| Author |
Message |
philyumpshus Regular
Posted: Thu 6-Nov-2008 06:56 Post subject: Unitrol 80K Question |
I was going to put this in my old post, but the edit isn't working...
Anyways, I have a Unitrol 80K siren that is wired for \"Option 2\" for the siren tones. First position is wail with yelp override, second position is hi lo with hetro override. My question is, after working fine, I touched a hot wire to the horn ring switch post and now instead of wail, it's working on yelp, and second position goes straight to hetro. I don't think I messed anything up, buy I would like to reset it so I have wail and hi lo back. Does anyone know how? |
| Back to top URL |
cajunblitz Professional Upfitter
Joined: 12 Apr 2006 Posts: 765 Location: Saint Martin Parish, Louisiana
Posted: Thu 6-Nov-2008 18:48 Post subject: Re: Unitrol 80K Question |
[quote:f4fa202e37=\"philyumpshus\"]I was going to put this in my old post, but the edit isn't working...
The 80K automatically compensates for hot or ground horn ring trigger. Try touching the horn ring lead to hot again while it's in the first position..it should switch back.
cajunblitz |
| Back to top URL |
EVModules Contributing Silver Member
Joined: 20 Aug 2005 Posts: 1631 Location: San Gabriel Valley, Ca
Posted: Fri 7-Nov-2008 00:33 Post subject: |
I'm guessing that you touched positive to the white \"manual\" wire? If so, the siren will go to the second tone for 8 seconds then revert back to the original tone automatically. Remember, the manual wire needs to touch either positive or negative only momentarily.
Sean |
| Back to top URL |
Posted: Fri 7-Nov-2008 15:16 Post subject: |
| I already did what cajun said, and it didn't help. I will have to try waiting the 8 seconds, although the manual said the override is 5 seconds and I think I've had it on longer than both of those suspenses. Thanks for the help though. We'll have to see what happens... |
| Back to top URL |
Posted: Fri 7-Nov-2008 15:26 Post subject: Re: |
| [quote:3cb827f42a=\"philyumpshus\"]I already did what cajun said, and it didn't help. I will have to try waiting the 8 seconds, although the manual said the override is 5 seconds and I think I've had it on longer than both of those suspenses. Thanks for the help though. We'll have to see what happens... |
Hmm, try unplugging the unit from power and ground for a couple seconds then plug it back in and try again. Sometimes that will do the trick as well.
cajunblitz |
| Back to top URL |
Posted: Sat 8-Nov-2008 21:06 Post subject: |
I was playing around with it and I happened to move to amp. After that, I started getting some cool Powertone-like tones, and that's when I realized that the plug between the harness and the amp was loose. Thanks for the help everyone. It works fine now.  |
| Back to top URL |
