Results 1 to 14 of 14
  1. #1
    Author of This Thread
    Senior Member
    Fire/EMT
    Law Enforcement
    NFD-102 is offline
    Joined August 2011
    Connecticut
    White Par36 LED WigWags/Foglights for Charger???
    Hey guys, I have a question that I have been wondering about for a while now. Connecticut has some laws that are kind of a pain in the ass but, I do have a red/white/siren permit as an officer. The normal blue light permit as an officer only allows all blue unless you have a special headlight flasher permit which I also have. Since I don't plan on being a Captain forever, when I go back down I'd like to use the wig wag permit. I have a 2009 civilian charger with the headlights that are supposed to be used with wigwags...so at this point, I use HAW's in the fog lights as a headlight flasher. They are white. I also plan on connecting it to two push buttons on my Cencom Gold. Next year I plan on buying the 2012 or newer Charger Blacktop Edition, so they would need to work for that car too.
    I'd like to do the same thing but have foglight LED's and use them as headlight flashers. I like whelen the most but they don't make the new fog/warning par36's in white. Below I listed the lights I like most, can someone explain how I might be able to use them as wigwags/warning lights and foglights. Which works best as a foglight too. I hope this makes sense. Again, they would be for a 2009 Charger SXT and a 2012 Charger Blacktop Edition.
    Whelen 4" Round Flat Lens TIR6 Super-LED Lighthead (White)
    Whelen 4" Round Extended Lens Super-LED Lighthead (White)
    Sirennet PAR-36 LED Spot/Flood Replacement Light - I'm not sure if these would fit in the fog lights location, but I really like them.
  2. #2
    Veteran
    Jared @ 911Lights is online now
    Joined May 2010
    Pittsburgh, PA
    StarSignal (Star/SVP), Nova, and Sound-Off also make them, any of them should work fine. The Whelen are probably going to be the brightest, but also the most expensive.
    -Jared
    Jared Ross FF/EMT
    Owner/President
    911Lights.com
    888-4-LED-LIGHTS
    Like us on Facebook for Special Discounts
    If we sell it, its made in America!
    Holding purchasing contracts for: Pennsylvania, Minnesota, New Jersey and parts of Ohio, Oklahoma, Texas, Louisiana and Michigan
  3. #3
    Senior Member
    Fire/EMT
    Law Enforcement
    NFD-102 is offline
    Joined August 2011
    Connecticut
    I don't mind expensive if they are really good equipment and bright, how would I hook them up so that they can do both steady and wigwag on two seperate switches? I don't want to go through all the flashpatterns every time.
  4. #4
    Senior Member
    Law Enforcement
    Fire Fighter
    Communications
    zacmtz7 is online now
    Joined May 2010
    Atlanta, GA
    use a code 3 700 series flasher with the lights set to steady burn internally.
  5. #5
    Senior Member
    Fire/EMT
    Law Enforcement
    NFD-102 is offline
    Joined August 2011
    Connecticut
    Awesome thanks! That looks pretty easy to install.
  6. #6
    Senior Member
    Fire/EMT
    Law Enforcement
    NFD-102 is offline
    Joined August 2011
    Connecticut
    So what do you think is better as foglights TIR6's or LINZ6's, they are pretty much the same price?
  7. #7
    Quote Originally Posted by NFD-102 View Post
    TIR are spot style. Lin are linear diffuse style... so depending on whether you want a bright concentrated spot or an area glow.... I'd go TIR personally.
  8. #8
    Veteran
    Joined May 2010
    Pittsburgh, PA
    Go for the LINZ6, twice the number of LEDs. If you are sticking with TIR may as well go for Nova, StarSignal, or SoundOff, all brighter and less expensive.
    -Jared
    Jared Ross FF/EMT
    Owner/President
    911Lights.com
    888-4-LED-LIGHTS
  9. #9
    Law Enforcement
    Professional Upfitter
    C2Installs is offline
    Joined May 2010
    Tennessee
    For warning, the Sound Off PAR36 units are incredible. I posted a video last year demonstrating them.
    However, if you want to use them in steady on, then choose another. SOS units will dim noticeably after a second or so in steady on mode. This is a heat-regulation mode, as the lights are designed for flashing. The steady on mode is useful for external flashers, but not constant on.
    Instead, get a set of lights designed as work lights and then use an external flasher.
  10. #10
    got_ygurt is offline
    Joined May 2010
    BC, Canada
    Another option would be the pioneer LED flasher:
    http://whelen.com/install/142/14215.pdf
    Also has synch if you have other whelen products
  11. #11
    Newbie
    Asp158 is offline
    Joined July 2012
    Arkansas
    The 2012 fog lights are 3.5" while the 2009 has 4" holes... So the 4" led fog lights above wont work without modifications.
  12. #12
    Joined May 2010
    BC, Canada
    Quote Originally Posted by Asp158 View Post
    I think whelen makes a 3.5" now with the dual LINZ-6's specifically for the 2012 charger.
  13. #13
    Senior Member
    Fire/EMT
    Law Enforcement
    NFD-102 is offline
    Joined August 2011
    Connecticut
    I thought they were the same size LED heads just a different attachment thats added onto the back side of them. The newer ones look like there are four mini L-brackets with screws that go in. The old have a bracket that connects to the back of the lighthead thats about 2-3 inches long. Its not the same light head with two different brackets?
  14. #14
    Senior Member
    Fire/EMT
    Law Enforcement
    NFD-102 is offline
    Joined August 2011
    Connecticut
    Also, can I just use my vehicle foglights switch to the Code 3 700 flasher? Or does it have to be wired differently?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Back to top
