| Author |
Message |
FFDsmokeeater Regular
Joined: 11 Apr 2006 Posts: 713 Location: Home: Franklin, New York & School: University of Maryland College Park, MD Summer: Syracuse, NY
| Back to top URL |
brewmeister Frequent Poster
Posted: Tue 18-Nov-2008 09:42 Post subject: |
Dash roll with spreaders= more efficient and saves time?
It also doesn't look like a very safe position the fireman is in.
My $0.01 |
| Back to top URL |
kiwibagpiper Regular
Joined: 08 Mar 2007 Posts: 184 Location: Monmouth County, New Jersey
Posted: Tue 18-Nov-2008 10:42 Post subject: |
Definitely never seen that one before We either use the spreaders as brewmeister suggested or do a chain pull, the chain gets wrapped around the steering column, run over a stack of cribbing on the hood and is then attached to the undercarriage at the front of the vehicle and then you just start winching. I personally have never seen or heard of the technique that you displayed in this picture, but it definitely doesn't look very safe. |
| Back to top URL |
Posted: Tue 18-Nov-2008 10:53 Post subject: |
| I agree with both of you brewmeister and kiwibagpiper. I am more prone to do a dash roll. When I first saw this pic, I noticed how the base of the jack could easily become upstable and kick out. Either hitting the patient or firefighter with great force. I would not recommend this technique to anyone. Ironicly, this picture was taken at a extrication training class. |
| Back to top URL |
Mick (firewolf) Contributing Member
Joined: 27 Aug 2005 Posts: 3725 Location: Grand Rapids area, Michigan, US of A
Posted: Tue 18-Nov-2008 10:55 Post subject: |
| we generally use the hydrauliuc ram, spreaders, or spreaders with chains, depending on the overall circumstances, not sure this particular method looks like a good idea. But then again, I've learned never to say never . . . the fire service thrives on innovations to handle new and different situations, you never know . . . |
| Back to top URL |
dynastar666 Turbo Poster
Joined: 24 Mar 2007 Posts: 2347 Location: Ithaca, NY and Burlington, VT
Posted: Tue 18-Nov-2008 11:13 Post subject: Re: |
| [quote:7f99c6377d=\"FFDsmokeeater\"]I agree with both of you brewmeister and kiwibagpiper. I am more prone to do a dash roll. When I first saw this pic, I noticed how the base of the jack could easily become upstable and kick out. Either hitting the patient or firefighter with great force. I would not recommend this technique to anyone. Ironicly, this picture was taken at a extrication training class. |
That is the first thing I thought when I looked at the pic. We always use a ram to roll the dash and if we are in a pinch we might use the spreaders. |
| Back to top URL |
Posted: Tue 18-Nov-2008 11:39 Post subject: Re: |
| [quote:fc51f0943c=\"Mick (firewolf)\"]the fire service thrives on innovations to handle new and different situations, you never know . . . |
\"Tradition unimpeded by progress...\"
| Back to top URL |
C420sailor Regular
Joined: 10 Dec 2007 Posts: 438 Location: Naval Air Station Pensacola, FL
Posted: Tue 18-Nov-2008 11:46 Post subject: |
What ever happened to using the tilt lever on the steering column?
That looks dangerous as hell. Lift the dash. |
| Back to top URL |
Posted: Tue 18-Nov-2008 11:52 Post subject: Re: |
| [quote:694ba8fda4=\"brewmeister\"][quote:694ba8fda4=\"Mick (firewolf)\"]the fire service thrives on innovations to handle new and different situations, you never know . . . |
| Back to top URL |
wduda92 Contributing Member
Joined: 22 Dec 2005 Posts: 387 Location: Binghamton NY
Posted: Tue 18-Nov-2008 11:57 Post subject: |
It definitely looks like the forces are working against each other. The jack being pulled down and the column pulled up  |
| Back to top URL |
Posted: Tue 18-Nov-2008 11:59 Post subject: Re: |
[quote:51e8833956=\"wduda92\"]It definitely looks like the forces are working against each other. The jack being pulled down and the column pulled up  |
yeah, I wondered about that, too. It almost seems like the fact that the jack is ON the dash would defeat attempts to pull the dash up . . .  |
| Back to top URL |
Posted: Tue 18-Nov-2008 13:56 Post subject: Re: |
[quote:61e488e7b0=\"wduda92\"]It definitely looks like the forces are working against each other. The jack being pulled down and the column pulled up  |
I also agree about the forces. I'm not saying I know everything, but I'm in the process of earning a fire protection engineering degree. I have taken my share of engineering and physics classes to understand that the physics behind what these guys are doing is not safe.
I think they are supplying the \"I am superman\" attitude that we all encounter at one point or another. |
| Back to top URL |
Brandon W Regular
Joined: 28 Aug 2005 Posts: 459 Location: Lawrenceburg, Kentucky
Posted: Tue 18-Nov-2008 15:36 Post subject: extrication pic |
| To me, I feel the same as everyone else. Make your relife cuts and use either the spreaders or a ram. I prefer the ram because you dont tie up your spreaders if you need to use them for another task during the operation and you get more spread out of most rams. I also do not use the chain pull around the steering wheel anymore either. It has been brought out that by wrapping the chain around the steering wheel of newer cars, can be more dangerous as well. Its due to the universal knuckle in the steering column. I have used the chain wrapped around the base of the entire dash and used with a comealong. Im not a winch fan, although its a very good source of easy force, i prefer to have a bit more control over the action taking place, but thats just me. |
| Back to top URL |
LFD-Mike Frequent Poster
Joined: 20 Aug 2005 Posts: 1898 Location: Metro Milwaukee, WI
Posted: Tue 18-Nov-2008 15:50 Post subject: |
I would rather roll the dash also.
