| Author |
Message |
Phil T. Suspended user
Joined: 27 Aug 2005 Posts: 1547 Location: Northwest Indiana
Posted: Thu 14-Aug-2008 16:19 Post subject: power lines |
| is there anyway to check if a wire down is live? Or is there anyway to tell if its a power line or cable or phone? |
| Back to top URL |
Parkpiggy Contributing Member
Posted: Thu 14-Aug-2008 16:36 Post subject: |
Probies?
J/K |
| Back to top URL |
Ben E. Contributing Member
Joined: 29 Aug 2005 Posts: 3529 Location: Tama county, IA
Posted: Thu 14-Aug-2008 16:38 Post subject: |
| Hotstick |
| Back to top URL |
David B. Frequent Poster
Joined: 14 Sep 2005 Posts: 1883 Location: Rochester N.Y.
Posted: Thu 14-Aug-2008 16:42 Post subject: Re: |
+1
Also if it's arcing that's generaly a good clue.
David B. |
| Back to top URL |
ems60 Regular
Posted: Thu 14-Aug-2008 17:51 Post subject: |
| All lines are live until the power company gets there and says their not. |
| Back to top URL |
Station 3 Regular
Joined: 21 Dec 2007 Posts: 950 Location: Lower Rio Grande Valley Area,TX
Do me a favor and please dont do anything just wait for your local electricity company to get on scene. You dont want to die for no reason just wait for them to get there and do thier job. Every year our local power company puts on a little show where they fry a hot dog wiener with like a gazzilian volts just to prove a point that firefighters arnt electricians and for them not to get close to the power lines when at a scene.  |
| Back to top URL |
usdemt Regular
Joined: 07 Mar 2008 Posts: 870 Location: Britton/Vermillion SD
Posted: Thu 14-Aug-2008 18:31 Post subject: |
Warning hijack in progress!
We have in very limited instances pulled the meter off of a house that has a working fire we are putting water on. In all intances it was a general electrcian that pulled the meter. The only reason it was done was because we have one power guy in our area to do it, and besides crappy cell service he could be 20 minutes away on a daily basis. Evertime we get chewed out but I would rather have a guy who knew what he was doing pull the meter without permission than be on the nozzle while you hit a 220 outlet, or the box itself. Any deptartments out there do that in emrgency situations? |
| Back to top URL |
Jasonc Regular
Joined: 16 Feb 2007 Posts: 216 Location: Outer Banks, NC
Posted: Thu 14-Aug-2008 19:24 Post subject: Re: |
| ems60 wrote: |
+100. Even phone and CATV wires (the thick black ones) have been known to become energized if a power line falls across them (due the the fact the are supported by a bare wire themselves). Also, safety systems don't always work. But for the most part, fighting a structure fire without pulling the meter is usually fine. 120VAC (its only 240VAC line to line) isn't much of a problem when fighting a fire, and normally doesn't present a nominal hazard until overhaul.
Remember the old saying: "Firemen don't mess with wires, and linemen don't mess with their fires"
Here's a cool video: http://www.youtube.com/watch?v=KM1snQAh8a0 |
| Back to top URL |
Posted: Thu 14-Aug-2008 19:54 Post subject: Re: |
| Jasonc wrote: |
| ems60 wrote: |
but cops mess with everything cuz they are god  |
| Back to top URL |
Posted: Thu 14-Aug-2008 19:59 Post subject: Re: |
good idea I forgot about those, now the hard part is getting the money for it |
| Back to top URL |
bobcoop06 Regular
Posted: Thu 14-Aug-2008 20:05 Post subject: Re: |
| Phil T. wrote: |
I'd be willing to bet that if you talked to your local power company(s) that they would be willing to help defray the cost of outfitting your department with an AC Hotstick, if not totally pay for it.  |
| Back to top URL |
Posted: Thu 14-Aug-2008 20:06 Post subject: Re: |
| bobcoop06 wrote: |
| Phil T. wrote: |
Couldnt hurt to ask Thanks |
| Back to top URL |
mfaith91 Contributing Member
Joined: 08 Mar 2007 Posts: 1885 Location: Brandenburg, KY
Posted: Thu 14-Aug-2008 21:48 Post subject: |
Uhm..... I'm going to put my Helmet on for just a second.....
