| Forum options: |
| Author | Message | ||||||
| DaveCN5 Contributing Member Joined: 13 Jan 2007 Posts: 4240 Location: Fairfield County, CT |
| tekguy Regular ![]() Joined: 04 Jan 2008 Posts: 153 Location: los angeles california |
the charge guard has low voltage shut down, low voltage override that gives you 15 extra minutes of power after low voltage shutdown by pressing a button. it automatically senses the rise in voltage when you turn on the ignition and viseversa to start time out (no ignition wire needed). you could hook up a relay at the power imput wire but it probably isnt nessessary ( application specific ?) It is not waterproof but it should be mounted inside the cab anyway. Im sure you could put the unit in a pelican case or similar h2o proof box and mount it extermally though. $70 +/- = not bad or dead battery= stranded and pissed off |
| All times are GMT - 6 Hours |
