eLightbars Home
Make a contribution
Fed Sig Legend LED Lightbar Flash Patterns
Author Message
R1MS12
Regular
Regular
PostPosted: Mon 3-Nov-2008 15:54    Post subject: Fed Sig Legend LED Lightbar Flash Patterns Reply with quote
I have tried searching, but still have not come up with a way to change flashpatterns on this bad boy. I have no experience with this product, but need to change the flash patterns on it - can anyone help point me in the right direction? Thanks in advance for any assistance.
Back to top    URL
ff168577
Regular
Regular
PostPosted: Mon 3-Nov-2008 16:19    Post subject: Reply with quote
Use a magnet over the right rear corner of the light. If it does not work there, then try it over the right front corner and that should change the pattern.
Back to top    URL
cajunblitz
Professional Upfitter
PostPosted: Mon 3-Nov-2008 16:36    Post subject: Re: Fed Sig Legend LED Lightbar Flash Patterns Reply with quote
[quote:e45618a532=\"R1MS12\"]I have tried searching, but still have not come up with a way to change flashpatterns on this bad boy. I have no experience with this product, but need to change the flash patterns on it - can anyone help point me in the right direction? Thanks in advance for any assistance.
Locate your Serial Interface Module first.
You have to program the patterns from highest setting to lowest i.e. Position 3 first, then Position 2 then position 1.
Flip the #6 DIP switch on your serial interface module on, then apply ignition to the serial inteface module (if it's already wired into your car, turn the key on) then apply power to position 3.
Press and release the little button on the serial interface module and watch the bar...the pattern will change. Let it cycle through at least once, then remove power from the position 3 (wire).
Apply power to Position 2 , then press the switch until the pattern changes to what you want again. Let it cycle once on the pattern you want, then remove power from Position 2.
Apply power to Position one and repeat the directions.
Remove power from position one, flip the DIP switch off, and THEN remove ignition. If you remove ignition at any time during your programming session, you will not lock in your new patterns. AWait until you are completely done before removing ignition.
Click here for the PDF:
cajunblitz
Back to top    URL
cajunblitz
PostPosted: Mon 3-Nov-2008 16:40    Post subject: Re: Fed Sig Legend LED Lightbar Flash Patterns Reply with quote
[quote:d1d15cac34=\"R1MS12\"]I have tried searching, but still have not come up with a way to change flashpatterns on this bad boy. I have no experience with this product, but need to change the flash patterns on it - can anyone help point me in the right direction? Thanks in advance for any assistance.
Press and release the little button on the serial interface module and watch the bar...the pattern will change. Keep pressinguntil you find a pattern you like, but wait a few seconds for the pattern to cycle before pressing again .Once you find your pattern for Position 3, let it cycle through at least once, then remove power from the position 3 (wire).
cajunblitz
Back to top    URL
ff168577
Regular
Regular
PostPosted: Mon 3-Nov-2008 16:46    Post subject: Reply with quote
I am sorry I was thinking the highlighter. My apologies. Thanks cajun for handleing.
Back to top    URL
R1MS12
Regular
Regular
PostPosted: Mon 3-Nov-2008 21:39    Post subject: Reply with quote
Outstanding, many thanks.
Back to top    URL
Display posts from previous:
Page 1 of 1
