| Author |
Message |
ddiesel2006 Regular
Posted: Tue 4-Nov-2008 01:17 Post subject: BL10000 Communications |
I've got a BL10000 that I think has some communications issues. Sometimes when a button is pressed, (TD, alley, outboard strobes, etc), the red indicator light on the controller (MPC-01) just flashes and nothing happens. Other times it works fine. What should I check first?
It's also got 3 strobes out. Is this more likely burned out bulbs or a burned power supply or something? |
| Back to top URL |
Pj Turbo Poster
Joined: 18 Aug 2005 Posts: 2371 Location: Federal Plaza, Manhattan, New York County, NY, USA, Earth
Posted: Wed 5-Nov-2008 22:12 Post subject: |
If the indicator light flashes, it means there is a problem somewhere. What is that function suppose to do?
Most common cause is a loose communications wire (is the serial cable properly connected at all locations, using the proper cable).
2nd to that, would be a light head on its way out.
What you need to do is ensure that all cabling is tight and connected properly.
The BL10000 draws a bunch of amps in a fully loaded bar. Make sure you running this on a vehicle that is running, and connected to the battery with proper fuses and connections. |
| Back to top URL |