I don't care for standing on the cowl, and a high lift jack can cause serious injuries if your hand slips off the handle at an inoppurtune time, such as falling off the cowl of a car |
| Back to top URL |
philyumpshus Regular
Posted: Tue 18-Nov-2008 15:56 Post subject: |
| At our extrication training, they said to not cut the column because sometimes the steering wheel jumps out and hits the patient. It seems the pulling on it like that could do the same thing. It would be an uncontrolled break. |
| Back to top URL |
OTFD122 Frequent Poster
Joined: 04 Dec 2005 Posts: 1855 Location: Rochester, MI
Posted: Tue 18-Nov-2008 16:04 Post subject: |
| That's a new one for me... We usually use our mini-cutters to cut the steering wheel, or do a roll using rams and a wedge. |
| Back to top URL |
Field79 Regular
Joined: 22 Jan 2007 Posts: 331 Location: Doylestown, PA
Posted: Tue 9-Dec-2008 15:30 Post subject: |
| kiwibagpiper wrote: |
We are taught to use both. Never know when it will come in handy. As for the picture, it may not look safe, but you dont know what they had to work with. Was the class only hand tools and they didnt have a comealong? Sometimes instructors take away pieces and make you think outside the box, so I cant really comment on this. If you have spreaders and comealongs, then i wouldnt do this, but we cant tell given this is a single picture.
Long story short is if it worked for you in a given situation and no one was hurt, then you were successful. This doesnt look to safe, but if it worked. Yay.
Matt |
| Back to top URL |
kinnelonfire75 Suspended user
Joined: 09 Mar 2008 Posts: 681 Location: Kinnelon, NJ (Morris County)
Posted: Tue 9-Dec-2008 16:57 Post subject: |
| we are told to leave the steering wheel and to just place a cover over it. (dont remember name of cover) |
| Back to top URL |
battalion_18 Regular
Joined: 18 Jul 2007 Posts: 357 Location: Forreston, Illinois
Posted: Tue 9-Dec-2008 17:33 Post subject: |
| doesn't look safe to me, would just prefer to do the dash roll from the underside of the dash, and how would it work with a good head-on collision having the whole front end of the car smashed up to the driver compartment, that changes everything then as far as being to lift the dash from the method shown in the pic.. won't see me trying it.. |
| Back to top URL |
Phillyrube Contributing Member
Posted: Tue 9-Dec-2008 19:09 Post subject: |
Most agencies now have redundant hydraulic systems, so if one of your pumps goes down, or a ram craps out, you have a backup. Now, regress to 1968, when I got my start. We had no Hurst Amkus tools. I learned to pull a steering column with a hand powered Porta-power, and also using a come-along. Slow and tedious, but they worked. Now, can you do this with a bottle jack? Sure can......
When I taught extrication I had the class taking roofs off using hand tools, and removing doors and tunnelling through the floor using an air chisel. You never knew when your power tools would crash.
We've come very far, but the basic student still needs to know how to use mechanical advantage. This particular technique? Something to play with, but I don't think I would try it with a patient sitting there. |
| Back to top URL |
pondfly Contributing Member
Joined: 28 Dec 2007 Posts: 317 Location: Unincorperated Wood Dale, IL
Posted: Tue 9-Dec-2008 23:06 Post subject: |
Nearly everyone has said that they would use some kind of hydraulic tool. While I agree with that decision, My current department didn't have a tool until I purchased an old tool myself last year.
I started my career with tools few, extremely heavy and slow. You learned to think out of the box and use other means. And that included the use of a Hi-Lift jack, but the placement there is definitely unsafe.
One day at the table, sit down with some of your more experienced members and discuss what you can use if you had a catastrophic failure and had to revert to alternative methods. Sometimes the back to basics is a nice refresher. Don't get me wrong, I love having a tool and I'm hoping for the feds to give us some money and we can get something that isn't 20 years old. |
| Back to top URL |
Posted: Wed 10-Dec-2008 07:53 Post subject: |
Very true, Pondfly. At the last class I took, We managed to take a roof off with a handsaw.
Tiring, but it does show that it can be done.
There's a saying that the difference between a Pro and a Beginner is that the Pro's do the basics better!!! |
| Back to top URL |
Posted: Wed 10-Dec-2008 15:25 Post subject: |
| OTFD122 wrote: |
You can get the spokes and rim of the wheel, but i think he is refering to cutting the column. Most of them have a hardened tool steel core, and then you also have airbag wiring that could get cut, too. Definitely a no-no! |
| Back to top URL |
DaveCN5 Contributing Member
Joined: 13 Jan 2007 Posts: 4240 Location: Fairfield County, CT
Posted: Wed 10-Dec-2008 19:02 Post subject: |
| While I agree with the rest of you on this being a slightly unsafe technique, I could see the reasons why it would be taught at an extrication class. Say a car goes off an embankment where you can't get the spreaders or a ram to. This could probably be a viable, but last resort technique. I doubt this was taught as a first resort method. |
| Back to top URL |
