| Author |
Message |
Firetom830 Member
Posted: Tue 11-Nov-2008 09:47 Post subject: Is it the siren, or the speaker? |
I have a Fed Sig MS4000 compact siren with a dynamax speaker. The other day it cut out half way to the station. If I listen closely, I can barely hear the siren through the speaker. So...is it the siren or the speaker? |
| Back to top URL |
rescue_oz Frequent Poster
Joined: 21 Aug 2005 Posts: 1706 Location: Sydney Australia
Posted: Tue 11-Nov-2008 13:42 Post subject: |
| Yes, without testing with a known good speaker (the next logical step) it could be either but more likely the siren. |
| Back to top URL |
Lightguy Member
Posted: Tue 11-Nov-2008 14:42 Post subject: |
| Make sure you are hearing the faint noise through the speaker. It could be coming from the siren box When the speaker goes, sometimes you can still hear the siren tones faintly from the siren box itself. It just has no amplification b/c the speaker is blown. Or, the speaker wire may have come loose, or pulled out. Check the speaker wires through the firewall as well. May have melted if not properly routed. |
| Back to top URL |
Firetom830 Member
Posted: Tue 11-Nov-2008 21:29 Post subject: |
Ok, my next step was to try and borrow a speaker to narrow it down. I'm sure that I heard it through the speaker, and I'm 99%(1% left for murphy) sure it's not a wiring issue(I am after all an electrician ). I just wasn't sure if it could be narrowed down to the speaker because I could still hear faint siren sounds through it. |
| Back to top URL |
Posted: Wed 12-Nov-2008 01:25 Post subject: |
| Easiest way is to try the speaker first just replacing the current speaker and if there is no difference try at the output of the siren box, that will give you a conclusive result. |
| Back to top URL |
