Results 1 to 15 of 15
Like Tree3Likes
  • 1 Post By jprleedy4680
  • 1 Post By Travelin Man
  • 1 Post By Zack
Thread: Ambulance rear lighting
  1. #1
    Author of This Thread
    JCLG316 is offline
    Joined September 2010
    Reading, Pa
    We have converted an ambulance into a traffic unit and when we are stopped in a lane with are rear doors open people say they don't always see us because two of the lights are blocked by the doors and the other two show through the windows of the doors and they are dim that way. So I was looking add two sets of lights behind each door rearward facing inbetween the cossion and the rear doors I have maybe an inch and a half of space. Not sure if I should go with TIR or LIN any suggestions. I don't want it to set to low so I don't bash my head on it.
  2. #2
    Volunteer Fire/EMT
    Law Enforcement
    jprleedy4680 is online now
    Joined January 2011
    USA Michigan
    Why not put some right on the inside of the doors themselves? Switch them so they will come on when the doors are open. No headache risk!
    parr555 likes this.
  3. #3
    Professional Upfitter
    OVERKILL is offline
    Joined January 2012
    hamilton ontario canada
    might be better to add something on the inner skin of the door with a magnetic switch too activate when open
  4. #4
    Veteran
    Hobbyist
    Collector
    HILO is online now
    Joined May 2010
    Dallas Texas
    What type ambulance? There should be plenty of room above the doors on any type.
    __________________________________________________ _______
    I've been through the desert on a horse with a dash laser on it's head.
  5. #5
    Fire Fighter
    Travelin Man is offline
    Joined July 2010
    Central Virginia
    Quote Originally Posted by jprleedy4680 View Post
    Exactly what we have at work. 700-series red LED's mounted to each entry door (rear and side) on a switch to activate when the door is opened.
    MESDA6 likes this.
  6. #6
    JCLG316 is offline
    Reading, Pa
    how would i hook up the lights to a magnet switch? and could i tap into the power that turns on the scene lights when the rear doors are open before the switch is to a momentary switch to turn them off from blinding traffic.
  7. #7
    Junior Member
    chiefolson is offline
    Joined July 2010
    Raleigh, NC
    The only problem with the lights mounted to the interior sides of such doors are that they will continually flash in your eyes when working in that area. We've lined the inner door panels with stainless and striped them with scotchlite for visibilty. I'd recommend that you install something vertically along the outside edge of the rear (along the extrusion) or above the doorline. I'd also look at upgrading the lights that shine through the rear windows to Super-LED, rather than 5mm equipped lights. They are far more visible through the glass, even with tinting.
  8. #8
    Volunteer Fire/EMT
    Law Enforcement
    Joined January 2011
    USA Michigan
    Shouldn't if they were switched properly...lots of ambulances in my area have them on the inside and activated by the door motion.
  9. #9
    WS224 is offline
    Joined November 2010
    2010 most dangerous City.
    Quote Originally Posted by chiefolson View Post
    Funny thing, when your working outside the vehicle all the outside lights stay on as well. It's amazing how hard people make things.
  10. #10
    Law Enforcement
    Paramedic
    Fire Fighter
    Zack is online now
    Joined May 2010
    Western MA
    I did the same thing... although I also kept the lights mounted on the inside of the doors.
  11. #11
    Volunteer Fire/EMT
    Law Enforcement
    Hobbyist
    ryan81986 is online now
    Joined April 2011
    Boston, MA
    Wow thats..... a lot of striping.
  12. #12
    Law Enforcement
    Paramedic
    Fire Fighter
    Zack is online now
    Joined May 2010
    Western MA
    Quote Originally Posted by ryan81986 View Post
    Safety first.
    If they discovered that hot pink would make me safer on the side of the road or highway, I'd change our uniforms.
    Doug likes this.
  13. #13
    Senior Member
    Shawn L is offline
    Joined May 2010
    Corbett, Oregon
    here is a non lighting suggestion..... how about a pair of door closers installed to shut the doors?
  14. #14
    Law Enforcement
    Paramedic
    Fire Fighter
    Zack is online now
    Joined May 2010
    Western MA
    Quote Originally Posted by Shawn L View Post
    When would they be programmed to operate? Just as I'm loading an stretcher into the back?
    I think the real question is: Why is it so difficult to get EMTs to close the doors when they walk away from the truck?!
  15. #15
    Senior Member
    Shawn L is offline
    Joined May 2010
    Corbett, Oregon
    I was referring to a standard commercial ( building application) , where when you go in and out it closes, if you want the door "propped" open you have to kinda over center it to get it to stay open like this:
    Shop TELL MANUFACTURING, INC. Commercial Grade 1 Door Closer Adjustable 3 - 6 at Lowes.com
Posting Permissions
  • You may not post replies
  • You may not edit your posts
