Results 1 to 15 of 15
Like Tree4Likes
  • 2 Post By TritonBoulder47
Thread: Ways to strap on a lightbar?
  1. #1
    Author of This Thread
    Police/EMS
    Professional Upfitter
    Fire Fighter
    joeparv is offline
    Joined June 2012
    US. New Jersey
    Lightbulb Ways to strap on a lightbar?
    i have a code 3 2100 bar and a 2005 cadillac srx for it to go on. have a panoramic sunroof that opens about 1 1/2" high. ive seen that whelen n code3 have roofrack mounts but mite not wsnt it that high or maybe i would, no idea what they look like. also was wondering if i would be able to use the gutter brackets to strap onto the roof rack bars themselves rather than the frame of my car , since my car seems to not have anything for these straps to hold onto according to whelen n code 3. so im pretty much stumped here. any ideas would be great and pics or anything that would help me choose a way to do this would be appreciated . thanks
  2. #2
    Junior Member
    SAR
    Hobbyist
    DDCtech is offline
    Joined February 2012
    Renton, WA
    Anyways I completely sympathize with your problem as I've had to figure it out to. It's hard to build something that looks decent using nuts and bolts from Lowe's, zipties and pipe straps, all of which I have done before. My advice is to see if you can find a mounting solution using roof mounting accessories from Yakima, Thule, etc. On my Frontier I found I could use the universal Mighty Mounts and move one of the factory crossbars back far enough to perfectly fit my code3 mini-bar well behind my sunroof. It had to be far back because my rear crossbar is fixed in place. I still have more options but it depends on what I want to spend and how creative I can be. Good luck and try to add some pics!
  3. #3
    Police/EMS
    Fire Fighter
    joeparv is offline
    Joined June 2012
    US. New Jersey
    Pics
    Quote Originally Posted by DDCtech View Post
    Maybe it's just me, but I like your style Joe. Cheeky and not afraid to stand up for yourself. Right on brotha.
    Hey thanks lol. If you can send me some pics of what your talking about. Joesep06@aol.com and yea I will send pics once I figure it out. Most likely gonna use the gutter straps that would best wrap around my roof rack whichever one that would be I don't know yet now found lol. Thanks
  4. #4
    Junior Member
    SAR
    Hobbyist
    DDCtech is offline
    Renton, WA
    I'll try to take some during National Night Out tomorrow evening. We will be stopping by some block parties in Redmond.
  5. #5
    Guru
    Communications
    Volunteer Fire/EMT
    TritonBoulder47 is offline
    Joined May 2010
    Factoryville, PA, USA
    This is how I mounted my lightbars (my old 9622 Edge, and my current Patriot) to my Avalanche... I had a set of Short Whelen mount straps laying around, so I mounted them to the lightbar and measured what I'd need to cut off... Then chopped them and dripped holes in the strap, then through the "U" Channel of my roof rack rails. Bolted it up and presto... Been holding SOLID...
    (The rust marks ar from the last set of hardware I had the bar mounted with... Package said they were stainless, obviously, the package lied... LoL)
    Squad-6 and SireLite like this.
    - Boulder
    "In the midst of chaos, we find our strength" - Me
    B&B Lighting Solutions B&Bs FaceBook Page Check us out and Like Us!!!
  6. #6
    Quote Originally Posted by joeparv View Post
    Can you get some pics of what you are working with so we can understand the problem better?
  7. #7
    Police/EMS
    Fire Fighter
    joeparv is offline
    Joined June 2012
    US. New Jersey
    Heres the pics of my roof rack
    Quote Originally Posted by JohnMarcson View Post
  8. #8
    Junior Member
    SAR
    Hobbyist
    DDCtech is offline
    Renton, WA
    Can these be adapted?
    Yakima Racks & Carriers
    "Always prepared, so others may live"
  9. #9
    Police/EMS
    Fire Fighter
    joeparv is offline
    Joined June 2012
    US. New Jersey
    they just run from bar to bar and are expensive. fabricated straps would do the same thing as they say by grabbing on its just finding the right one n making it work is the problem
  10. #10
    Guru
    Communications
    Volunteer Fire/EMT
    Joined May 2010
    Maybe mount the straps inverted from their original position... As in, instead of the end of the strap pointing down and getting secured in the top of the door jamb, invert it so the end is pointing upward and have it come under the roof rail...
    - Boulder
  11. #11
    Police/EMS
    Fire Fighter
    joeparv is offline
    Joined June 2012
    US. New Jersey
    nice idea but then the bar would possibly fall easier . i was thinkin of usin the straps n having one that would wrap around it as much as it could n then grab n tighten to get a good hold. trying to find one that would fit n wrap around it basically
  12. #12
    Guru
    Communications
    Volunteer Fire/EMT
    Joined May 2010
    Get some metal stock and make your own...
    - Boulder
  13. #13
    Newbie
    Towing
    First Responder
    Fire Fighter
    speedwaysafety is offline
    Joined June 2011
    United States, Oregon
    that roof rack should be strong enough to be able to use threaded pop in zerts they are sorta like a pop rivets but you drill a specific diameter whole in the rack and then these slide in and are poped in with a tool similar to a pop rivet gun and they are threaded on the inside. fabricate the plate you need with the proper height to clear your sunroof and then you can bolt them directly to your existing rack
  14. #14
    Guru
    Security
    Emergency Management
    Communications
    Jarred J. is offline
    Joined May 2010
    just use ba. . ..
    no wait bad use for it.
    hungry people would eat your bar off.
    Well, what's this year got in store?
    EMA Radio ID #548
    Bedford County Rescue Unit Radio ID Pending
    Callsign KK4BBG
  15. #15
    Police/EMS
    Fire Fighter
    joeparv is offline
    Joined June 2012
    US. New Jersey
    found a mount that attaches to roof rack that is similar to the one i have. its a whelen roof rack mount for a suzuki grand vitara. it wraps around the frame of the rail and then the feet bolt onto that. now to only find one lol
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Back to top
