Results 1 to 9 of 9
Thread: SE8BBBB
  1. #1
    Author of This Thread
    Newbie
    Sffd24 is offline
    Joined July 2012
    USA new york
    SE8BBBB
    Hello all, my ? is can you add more light heads to a SE8BBBB? any help would be great
  2. #2
    Guru
    Fire/Paramedic
    Vintage Collector
    Retired
    Hoser is online now
    Joined June 2010
    Ohio
    You might want to explain your question a little better. IE; what light and model number, be more specific.
  3. #3
    Newbie
    Sffd24 is offline
    Joined July 2012
    USA new york
    SE8BBBB
    It would be a whelen liberty light bar model SE8BBBB
  4. #4
    Veteran
    Communications
    Volunteer Fire/EMT
    Vintage Collector
    Zapp Brannigan is online now
    Joined May 2010
    41.696104, -73.888356
    Slightly confused... If I understand the morsels correctly, this is am Economy bar (the E in the model number). Not sure if that means you have economy heads (depopulated) or just economy corners. By "adding more heads" do you mean heads with more LEDs, or more 500 Series modules? It depends on how many modules you have in it already?
    The Search Function Is Your Friend
    Full-Time Buff
    Captain, FFII/EMT-B
  5. #5
    Volunteer Fire/EMT
    First Responder
    Dealer
    Tiller245 is online now
    Joined June 2012
    Chester County,PA
    my guess is that you have an economy style whelen liberty light bar and if that is the case then yes and no...you can add light heads if there is room but i don't know how you would wire them to the bored...
    T.Bell
    Firefighter/EMT/lights and sirens novice
    I am a wackier don't hate
    Stat Emergency Equipment
    Tyler Bell
    Owner/CEO
    Tiller245@Gmail.com
    PM and email is the best way to reach me at times
  6. #6
    Volunteer Fire/EMT
    First Responder
    Dealer
    Joined June 2012
    Chester County,PA
    Quote Originally Posted by Zapp Brannigan View Post
    i figured out that he has some type of whelen liberty module because the "s" is the first letter for a liberty designation I.E whelen.com
    T.Bell
    Tyler Bell
    Owner/CEO
    Tiller245@Gmail.com
  7. #7
    Senior Member
    Volunteer Fire Fighter
    Hobbyist
    spc2315 is offline
    Joined March 2011
    Connecticut
    You should be able to. On my SX8BBBB (which is also forsale) I removed the takedowns and added in a set of lin6. There is usually a open outlet on the harness for "aux" which I plugged mine into and it is now full led. If your looking to add more I have one depop 500 series in blue that i have forsale.
    "I'm not a cop but my car is!"
  8. #8
    Junior Member
    philter74 is online now
    Joined May 2010
    Nyack, NY
    Quote Originally Posted by Sffd24 View Post
    Yes, you can fully load an SE8 lightbar.
    Inside a SE8BBBB Lightbar are two ULF22 LED flashers, one for front, one for rear. There are two outputs on each flasher - orange and brown. The harness has daisy chained plugs from each flasher that run across the lightbar. So if you looked at the rear of your lightbar from the top, your driver rear corner would be an orange output, the lighthead next to it brown, and so on down the line. Does that make sense?
  9. #9
    Senior Member
    Communications
    Professional Upfitter
    twodogs603 is offline
    Joined September 2011
    Norfolk,VA
    Quote Originally Posted by philter74 View Post
    This is correct. I just put a new harness in the same bar. If I remember right it will hold up to 14 lightheads. The one I was working on had 2 unused plugs coming off the flasher.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Back to top
