eLightbars Home
Make a contribution
Rotator Amps?
Author Message
Installs08
Regular
Regular
PostPosted: Sat 16-Aug-2008 17:06    Post subject: Rotator Amps? Reply with quote
Tried the search function but could not find anything...
I have a 2 rotator 55Watt mini bar I just added a cord to. Someone told me that it was too many amps for a cigar lighter. Im thinking the rotators are probably like 3-4 amps max and it should not be a problem off a lighter cord? Any thoughts?? Thanks in advance..
Back to top    URL
Pimpala03
Moderator
Moderator
PostPosted: Sat 16-Aug-2008 17:15    Post subject: Reply with quote
You are much better off hard wiring it.
Search for "melted plug". You should get some good threads.
Back to top    URL
Pat H.
PostPosted: Sat 16-Aug-2008 17:16    Post subject: Re: Rotator Amps? Reply with quote
Your Code 3 420 & LP6100; and the Federal Highlighter all have two 55 watt bulbs as standard and a cigarette plug. Your 55 watt bulbs are rated around 4.3 amps each. "Someone" doesn't know what he is talking about; otherwise Code and Federal would not offer them with lighter plugs.
Back to top    URL
Installs08
Regular
Regular
PostPosted: Sat 16-Aug-2008 17:23    Post subject: Reply with quote
It is a highlighter which I bought as a perm mount and added a cord to move it from one vehicle to another as needed. I'm going to keep it on there because if the manufacturer adds a cord, I guess it will work.
Back to top    URL
Richard P
Regular
Regular
PostPosted: Sat 16-Aug-2008 18:26    Post subject: Reply with quote
I bought some good wires for my 55 watt turbobeam, it runs 8 amps, cigar plug handles it well. it get warm, but not hot. I also have a star minibar with 2 50 watts, same plug, it got sligtly warm. these were over 1 hour periods continuous. get a plug with a flat positive cap, rounded ones are horrible for contact and heat up badly
Back to top    URL
FireEMSPolice
Frequent Poster
PostPosted: Sat 16-Aug-2008 19:04    Post subject: Reply with quote
My work has a bunch of Code 3 LP6105 mini-bars. All have 2 rotators. All have cigar plugs. To date, ALL that have been used have had the plugs melt. The unused ones will remain unused. Everytime they melt within warranty, Code 3 just keeps sending more to us so they can melt.
Back to top    URL
Richard P
Regular
Regular
PostPosted: Sat 16-Aug-2008 19:09    Post subject: Reply with quote
I beefed mine up with a heavier guage plug, its a lighter plug extension, flat tip, no current i, everything flows nicely
Back to top    URL
MikeyGoebel
Regular
Regular
PostPosted: Sat 16-Aug-2008 19:17    Post subject: Reply with quote
Not to hijack the thread, but when I was like 13 I decided to hook a cigar plug up to a CB radio. Let's just say it didn't work out to well for the CB Radio, the plug, or the car. It melted the plug, fried the CB, and the cigar plug never worked again. I didn't get much better after that. I had no idea how to hook it correctly, so I put the power and ground wire on a new CB into the two spaces on the fuse block, and put a fuse in behind it to hold it in place. I know this don't have anything to do with the actual thread, I just thought it was provide some insight on what happens.
Back to top    URL
rwo978
Turbo Poster
PostPosted: Sat 16-Aug-2008 21:50    Post subject: Re: Reply with quote
The design for the Code 3 plug is horrible. I've replaced all the ends on the minis my vollie group owns. Melts on the inside causing the wires to arch, blowing fuses constantly. Wish they would design something new. Rolling Eyes
Back to top    URL
Mick (firewolf)
Contributing Member
PostPosted: Sat 16-Aug-2008 21:56    Post subject: Reply with quote
I've had both good and bad luck with cig plugs and mini bars. My recc, if you're going to add one, make sure it's decent gauge wire and a good heavy plug, just to be safe. With just two rotators, you should be good, but better safe than sorry, is my opinion . . .
Back to top    URL
LFD-Mike
Frequent Poster
PostPosted: Sun 17-Aug-2008 12:22    Post subject: Reply with quote
A 2 rotator mini-bar is only going to use ~10 amps. This itself is not a problem for the cigarette lighter; which is usually fused at 30A, but an accessory port may be another thing.
Most problems are due to cheap components, such as crappy plugs.
Back to top    URL
NPS Ranger
Contributing Member
PostPosted: Sun 17-Aug-2008 15:48    Post subject: Reply with quote
It all depends on your actual lighter socket, and plug, and how good the contact is between one and the other. As Pat said the actual amperage is around 8.6. If you had a gold plated lighter socket and gold plated plug contacts and the planets were all in alignment, it should run fine. If your lighter socket is corroded or the contacts are oxidized, it will produce resistance. Resistance produces heat. Heat melts plugs. A brand new factory wired plug stuck into the socket in a brand new car probably won't be a problem. A 10 year old Highlighter that has sat on the floor all its life with a crudded up plug, jammed into the socket on a 1978 F150 that has already lit 30,000 coffin nails, is likely to get very very hot. I have run factory minibars from Fed Sig and Ecco with factory wired plugs, and they all got at least warm. A much better idea is to get some sort of quick-connect mating plug such as a 4 way flat trailer plug, and wire one leg permanently into the vehicle.
Back to top    URL
Installs08
Regular
Regular
PostPosted: Sun 17-Aug-2008 20:54    Post subject: Reply with quote
That sounds like a decent idea. I might just hardwire the bar to a trailer connector, then have another connector on the roof. When I'm ready to use the bar. Stick it on there, and connect the connectors
Back to top    URL
NPS Ranger
Contributing Member
PostPosted: Sun 17-Aug-2008 21:56    Post subject: Reply with quote
I was actually imagining the connector under the dash, and you run the wire in like any other throw light. That would keep the connector free of snow and ice.
Back to top    URL
PaLightFreak
Frequent Poster
PostPosted: Mon 18-Aug-2008 08:16    Post subject: Reply with quote
I'll second Pat H on this....
A question that nobody has asked but only seem to be focused on the "cig-plug" in which that other person's comment could have been justified by is....whats the size of wire did you add to it when you "added a cord to" that person who said it was too many amps might have felt that along with small size of wire the cig-plug wont work. so i will ask, what size/gauge wire did you use?
Back to top    URL
rescue_oz
Frequent Poster
PostPosted: Mon 18-Aug-2008 15:59    Post subject: Reply with quote
When I've had customers ask the best way to run these style of lights I usually install an Anderson plug (rated at 50A) at the base of the B pillar and replace the lighter plug with a matching connector. Leds in lighter sockets are OK but anything with a rotator needs a better connection than the manufacturers are willing to supply.
Back to top    URL
Display posts from previous:
Page 1 of 1