Just send in the Cop-O-Meter....
| Back to top URL |
Posted: Thu 14-Aug-2008 22:09 Post subject: Re: |
| mfaith91 wrote: |
your the coolest cop i know  |
| Back to top URL |
Posted: Thu 14-Aug-2008 23:28 Post subject: |
| I would be willing to bet, if I was a betting man, that the power company probably WOULD help you with the costs of a Hotstick. When I was a high-voltage electrical technician, we used them exclusively to verify our shutdowns on busses after lockout/tagouts. Never once had a mishap. |
| Back to top URL |
car54 Regular
Posted: Fri 15-Aug-2008 09:03 Post subject: Re: |
| Ben E. wrote: |
OR NOT, they are not likley to give you a hotstick for the same reason you would not give someone a nozzle and say here point that at the hot stuff and help out! LIABILITY - even if your "trained" and you do it wrong quess who is to blame? |
| Back to top URL |
Robert W. Regular
Joined: 27 May 2008 Posts: 713 Location: Hartford, CT
Posted: Fri 15-Aug-2008 10:12 Post subject: |
Love the hotsticks.. we have 2... but..
Always assume a down line is live, even if you are convinced it is for communications purposes. If you are on a fireground and see a down lined, just take the time to find a way around that. Otherwise, get your hot stick, but remember it is electronic too and it needs to have power, so it could give false readings as well. |
| Back to top URL |
ems60 Regular
Posted: Fri 15-Aug-2008 10:17 Post subject: |
| Maybe the cable guys can jump in here, but I recall seeing that some of the cable lines can carry 80-90 volts and the fiber optic lines can cause eye damage if you look in the end. Just stay away from the wires, you never know. |
| Back to top URL |
Posted: Fri 15-Aug-2008 10:21 Post subject: Re: |
| ems60 wrote: |
Yes... Telephony typically can carry 85-100 volts, depending on location.... in these parts anway.... It's 'nuff to put you on your ars... I thought that earlier but wasn't going to threadjack- but since it was broughtup yes you are absolutely correct!
Mike |
| Back to top URL |
Posted: Fri 15-Aug-2008 10:28 Post subject: Re: |
| car54 wrote: |
| Ben E. wrote: |
I didn't say they would give you a hotstick. I said they would help you with the costs... There's a difference in giving away equipment that requires training and donating money. |
| Back to top URL |
ems60 Regular
Posted: Fri 15-Aug-2008 10:33 Post subject: |
| I wasn't thread jacking, he asked how to tell if they were power, cable or phone. I was just saying just because they aren't lines from the electric company, doesn't mean they don't have power in them. Some people assume that because they aren't electric means they are safe to touch. |
| Back to top URL |
Posted: Fri 15-Aug-2008 11:30 Post subject: |
well the main reason why I ask is because when we had a storm roll through we had most our rigs tied up on a wires down calls, and the wait for the elec company was hours. Obviously we cant tie up all our rigs for hours on babysitting a wire laying across the road. The one I was on one of our ff is a electrician, and determined it was a phone wire, so he picked it up and moved it off the road . We were able to leave once the road was cleared. |
| Back to top URL |
Mike F Contributing Member
Joined: 19 Aug 2005 Posts: 994 Location: Buffalo Grove, IL
Posted: Fri 15-Aug-2008 14:02 Post subject: Re: |
| ems60 wrote: |
+1000000000000000000000 |
| Back to top URL |
stfd717 Regular
Posted: Fri 15-Aug-2008 14:47 Post subject: |
Depending on the utility company will tell you how far you can go. Our FD had one donated by electric co - I think they also gave us a price break on another when we purchased for our other engine. Of course we have a very good rep with our electric comapny. The gas company is in the process of completing a Nat Gas prop field on our training ground for multi-agency training (FD, Gas co, local fire brigade) with no cost to FD or FB because they helped fund and build the site - we are getting a $100k field for about 20k). The Gas Co also donated some grass helmets and goggles for the work put into the field. A few years ago they also donated some CO detectors - They have been great! The better you work with them the more you "might get."
The worst that can happen when you ask is they can tell you "no" - but i'll bet they will not do that if you ask nicely.
C. |
| Back to top URL |
EVS1 Regular
Joined: 25 Dec 2005 Posts: 939 Location: West Virginia
Posted: Fri 15-Aug-2008 22:19 Post subject: |
The problem with hotsticks and power lines is that a power line that checks "dead" now, can come back on without you knowing it. The power distribution systems have fuses on the poles, but they also have automatic reset breakers in the substations. They also can shunt power from another part of the system,(another direction) which will re-energize the wires without you knowing it. Hotsticks are fine in industrial applications where the system is tightly controlled, but they have no business on a firetruck.
The best thing to do is barricade the wires and stay away from them. Let the power company do their job and we'll do ours. |
| Back to top URL |
