eLightbars Home
Make a contribution
turning a jetsonic into a mini?
Author Message
Skippy
PostPosted: Mon 17-Nov-2008 14:42    Post subject: turning a jetsonic into a mini? Reply with quote
hi All,
Tried to do a search, but it timed out (Could not obtain matched posts list)
... Has anyone turned a full size jetsonic into a mini (or two)?
It looks like i would just need an end piece and a retaining clip, right?
Back to top    URL
JeffFireRadio
PostPosted: Tue 18-Nov-2008 10:19    Post subject: Reply with quote
Just a thought...would it turn out better if you used a Jetstream bulkhead and trimmed two full sized domes down into mini left-right halves, meeting in the middle at the bulkhead? Goodness, it wouldn't take much to improved on Federal's cheesy mini solution of an endcap and a strap. You might be on to something good, and better than factory! Smile You will have to tap threads into the aluminum base for dome screws either way you go. Good luck with the project. It actually sounds like fun.
Back to top    URL
OTFD122
Frequent Poster
PostPosted: Tue 18-Nov-2008 16:08    Post subject: Reply with quote
Charger Lighting ought to chime in here... I know he has made Mini MX7000s, and cut down Vectors into minis.
Back to top    URL
Skippy
PostPosted: Thu 20-Nov-2008 09:37    Post subject: Re: Reply with quote
[quote:b97bac2e82=\"JeffFireRadio\"]Just a thought...would it turn out better if you used a Jetstream bulkhead and trimmed two full sized domes down into mini left-right halves, meeting in the middle at the bulkhead? Goodness, it wouldn't take much to improved on Federal's cheesy mini solution of an endcap and a strap. You might be on to something good, and better than factory! Smile You will have to tap threads into the aluminum base for dome screws either way you go. Good luck with the project. It actually sounds like fun.
I like this idea better. We found two of the jetsonics stuck in storage - they need some help (the lenses have seen better days) but i thought it would be a fun project to tinker with in my \"spare\" time.
Back to top    URL
strobar
Regular
Regular
PostPosted: Wed 3-Dec-2008 01:37    Post subject: minijet Reply with quote
Yes, you can
I had a half broken jetstream (come from a car crash), I cut the aluminium frame and bought one end cap (#Z8552286A) and the retaining band (#Z8552B237A), a few time to wiring, and now I have a like new mini bar Exclamation Cool No wasting time
Back to top    URL
strobar
Regular
Regular
PostPosted: Tue 9-Dec-2008 10:27    Post subject: Re: minijet Reply with quote
Arrow
Back to top    URL
Display posts from previous:
Page 1 of 1
