February 15th, 2012, 11:11 PM
#1
Author of This Thread
Junior Member
Security
Volunteer Fire Fighter
Communications
Strobesnmore E66 Mounting
Just looking at some suggestions for mounting a strobesnmore E66 Light in the rear of a 2001 crown vic. I'd like to have it on the deck, to seperate it from the lightbar a little bit, but can go headliner too. I've got some ideas, but Im just looking for suggestions that will come out cleaner/easier than what I have in mind so far.
Thanks
Ty
February 16th, 2012, 02:56 AM
#2
I had an E48T/A mounted to the top and an E66 on the bottom. The problem with the E66 on the bottom was the third break light. If you mount if high enough to clear that, then it obstructs your view. I would mount it to the roof.
February 16th, 2012, 02:52 PM
#3
Junior Member
Security
Communications
I think we've got it figured out to mount it to the deck. Im not too worried about view. Thats why I got side mirrors :P
Thanks.
February 20th, 2012, 04:29 PM
#4
Junior Member
Security
Communications
Ended up putting it in the deck. The third brake light does block it a little, but not too bad.
February 24th, 2012, 07:22 PM
#5
Would you be willing to take a pic and post of the install in daylight? 1 looking in from the outside and inside looking out.
Posting Permissions
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Site Rules
