Results 1 to 5 of 5
  1. #1
    Author of This Thread
    Junior Member
    firemane24 is offline
    Joined September 2010
    Livingston County, MI
    Whelen LED Question...
    So I've always bought clear lenses with solid colors myself but an associate of mine obtained some 700 series leds that are split red/white with matching colored lenses. If he was to get an all red lense will the white side of the light come off as an off red compared to the true red side or will it be unnoticeable?
  2. #2
    Quote Originally Posted by firemane24 View Post
    It will be very very noticable. White LEDs are not the same as white halogen lights. White halogen lights contain a broad spectrum of light. The red lens filters out all light except red. Depending on how the white LEDs are made they may contain almost no red. That means the red lens will filter out all light that is not red, ie most or all of the light. The amount this will occur depends on how broad a specturm is produced by the white LED. Usually it totally kills 75% or more of the output.
  3. #3
    Junior Member
    Thank you sir. That's what I kinda thought bout I haven't had time to mess with them. Maybe we'll be tryin to trade them as I think that would be a lot of white on the front of a Tahoe and I personally think split heads are stupid.
  4. #4
    Junior Member
    And he has one more question...they didn't come with the back flanges. He's puttin them on the grille. Can he do with out the flanges on the grill or does he need them. I told him to get them
  5. #5
    Guru
    Professional Upfitter
    Communications
    Volunteer Fire/EMT
    TritonBoulder47 is offline
    Joined May 2010
    Factoryville, PA, USA
    The flanges for the 700s are needed... It just finished the look better is all... My 700s are mounted behind my grille with some aluminum stock...
    - Boulder
    "In the midst of chaos, we find our strength" - Me
    B&B Lighting Solutions B&Bs FaceBook Page Check us out and Like Us!!!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Back to top
