Page 1 of 2 12 LastLast
Results 1 to 30 of 39
Like Tree3Likes
Thread: Soundoff select-a-pattern HLF
  1. #1
    Author of This Thread
    Senior Member
    Volunteer Fire Fighter
    dcfrmp255 is offline
    Joined November 2010
    South Georgia
    http://www.soundoffsignal.com/warnam.../ETHFSS-SP.pdf
    So, let me get this straight. I only cut the positive wire on the drivers side high beam light and connect the yellow wire to the wire going to the light and connect the blue wire to the other end of the positive wire that I just cut? So, I don't cut anything on the passenger side?
    Garrett Wooten
    gdwooten@gmail.com
  2. #2
    Senior Member
    First Responder
    Hobbyist
    fireman658 is online now
    Joined June 2012
    Missouri
    Quote Originally Posted by dcfrmp255 View Post
    Correct. Your headlights are both ran off of 1 wire for highbeam and 1 for low beam. It was on my Crown Vic anyway. They come into the drivers side and jump to the passenger side.
  3. #3
    Senior Member
    South Georgia
    Quote Originally Posted by fireman658 View Post
    No, my high beams and low beams have separate wires. I have an 02 Chevy Silverado...
    Garrett Wooten
    gdwooten@gmail.com
  4. #4
    Volunteer Fire/EMT
    First Responder
    Communications
    pingfung is offline
    Joined April 2011
    valencia, venezuela
    follow this tips and don't cut you wire... "No-Splice" HLF
  5. #5
    Senior Member
    South Georgia
    Quote Originally Posted by pingfung View Post
    That is how my current HLF is installed, I just need to know where to connect the wires...
    Garrett Wooten
    gdwooten@gmail.com
  6. #6
    Senior Member
    Communications
    Professional Upfitter
    twodogs603 is online now
    Joined September 2011
    Norfolk,VA
    Make sure your headlights are not ground switched. I know they are on my 2003 Sierra. At least I think they are. Hell I cant remember now.
  7. #7
    Senior Member
    South Georgia
    Quote Originally Posted by twodogs603 View Post
    I tested them earlier today and they are positive switched.
    Garrett Wooten
    gdwooten@gmail.com
  8. #8
    ERM
    ERM is offline
    Joined May 2010
    Omaha, NE
    On a single fuse supply, your vehicle provides power to both headlights through one fuse. What you are doing is severing the right headlight from the left headlight.
    When your high beams are turned on, power flows to the left headlight and down the blue wire and out to the right headlight through the yellow wire. When your flasher is on, power is pulsed to the left and right headlights through the blue and yellow wires respectively. The flasher monitors the blue wire in the off state to see if you turned your high beam switch on in order to turn off the flasher. When the high beams switch is turned off and while the flasher switch is activated, the flasher resumes operation.
    If you connect it to a dual fuse system, follow the same steps, however, when you cut the supply to the right side, that supply will be left alone and taped off.
    This flasher will ONLY work in a positive switched system. Another way you can install this flasher, which is the way I have installed this many times in Chevy positive switched vehicles, is to simply use a fuse tap in the fuse block under the hood. Blue taps onto the output side of the driver's side high beam and yellow taps onto the output side of the passenger's side high beam. In order to make this work though, you must replace the pax side fuse with a blown fuse to prevent backflow. This setup works every time and no wires get cut.
    Let me know if you have any questions.
    Tony
    dcfrmp255 likes this.
    Creators of the first series of programmable flashers.
    http://www.fisos.net/
    http://www.ledguy.net
    The REAL Ledguy!
    Check out our clearance section of new and used lights and sirens. Click here.
  9. #9
    Senior Member
    South Georgia
    Quote Originally Posted by ERM View Post
    Tony
    Ahhhh, Thanks!! This helps a lot!!!! The flasher is supposed to come this Friday, so I will let you know. Thanks everybody for your replies!
    Garrett Wooten
    gdwooten@gmail.com
  10. #10
    Senior Member
    South Georgia
    OMG I've followed the instructions and it is not working!!!! PLEASE, if anybody has installed this flasher on an 2002 Chevy Silverado, PLEASE help me!!! Do I cut the orange wire on the high beams? PLEASE HELP.
