eLightbars Home
Make a contribution
Backflash Flasher Help
Author Message
Credicon
Regular
Regular
PostPosted: Wed 12-Nov-2008 10:12    Post subject: Backflash Flasher Help Reply with quote
I have an install I am doing that requires the following.
When the flasher is turned on, it starts producing back flash (brake lights & reverse lights alternating), but when the brakes are applied the flasher switches to alternating reverse lights, and then when the brakes are let off it reverts back to back flash, does anyone make a flasher like this or will I have to just wire up 2 flashers and a relay to switch between the two. I would prefer a solid state flasher because I think the relays clicking on and off every time they hit the breaks will drive them crazy...
Thanks,
Credicon
Back to top    URL
Credicon
Regular
Regular
PostPosted: Wed 12-Nov-2008 15:10    Post subject: Reply with quote
no one has any ideas?
Back to top    URL
cajunblitz
Professional Upfitter
PostPosted: Thu 13-Nov-2008 07:39    Post subject: Reply with quote
I tried all night to reply, but the board wasn't cooperating. Most flashbacks are built to function as you describe. Here's a link to the SoundOff solid state model.
http://www.soundoffsignal.com/warnamber/flashers/Taillight/ETFBSSN-P.htm
cajunblitz
Back to top    URL
Andy L.
Moderator
Moderator
PostPosted: Thu 13-Nov-2008 10:50    Post subject: Re: Reply with quote
[quote:9f7ecf35d0=\"cajunblitz\"]I tried all night to reply, but the board wasn't cooperating. Most flashbacks are built to function as you describe. Here's a link to the SoundOff solid state model.
cajunblitz
But he wants the reverse lamps to alternate when the brakes are active - I haven't seen a flasher that will do that yet.
Back to top    URL
cajunblitz
PostPosted: Thu 13-Nov-2008 13:49    Post subject: Re: Reply with quote
[quote:24424f05ed=\"Andy L.\"][quote:24424f05ed=\"cajunblitz\"]I tried all night to reply, but the board wasn't cooperating. Most flashbacks are built to function as you describe. Here's a link to the SoundOff solid state model.
cajunblitz
Oops! I re-read what he wanted and yes you're right Andy....the reverse lamps will continue to just flash together when the brake is applied, not alternate between each other. No flasher that I know of either will alternate the reverse. Something could be built with the standard flashback, an additional flasher and a pair of relays to produce the required results, but it's not worth it IMHO.
cajunblitz
Back to top    URL
Display posts from previous:
Page 1 of 1
