| Author |
Message |
dshannon Regular
Joined: 25 Mar 2008 Posts: 66 Location: Edinburg, Ohio
Posted: Thu 6-Nov-2008 20:31 Post subject: Edge 9000 help |
So I've got an edge 9000 I want to add a halogen flasher to. Its a 48\" 8 strobe, TD, alley. There are a pair of halogen reflectors in the rear that have wiring but no bulbs, so I put bulbs in and they didn't work. Lo and behold when I dig in to the wiring, there are 2 wires running from one light to the other, hooked to nothing else! &*$? What I'm asking is what is the easiest way to add a flasher? I also was hoping I could get my TD's to flash as well, and maybe a piercer unit.
Sorry for the novel, any help is appreciated! |
| Back to top URL |
JDH Regular
Joined: 27 Aug 2005 Posts: 427 Location: Maitland, Fl.
Posted: Fri 7-Nov-2008 06:42 Post subject: |
From my experience with Edge bars, is they always have extra wires in the harness for this reason. It is relatively easy to add flashers to the rear and flashing TD�s. You would need 2 flasher boards. The basic whelen flasher circuit is cheap and will flash four lamps, and/or steady burn 4 lamps. The piecer can be added the same way.
You may want to place an ad for what you want on the Wanted list�.or you can check %$^&bay. |
| Back to top URL |