    Garrett Wooten
    gdwooten@gmail.com
  11. #11
    Senior Member
    South Georgia
    Tony
    My truck has a fuse for the left headlamps and a fuse for the right headlamps...
    Garrett Wooten
    gdwooten@gmail.com
  12. #12
    Veteran
    Volunteer Fire/EMT
    Law Enforcement
    theroofable is offline
    Joined May 2010
    New Jersey
    Does anything happen? From what I read so far, you made the mistake of cutting the DRIVER side light instead of the PASSENGER light. To verify that you cut the right wire, try turning the high beam on with the wire cut. If you have, the light wont light. Ground the green. Connect yellow and blue to either side of the cut wire. If you do that wrong only one would flash. White to battery, red to switch. All other wires can be cut to a reasonable length and zip tied out of the way. What is the orange wire you are talking about? Im not seeing that in the diagram.
  13. #13
    Senior Member
    South Georgia
    Quote Originally Posted by theroofable View Post
    The orange wire is the OEM positive wire going to my high beams. This is what I did, I cut the orange wire(positive high beams) on the passenger side and connected the yellow wire to the orange wire going directly to the high beam and connected the blue wire to the other end of the orange wire. To get the highbeams to flash, I have to have the headlights turned off, and have the dimmer switch selected to highbeams.
    Garrett Wooten
    gdwooten@gmail.com
  14. #14
    Veteran
    Volunteer Fire/EMT
    Law Enforcement
    Joined May 2010
    New Jersey
    was this unit new or used? Did you check the fuse in the white wire, sounds like the flasher isnt getting the power to flash the lights, requiring the high beams to be on to flash them.
  15. #15
    Senior Member
    South Georgia
    Bought flasher NIB, checked all fuses and connections and they are in working order. Flasher still requires the headlights off and dimmer switch on highbeams...
    Garrett Wooten
    gdwooten@gmail.com
  16. #16
    ERM
    ERM is offline
    Joined May 2010
    Omaha, NE
    How sure are you? SOS says they are ground switched.
    Remove your high beam connector. Using a test probe (looks like an ice pick with a bulb in the handle and a wire coming out the handle), connect the tester wire to a reliable ground and test each pin inside the wire harness you just took off of the bulb. With the headlights switch off, the tester won't light. Turn on the high beams and repeat the test. One of the wires in the harness will light the tester. This is a positive switched system. However, run the test one more time by connecting the tester wire to a positive source. Repeat the above test. Verify the ground is constant with the high beam switch in either the on or off position and that the other wire does not go to ground. Let us know your results.
    Tony
    The REAL Ledguy!
  17. #17
    Senior Member
    South Georgia
    Tony
    This is another reason that I am confused. I am aware that SOS says that they are ground, but I have tested them multiple times using the method that you stated and they are in fact POSITIVE.
    Garrett Wooten
    gdwooten@gmail.com
  18. #18
    Senior Member
    bigcat is offline
    Joined May 2010
    Hartford County, CT
    Edit: It made sense in my head but I flubbed it when I typed it out.
    My 02 Silverado was GROUND switched. I'm pretty sure that is your problem. I know this because I had a trigger wire for fog lights coming off the power wire to the driver's side headlight. If I switched to high beams, my fogs stayed on because that wire was always powered (ground switched).
    If your headlights are positive switched you will have three wires going into the back of the bulb. Two will be positive wires and one will be a ground. The ground will be constant. The low beam wire will be powered when the low beams are on and will shut off when the high beams are activated. The opposite is true as well. The high beam wire will not be powered when the low beams are on and will be when the high beams are activated.
    On a ground switched system (I'm trying to remember my Silverado) there are still three wires going into the back of the bulb but one is positive (constant) and the two others were grounds. The system switches which ground is connected to activate the low/high beam lights. If you turn on your low beams and find one wire being powered, if when you switch to high beams that wire stays powered, you are ground switched. If you have two wires that are powered at different times (one with low beams and one with high beams) that is positive switched.
  19. #19
    Senior Member
    South Georgia
    Quote Originally Posted by bigcat View Post
    My 02 Silverado was GROUND switched. I'm pretty sure that is your problem. I know this because I had a trigger wire for fog lights coming off my low beam wire. If I switched to high beams, my fogs stayed on because the low beam wire was always powered.
