy Very Happy
Ah. Makes sense now. My favorite is the radio head mounting. Very cool and effective.
Back to top    URL
grfd711
Moderator
Moderator
PostPosted: Tue 4-Nov-2008 01:00    Post subject: Reply with quote
I like it.
Back to top    URL
grfd711
Moderator
Moderator
I like it.
Back to top    URL
fiveohFL
New member
New member
PostPosted: Tue 4-Nov-2008 09:18    Post subject: Nice Install Reply with quote
Looks good.
Two questions regarding the M/A Com radio.
1. What is the extra cable plugged into the rear of the main unit? Our units only have the one cable, which eventually hooks up the remote mic. Yours looks like you have a second cable fitted between the main cable and the unit.
2. Where did you get the mic holder?
Back to top    URL
MEVS06
Frequent Poster
PostPosted: Tue 4-Nov-2008 12:21    Post subject: Reply with quote
good job nice install
joe
Back to top    URL
hawkspringsfire
Contributing Member
PostPosted: Tue 4-Nov-2008 13:44    Post subject: Re: Nice Install Reply with quote
[quote:294a3bb4d5=\"fiveohFL\"]
You can find those on eBay. They are meant for cell phones but you can mount what ever you want on them.
Back to top    URL
DispDave
New member
New member
PostPosted: Tue 4-Nov-2008 14:55    Post subject: Re: Nice Install Reply with quote
[quote:cca504e9f5=\"fiveohFL\"]Looks good.
1. The extra cable is for the dual head that is now mounted on my Odyssey Auto cabinet in the back (more pics to follow).
2. http://www.kudausa.com (great stuff! We use these for all the unmarked cars)
Back to top    URL
Display posts from previous:
Post new topic   Reply to topic    eLightbars.org Forum -> Installs and member rides All times are GMT - 6 Hours
Goto page 1, 2  Next
Page 1 of 2
