| Author |
Message |
Klein36 Frequent Poster
Joined: 18 Jan 2008 Posts: 1065 Location: Harris Co, TX
Posted: Thu 6-Nov-2008 14:23 Post subject: speaker noise |
the video pretty much explains what the problem is. it has not done this before. the only change i have made is radio rebroadcast through the UTMD. but i don't see a relationship between that and my slimlighter. it happens with only the LEDs (not lightbar or HAWs) and with the radio rebroadcast on and off. doesn't matter. ideas?
| Back to top URL |
futurecop Regular
Joined: 27 Nov 2007 Posts: 182 Location: Waukesha Co, Wisconsin
Posted: Thu 6-Nov-2008 23:43 Post subject: |
| Ive heard the same thing on several vehicles, including my own |
| Back to top URL |
rwo978 Turbo Poster
Joined: 06 Sep 2005 Posts: 2466 Location: West Fargo, ND
Posted: Sat 8-Nov-2008 09:30 Post subject: |
| My 80K used to make wierd noises when just turned on (standby) with nothing else on (no lights). Must be a Unitrol thing. |
| Back to top URL |
dshannon Regular
Joined: 25 Mar 2008 Posts: 66 Location: Edinburg, Ohio
Posted: Sat 8-Nov-2008 15:55 Post subject: |
| could this be alternator noise? I get it through my FM radio because of where I ran my wiring for my subwoofers, right next to my antenna. Just something to think about. If this is the case the noise would increase in speed with your engine speed. |
| Back to top URL |
Posted: Sun 9-Nov-2008 21:41 Post subject: Re: |
| [quote:68e7d2d01d=\"dshannon\"]could this be alternator noise? I get it through my FM radio because of where I ran my wiring for my subwoofers, right next to my antenna. Just something to think about. If this is the case the noise would increase in speed with your engine speed. |
i don't see how it can be the alternator when the engine was off during the video. it happens when the engine is on and off. thanks for the idea, though. never thought of it. |
| Back to top URL |
ka8ypy Regular
Joined: 13 Mar 2006 Posts: 494 Location: College Park, MD
Posted: Sun 9-Nov-2008 23:40 Post subject: |
Since the only change is the connection of radio rebroadcast, is the radio on as well as the UTMD when the sound happens? If so, then the radio is picking up the RF hash from the slimlighters and it is heard on the speakers (Speaker wires from radio to utmd may be acting as an antenna). If you can, put a choke (ferrite bead) on the wires from the radio to the UTMD and see if that helps any.
I had the same issue with my slimlighters and TIR3s in my truck until I put a choke on the speaker wires.
Dan
Slick Top Solutions |
| Back to top URL |
Posted: Mon 10-Nov-2008 00:21 Post subject: |
well in the video you can see the radio is on (orange display) and the LEDs are on (back lit is on by ignition only but constant power to the UTMD). i always have the radio on so I have never tried it without the radio on. the RRB is always switched off even when the noise occurs. I will try tomorrow with the radio off. I am also still unaware of the device you were describing, ferrite bead. thanks for the help  |
| Back to top URL |
ka8ypy Regular
Posted: Mon 10-Nov-2008 10:39 Post subject: |
Check it with the radio off and we will go from there.
Dan
| Back to top URL |
Posted: Mon 10-Nov-2008 14:09 Post subject: |
still did it with radio off  |
| Back to top URL |
ka8ypy Regular
Posted: Mon 10-Nov-2008 16:14 Post subject: |
| If it's not too much of a pain in the azz, disconnect the wiring from the radio to the UTMD at the radio side and see if it goes away. |
| Back to top URL |
Posted: Mon 10-Nov-2008 16:41 Post subject: |
| so disable radio rebroadcast? its a plug on the UTMD so i can just unplug it and try it? i'd like to keep the feature on cause i do use it when on some scenes. my main concern is it being a fire hazard, if it is one. it doesnt bother me that it makes the sound because it can only be heard when my ear is within inches of the speaker but i just want to make sure it isn't some crazy fire hazard. All my wiring is good and safe, fused, blah blah blah but still...kinda odd. |
| Back to top URL |
ka8ypy Regular
Posted: Mon 10-Nov-2008 23:13 Post subject: |
Nope, not a fire hazard, just an annoyance. If you can live with it leave it. If it bothers you and you want to find it, unplug the rebroadcast from the UTMD and see if you still have it at your internal radio speaker. If so, the radio is picking up the rf hash from the lights.
Dan
| Back to top URL |
Posted: Mon 10-Nov-2008 23:30 Post subject: |
hrm. ok. ill check it out further. thanks for all the help  |
| Back to top URL |
EVModules Contributing Silver Member
Joined: 20 Aug 2005 Posts: 1631 Location: San Gabriel Valley, Ca
Posted: Wed 12-Nov-2008 03:43 Post subject: |
Seems like you have a ground loop issue. Check to see if all the components in questions have the same power and ground points. Usually if there are two seperate ground sources, it would produce noises commonly called \"ground loops\".
Give it a try & report.
Sean |
| Back to top URL |
