eLightbars Home
Make a contribution
question on linear strobes for edge9000
Author Message
THEGOLDPRO
Regular
Regular
PostPosted: Sat 8-Nov-2008 17:01    Post subject: question on linear strobes for edge9000 Reply with quote
question is i just got this bar and it has all linear strobe tubes in it, something like 14 strobes now 3 of the strobes are burned out, do i need to replace the entire assembly with the bulb and reflector or what... the tubes them selves dont look like they come out.
[img]http://www.plowsite.com/picture.php?albumid=98&pictureid=869[/img]
this is the end strobe thats blown
[img]http://www.plowsite.com/picture.php?albumid=98&pictureid=870[/img]
better pic of the end tube
[IMG]http://www.plowsite.com/picture.php?albumid=98&pictureid=867[/IMG]
Back to top    URL
THEGOLDPRO
Regular
Regular
PostPosted: Sat 8-Nov-2008 21:08    Post subject: Reply with quote
bump anyoone?
Back to top    URL
ffjwhite
Contributing Gold Member
PostPosted: Sat 8-Nov-2008 22:43    Post subject: Re: Reply with quote
[quote:16b14f2318=\"THEGOLDPRO\"]bump anyoone?
Post bumping is not allowed here on the forum. Depending on what kind of Edge bar you have yu can either change the whole housing or just the bulb. Even tho you say its an Edge 9000, they used I think 3 different kind of strobe assemblies with these. Best way to tell is to look at the strobe tubes and see if they are held in by a bracket or if they have a peice of metal coming off of them and going into the housing. If they are the brackets then you can change just the bulb. Also none of your pictures work.
Back to top    URL
Pimpala03
Moderator
Moderator
PostPosted: Sun 9-Nov-2008 05:50    Post subject: Reply with quote
You might want to try some patience as you only posted the message about 3 hours before you got impatient. Read this thread for instructions on the proper way to post images.
Back to top    URL
THEGOLDPRO
Regular
Regular
PostPosted: Tue 11-Nov-2008 22:28    Post subject: Reply with quote
yeah they are the bulbs with the metal comingout the end and going inside the housing so im assuming i need to change the whole assembly.
Back to top    URL
ukr
Contributing Member
PostPosted: Wed 12-Nov-2008 02:32    Post subject: Reply with quote
if it looks like this, or similar
you have to change the whole lighthead
Back to top    URL
THEGOLDPRO
Regular
Regular
PostPosted: Sat 15-Nov-2008 21:18    Post subject: Reply with quote
those are pretty much what they look like.
Back to top    URL
K9cop18
Regular
Regular
PostPosted: Sun 16-Nov-2008 19:50    Post subject: Reply with quote
Since we cant get our bean-counters to buy the CORRECT replacement strobes for our whelen bars, what I have done for some of our guys is to remove the blown strobe tube (break it out) then drill a 1\" hole in the center of the housing that will accept a standard HAW strobe bulb (which we always have tons of used ones)
Works great - way better than no bulb at all!
Back to top    URL
C.B.L. International
Regular
Regular
PostPosted: Mon 17-Nov-2008 17:34    Post subject: Reply with quote
K9cop18 Have you ever thought about trying Hide Away Leds in them?
Back to top    URL
K9cop18
Regular
Regular
PostPosted: Mon 17-Nov-2008 20:04    Post subject: Reply with quote
Oh yeah...thought about it...BUT, I havent got my hands on any that I could use to try it out. I did try a set of those el-cheapo imported hideaway leds in the second set of takedowns on my Freedom bar, but they sucked.
Back to top    URL
THEGOLDPRO
Regular
Regular
PostPosted: Tue 25-Nov-2008 17:40    Post subject: Reply with quote
thanks k9cop great idea!!!!
Back to top    URL
Display posts from previous:
Page 1 of 1
