eLightbars Home
Make a contribution
Strobe Cable to cig plug
Author Message
kinnelonfire75
Suspended user
PostPosted: Sun 9-Nov-2008 16:19    Post subject: Strobe Cable to cig plug Reply with quote
I recieved a whelen micro grille-master from ENG17INE here on the boards. It can with a strobe cable. What should I do if I want to wire this to a cig plug and have it on the dash (I have a 2 channel flasher and a cig plug). I need wiring help from strobe cable (R/W/Black wires) to flasher. I know how to get from the flasher to the plug.
Back to top    URL
Andy L.
Moderator
Moderator
PostPosted: Sun 9-Nov-2008 16:21    Post subject: Re: Strobe Cable to cig plug Reply with quote
[quote:f634103946=\"kinnelonfire75\"]I recieved a whelen micro grille-master from ENG17INE here on the boards. It can with a strobe cable. What should I do if I want to wire this to a cig plug and have it on the dash (I have a 2 channel flasher and a cig plug). I need wiring help from strobe cable (R/W/Black wires) to flasher. I know how to get from the flasher to the plug.
What type of lighthead is it? Strobe, Halogen, LED?
Back to top    URL
Pimpala03
Moderator
Moderator
PostPosted: Sun 9-Nov-2008 16:26    Post subject: Reply with quote
I think you just plug it into a strobe power supply. In other words, it's a remote strobe.
Back to top    URL
kinnelonfire75
Suspended user
PostPosted: Sun 9-Nov-2008 16:58    Post subject: Reply with quote
Edit is not working for me and i made a typing error: I recieved a whelen micro grille-master from ENG17INE here on the boards. It came with a strobe cable. What should I do if I want to wire this to a cig plug and have it on the dash (I have a 2 channel flasher and a cig plug). I need wiring help from strobe cable (R/W/Black wires) to flasher. I know how to get from the flasher to the plug.
The sentence in red was messed up originally.
To elaborate: out of the back of the unit comes a strobe cable. it is a strobe lighthead. serial number SAE J 595 I want to be able to stick it into my cig plug and put it on the dash, if possible.
Therefore I do not want a remote unit (power supply) although I have considered it an option.
Thats my latest project
Back to top    URL
ffjwhite
Contributing Gold Member
PostPosted: Sun 9-Nov-2008 17:10    Post subject: Reply with quote
If it is a strobe light head and it doesnt have a built in Power supply then you will not be able to use the light. You need a power supply. A 2 Channel flasher will not work. Nothing will work unless it is a Strobe Power supply
Back to top    URL
Andy L.
Moderator
Moderator
PostPosted: Sun 9-Nov-2008 17:19    Post subject: Reply with quote
You could use a small 2 outlet power supply and wire that with a cig plug and then just attach the strobe head to the PS. But as already stated - the lighthead will be useless without a strobe power supply.
Back to top    URL
kinnelonfire75
Suspended user
PostPosted: Sun 9-Nov-2008 17:40    Post subject: Reply with quote
alright thnx
Back to top    URL
kinnelonfire75
Suspended user
PostPosted: Sun 9-Nov-2008 18:34    Post subject: Reply with quote
Alright I have redone the parameters for this project so this info can stay for other people but otherwise the thread can be locked.
Back to top    URL
hawkspringsfire
Contributing Member
PostPosted: Sun 9-Nov-2008 21:09    Post subject: Reply with quote
Is it possible to run power from a cig plug to a strobe PS?
Back to top    URL
grfd711
Moderator
Moderator
PostPosted: Sun 9-Nov-2008 21:18    Post subject: Re: Reply with quote
[quote:eed1c5c87d=\"hawkspringsfire\"]Is it possible to run power from a cig plug to a strobe PS?
Would imagine it would be possible to do that. Would depend on how much amps the cigar recepticle in the vehicle could hold and how much the power supply is gonna require. Back to top    URL
SnuffJ25
Regular
Regular
PostPosted: Mon 10-Nov-2008 07:48    Post subject: Re: Reply with quote
[quote:11ddae7c3f=\"hawkspringsfire\"]Is it possible to run power from a cig plug to a strobe PS?
Of course, how do you think self contained strobes do it?
Back to top    URL
Display posts from previous:
Page 1 of 1
