Results 1 to 11 of 11
  1. #1
    Author of This Thread
    Junior Member
    BryanB is online now
    Joined July 2010
    Central NJ
    Connect two mini phantoms?
    I'm planning to use two of the new mini phantoms in my cars windshield. I wanted to know if it's possible to connect them both into one of the cigar plugs to preserve the ability to switch patterns on the go.
  2. #2
    Veteran
    Jared @ 911Lights is offline
    Joined May 2010
    Pittsburgh, PA
    Quote Originally Posted by BryanB View Post
    Yes, if you have the Mini-Phantom with the pattern selector switch on the cig plug you can do that, because there are three wires inside the cable. However keep in mind that they will not sync because there is no sync function on the Mini-Phantom.
    Also, I would suggest cutting the plugs off both lights a few inches from the plug and splicing the three sets of three wires each together with butt splices. Trying to take apart the cig plug is only going to land you with a broken cig plug.
    -Jared
    Jared Ross
    911Lights.com
    888-4-LED-LIGHTS
    Like us on Facebook for Special Discounts
    If we sell it, its made in America!
    Holding purchasing contracts for: Pennsylvania, Minnesota, New Jersey and parts of OH, TX, LA & MI.
  3. #3
    Junior Member
    Joined July 2010
    Central NJ
    Ok that sounds good. I just wanted to be able to have them on the same pattern and switch at the same time. Unsynched will make it look interesting.
  4. #4
    Newbie
    Jeff A is offline
    Joined October 2011
    USA - Illinois
    You can sync certain new mini phantoms
    Quote Originally Posted by Jared @ 911Lights View Post
    -Jared
    You can synchronize the new mini phantom ulb9s-1's. If you have not purchased the lights yet you may want to consider this model mini phantom. I have orders two for my trucks headliner. Check out their product sheet.
    Model ULB9S Mini-Phantom Undercover LED Light - Star Headlight & Lantern Company - Amber Products
  5. #5
    Veteran
    Joined May 2010
    Pittsburgh, PA
    The sync version of the Mini-Phantom (ULB9-1) has been around for years, however it only has 3 flash pattern which doesn't make it very appealing to most people. If you haven't purchased your lights yet I would highly suggest the STARBURST Mini-Phantom, and if syncing and a wide variety of patterns is important the VersaStar Series Dash Lights:
    911Lights.com - SVP STARBURST Mini Phantom
    911Lights.com - VersaStar LED Dual Dash Light
    911Lights.com - VersaStar LED Single Dash Light
    Quote Originally Posted by Jeff A View Post
    Jared Ross
    911Lights.com
    888-4-LED-LIGHTS
  6. #6
    Newbie
    Jeff A is offline
    Joined October 2011
    USA - Illinois
    Jared - I spoke with a sales rep from Star and she said the new starburst mini phantom ulb9s-1 will have all 35 flash patterns and can be synced. The ulb9s can not be synced. The two light kit that can be syncedand that only offers 6 flash patterns is the RLKULB9S. I am not disagreeing with your posts, im just letting you know what the rep said about the new ulb9s-1's. She also said they come with a 15 ft 4 wire harness. I should be getting my order next week and will confirm the actual number of patterns.
  7. #7
    Veteran
    Joined May 2010
    Pittsburgh, PA
    Jeff, the S on the end is just the STARBURST LEDs, the ULB9, ULB9-1 and RLKULB9-1 have been around for at least 5-6 years, I'm very familiar with all three of them. I can tell you for sure that the ULB9-1 and the RLKULB9-1 (really just two of the ULB9-1s) both only have 3 flash patterns (they say six on the RLKULB9-1 because you have two phases). All three are now available with the STARBURST LEDs, however I've only personally played with the ULB9S. From my understanding from engineering before they went into production, the ULB9S-1 and RLKULB9S-1 are using the same flashers as the ULB9-1 and RLKULB9-1 which is the same flasher as the DL15-6W-1K, the manual on the site also shows the 3 patterns for the ULB9S-1 Star ULB9 Series Manual - Star Headlight & Lantern Company, Avon, NY
    Seems like you were told something different, I hope you are right, it would be great to have the sync option on the 35 patterns.
    -Jared
    Jared Ross
    911Lights.com
    888-4-LED-LIGHTS
  8. #8
    Junior Member
    Joined July 2010
    Central NJ
    Would the mounting options be the same as getting the normal window mount ones?
  9. #9
    Newbie
    Jeff A is offline
    Joined October 2011
    USA - Illinois
    -Jared
    Jared - you are right. My GSA rep didn't seem confident in her response to my question. I ordered one RR and one bb. Would you happen to have seen a video for the three available flash patterns? I was optimistic. I hope the three flash patterns are at least decent. I tried to find them on the web with no luck. Thanks
  10. #10
    Veteran
    Joined May 2010
    Pittsburgh, PA
    I just checked, I thought I might have a video of the DL-15 two-headed-dragon, but I don't. I don't care for them, but the random is the best of the bunch.
    -Jared
    Jared Ross
    911Lights.com
    888-4-LED-LIGHTS
  11. #11
    Veteran
    Joined May 2010
    Pittsburgh, PA
    Yep, the ULB9-1 & ULB9S-1 have the suction cup, bail/deck bracket, and the rear-view mirror clamp mount. The two-headed-dragon (RLKULB9-1/RLKULB9S-1) only has the bail/deck mount.
    -Jared
    Jared Ross
    911Lights.com
    888-4-LED-LIGHTS
Posting Permissions
  • You may not post replies
  • You may not edit your posts
