Results 1 to 16 of 16
  1. #1
    Author of This Thread
    Junior Member
    mls60442 is offline
    Joined July 2010
    Joliet, IL
    Chicago PD Whelen Edges
    Does anyone know the exact configuration of the Chicago PD Whelen Edges. I know the lens configuration and functions of the lights. I am looking for the lens lengths or a close approximation. What Whelen Edge parts were inside. And was it an EB6 power supply? I know there were four strobes to the front. It has been too long since I have seen one to remember if it was just 2 or 4 strobes to the rear. Any help is appreciated. I have a 9000 frame that I would like to just convert to a CPD-style Edge.
    I found some on Craigslist a few years ago. The guy had 5 for $500 or $125 each. When I called him for one, he changed his mind and wouldn't sell them individually, only as a group. He even offered all 5 for $400. If I only had the $400 at the time. Oh well.
  2. #2
    Senior Member
    Law Enforcement
    Volunteer Fire Fighter
    Collector
    50theman is offline
    Joined February 2011
    Virginia
    Quote Originally Posted by mls60442 View Post
    He is probably trying to recoup his money. see link here http://elightbars.org/f16/links-deal...tml#post263611
    I think the bars were set up like this.
    Front: strobe-takedown-strobe{black center}strobe-takedown-strobe
    Rear: strobe-red brake light-{black center}-red brake light-strobe
    5-0
  3. #3
    Veteran
    Fire/Paramedic
    Communications
    Professional Upfitter
    Respondcode3 is online now
    Joined May 2010
    Northen Il USA
    CPD bars are 4 strobe in the front 2 in the rear the only halogen were the takedowns and alleys the rear brakes were incandescent bulbs
  4. #4
    jdh
    Senior Member
    Collector
    jdh is offline
    Joined May 2010
    Maitland, Fl.
    Quote Originally Posted by Respondcode3 View Post
    I always thought they were 4 strobe, 1 in each corner, takedowns, front flashers, rear flashers and STT.
  5. #5
    Senior Member
    Clarence H is offline
    Joined May 2010
    USA Twin Cities Minnesota
    Chicago Whelen bars
    Looks like Ranger services got them.
    Clarence
    Quote Originally Posted by 50theman View Post
    Front: strobe-takedown-flasher{black center}flasher-takedown-strobe
    Rear: strobe-red brake light-strobe{black center}strobe-red brake light-strobe
  6. #6
    ny04350 is offline
    Joined August 2010
    Hudson Valley, NY
    Restored Caprice with an actual Chicago bar...
    Attached Images Attached Images
  7. #7
    Senior Member
    Law Enforcement
    Fire Fighter
    Communications
    zacmtz7 is offline
    Joined May 2010
    Atlanta, GA
    Just watch "The Fugitive" they got CPD cars all over the place in it.
  8. #8
    Veteran
    Fire/Paramedic
    Communications
    Joined May 2010
    Northen Il USA
    Quote Originally Posted by ny04350 View Post
    Owned by an authentic CPD officer too.
  9. #9
    Senior Member
    Law Enforcement
    Collector
    50theman is offline
    Virginia
    You can clearly see that the bar has 4 strobes to the front at 00:22.
    So which is it?
    5-0
  10. #10
    obviously by the time they went to the newer edges with linear strobes inboard... there were 4 front strobes...
    I believe I have seen both....
    Public Surplus: Auction #697244
  11. #11
    Veteran
    Fire/Paramedic
    Communications
    Joined May 2010
    Northen Il USA
    CPD bars had no flashing halogen. The bars are Strobe,TD Strobe, Black, Strobe TD.Strobe on the front Rear is Strobe, Brake,nothing, Black,Nothing Brake, strobe. The cars are very low key They only other lights when the strobe bars were used was a Headlight flasher.
  12. #12
    Veteran
    Snow Removal
    Hobbyist
    Collector
    7d9_z28 is offline
    Joined March 2012
    Michigan
    Is this one? Been listen on CL for quite a while
    Whelen Strobe Lightbar
    Hes got a newer ad listing it for less also
  13. #13
    Senior Member
    Law Enforcement
    Collector
    50theman is offline
    Virginia
    Ok,
    My bad, I read your post bass ackwards, sorry.
    Your right.
    Take care,
    5-0
  14. #14
    Junior Member
    mls60442 is offline
    Joined July 2010
    Joliet, IL
    Quote Originally Posted by 7d9_z28 View Post
    Yeah, that's one. Maybe I can grab that and save the trouble.
  15. #15
    Junior Member
    mls60442 is offline
    Joined July 2010
    Joliet, IL
    Thanks for all of the replies. Yeah, I knew there were four strobes to the front, just wasn't sure about the rear. I believed it was only two, but haven't seen one lit up from the rear in quite some time. I did not know the stop lights were incandescent either, so that helped.
    The Edges and Jetstrobes are disappearing from service, so I figured it was time to add a CPD-spec Edge to the collection alongside the Illinois State Police-spec MX7000 and New Orleans PD-spec Vector.
  16. #16
    Moderator
    shues is offline
    Joined May 2010
    NW Indiana
    That guy is plain crazy. I've called him a dozen times over the last few years, trying to buy something or another. Every time I call him, all he wants to do is rant about something. It's about impossible to get a word in edgewise.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Back to top
