| Author |
Message |
CTARES Regular
Joined: 23 Jan 2008 Posts: 54 Location: New Haven, CT
Posted: Thu 13-Nov-2008 09:24 Post subject: Help with Installing 4 TIR6s in Grille of 07+ Expedition |
I have 4 TIR6s, flanges, and 4 Crown Vic Grille mounting brackets (as suggested by dealer) to mount in the grille of the 07+ Expedition. Has anyone done so? Seems modification to the bracket is required? I would like to put two in the upper part and two in the lower part (3 openings in this grille, center left open)
If someone has done this, and I've seen a cple on here, could you give some professional advice? |
| Back to top URL |
nickdejohn Regular
Joined: 28 Nov 2006 Posts: 65 Location: Middletown, CT
Posted: Sat 6-Dec-2008 15:54 Post subject: |
| I actually have a 2007 Expedition and I have 4 LIN6's in the grille. The way I installed mine was I purchased the Surface Mount Bracket from Whelen (5LSMAB). I got 4 of them. I mounted them to the opening in the grille, top and bottom with a small nut and bolt. I then installed the lighthead and screwed the plastic flange surrounding to the surface mount adapter. If you want to give me your email address, I will send you some pics of my grille to show you what I did. It looks nice. |
| Back to top URL |
