Results 1 to 10 of 10
  1. #1
    Author of This Thread
    Junior Member
    Volunteer Fire/EMT
    Newton15 is offline
    Joined October 2010
    Michigan, USA
    Soundoff Mini Pinnacle versus 911EP Millennium
    Im thinking of upgrading my roof light on my 1999 GMC Yukon, I am debating between the mini pinnacle or a full size millennium. The millennium is used on Craigslist for a decent price or I would buy a pinnacle new. I am looking for the pros and cons of each light, any help or input is greatly appreciated.
  2. #2
    Veteran
    Snow Removal
    Hobbyist
    Collector
    7d9_z28 is offline
    Joined March 2012
    Michigan
    Looking at the $300 one in Kentwood?
    The Pinnacle is your best bet. Millenniums aren't bright at all, Im betting the mini Pinnacle is brighter than a fullsize Millennium. The Pinnacle will be more reliable too. Millenniums are outdated 0.5w technology, and have a rather high failure rate: the boards inside corrode, the seals on the modules leak, modules dim and die, CID fails cause the light to half work... They are my favorite LED bar, I have 3 of them, but for primary warning, you wont want it. I only have one on a vehicle, its all amber for plowing snow. I don't run emergency calls or anything, so its bright enough for me. But I wouldn't expect traffic to move for it.
    That said, Millenniums are awesome lightbars! Here is a link to My truck and Millennium: 2001 Chevy 2500hd CCSB with Millennium (Millennium Discussion)
    Also, for what its worth, I have never paid more than $250 shipped for a Millennium - For $300+ you might as well get a used Whelen Liberty or Patriot, or the like. Good luck with the decision!
    WARNING: I receive and read through Galls catalogs. Therefore, I am an expert in emergency services equipment.
  3. #3
    Junior Member
    Volunteer Fire/EMT
    Newton15 is offline
    Joined October 2010
    Michigan, USA
    Quote Originally Posted by 7d9_z28 View Post
    Yes I was looking at the one in Kentwood, Thanks for the input, I wasnt too familar with that brand or style of lightbar. Im now thinking the pinnacle is my best bet. I dont want to get something outdated that may cause me problems down the road.
  4. #4
    Veteran
    Snow Removal
    Hobbyist
    Collector
    7d9_z28 is offline
    Joined March 2012
    Michigan
    Like I said, they are cool bars, 911ep had great patterns available. But the Millennium was the FIRST LED lightbar out there, they were around from about 99,00 to 2005 IIRC. It was replaced with the Galaxy, which was even more prone to failure. Everything else 911ep made is pretty decent.
    You will be happy with the mini Pinnacle, My dad ran one on his 99 Yukon Denali, it was a bright little sucker! Plus, if you are buying one new, you have a warranty!
    Had you ever contacted the owner of the Millennium? I tried a couple times with no response.
    IF you do Decide on the Millennium, I have found a couple good sources for parts through ELB (actually the reason I joined the site was to buy a Millennium, ended up buying two!)
  5. #5
    Junior Member
    Volunteer Fire/EMT
    Newton15 is offline
    Joined October 2010
    Michigan, USA
    No I have not attempted to contact him, I was going to wait until I decided on which one I wanted. I think im going to go with the mini pinnacle. Thanks for all you input.
  6. #6
    Veteran
    NPS Ranger is offline
    Joined May 2010
    Penn's Woods
  7. #7
    Professional Upfitter
    Dealer
    Fire/Paramedic
    FireMedic129 is offline
    Joined July 2011
    Kentucky
    I have sold and installed dozens of the mini pinnacle. I have not had anybody be unhappy with the light output.
    A.L.S. Emergency Lighting
    Check Out Our New Code-11 Lighting Products Click Here
    Master Distributor for Sound Off Signal
    Dealer for Feniex,Whelen,SVP,Federal Signal,Axixtech,Havis,Setina and many more!!
    Sales@alsemergencylighting.com
    http://www.alsemergencylighting.com
  8. #8
    Veteran
    Communications
    Volunteer Fire/EMT
    Vintage Collector
    Zapp Brannigan is offline
    Joined May 2010
    41.696104, -73.888356
    Link to the Millennium on CL?
    The Search Function Is Your Friend
    Full-Time Buff
    Captain, FFII/EMT-B
  9. #9
    Veteran
    Snow Removal
    Hobbyist
    Collector
    7d9_z28 is offline
    Joined March 2012
    Michigan
    Quote Originally Posted by Zapp Brannigan View Post
    Ill FB it to you. Its about 45 minutes from me
  10. #10
    tmtrev is offline
    Joined May 2010
    Aston, Pa
    I have a R/B millennium for sale if someone needs one. Tom
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Back to top