    How did you test them? If you put a test light on the high beam wire (with the low beams on) and the test light comes on, they are ground switched. If the test light stays off until you activate high beams, then it is positive switched.
    I'll check them again.
    Garrett Wooten
    gdwooten@gmail.com
  20. #20
    Senior Member
    South Georgia
    Did you have a HLF connected to your headlights? I have removed the select-a-pattern and hooked up my Whelen UHF-2150A and wired it according to the negative switched instructions and it still does not work!
    Garrett Wooten
    gdwooten@gmail.com
  21. #21
    Law Enforcement
    C2Installs is offline
    Joined May 2010
    Tennessee
    According to the SOS flasher chart, your vehicle is a ground-switched system (as has been mentioned above) and the proper high-beam wire will be purple. It further indicates that the flasher you have is not compatible, as it is not listed as a recommended flasher. I suggest you punt and try again. I am unfamiliar with the Whelen flasher you mentioned.
    FWIW, I have installed more SOS HL flashers than I care to count, and I've never had one not work when installed IAW their chart and instructions.
    SoundOff Tech - Technical Service Bulletins
    theroofable likes this.
  22. #22
    Senior Member
    South Georgia
    Looks like I am SOL when comes to having a HLF on my truck. I talked to the folks a Whelen and they said that their UHF-2150A will not work with my truck. I DO have a NEGATIVE switched system which means that the SOS select-a-pattern will not work either. Thanks for all of your help and replies. If you do know of a flasher that will work properly on a 2002 chevy silverado then let me know. Thanks!
    Garrett Wooten
    gdwooten@gmail.com
  23. #23
    ERM
    ERM is offline
    Joined May 2010
    Omaha, NE
    Did you get my PM?
    The REAL Ledguy!
  24. #24
    Senior Member
    South Georgia
    Would it be possible to hook the solid state select-a-pattern to 2 Feniex Titan 200's?
    Garrett Wooten
    gdwooten@gmail.com
  25. #25
    Law Enforcement
    Joined May 2010
    Tennessee
    Why not just buy the correct flasher? SOS offers what you need. Alternately, you could add a couple of relays to make the flasher work with your headlights.
  26. #26
    Senior Member
    South Georgia
    Quote Originally Posted by C2Installs View Post
    Yea, you're right. It would be a PITA to hook up the Titans to the HLF. I have contacted two SOS dealer on the board to give me a quote on the relay select-a-pattern that is supposed to work with my truck.
    Garrett Wooten
    gdwooten@gmail.com
  27. #27
    Senior Member
    South Georgia
    Ok, I bought the SOS ETHF00-SP relay flasher, the chart said that it would work with my truck....I have determined that I have a ground switched system, so I hooked the flasher up according to the ground switched diagram. STILL DOES NOT WORK!!! It does not even make a clicking sound!!! After this weather passes over, I will go back and double check everything. I will be making a call to SOS in the morning...
    Garrett Wooten
    gdwooten@gmail.com
  28. #28
    Law Enforcement
    Joined May 2010
    Tennessee
    Uhh, you're doing it wrong. I'm sure it's something simple, hang in there. One common mistake is not grounding the green wire, instead many mistakenly assume the black is the ground. Not sure why SOS does it that way, but they do. Another common mistake is cutting the circuit on the wrong side.
    Anyway, I'm sure it can be worked out. Are your highbeams working w/out the flasher?
  29. #29
    Senior Member
    South Georgia
    This flasher does not have the green wire for the ground. Yes, the highbeams work without the flasher. The wires are as follows:
    Black=Ground
    White= Fused ground
    Red= Connected to +12v control switch
    Blue= To other end of cut passenger side wire
    Yellow=To passenger side highbeam light
    http://www.soundoffsignal.com/warnam.../ETHF00-SP.pdf
    Garrett Wooten
    gdwooten@gmail.com
  30. #30
    EMT
    nmemergency is offline
    Joined May 2010
    Northern Michigan
    Did you try to turn on the low beams? The instructions say: "Note: Some vehicles may require that the low beam headlights are turned
    ON before the high beam headlights will flash." And SOS does say the headlights must be ON for your vehicle.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Back to top
