Results 1 to 20 of 20
Like Tree4Likes
  • 4 Post By MEVS06
Thread: Wiring up LEDS, need some help....
  1. #1
    Author of This Thread
    Newbie
    3alarmRed is offline
    Joined July 2012
    Midwest
    I am a newer volunteer on a local Fire/EMS department. I picked up a dash light (8 LEDs, 4 per side) and a pair of grill lights (4 per side). The dash light came with a cig. lighter adapter with on/off switch and a momentary light to change flash pattern. The grill lights need to be wired in as well. I would like to hardwire the complete setup without the cig. adapter. What do I need to complete the install? Can I use 1 on/off switch and the momentary switch to control everything?
    * I understand low voltage wiring as far as battery power, ground, running wires and such.
    Thanks a bunch.
  2. #2
    Veteran
    Law Enforcement
    Professional Upfitter
    Dealer
    MEVS06 is online now
    Joined May 2010
    San Antonio, TX
    Yes
  3. #3
    Newbie
    Joined July 2012
    Midwest
    Well my original thought didn't work. I dismantled the the switch box that came with the dash unit, that was attached to the cig adapter. Wired all four lights to the on/off and momentary and there doesn't appear to be enough current. The dash unit lights up but only flashes 3 or times then stays lit and the grill lights won't light at all. I'm guessing the mini rocker on/off can't handle the load, any thoughts?
  4. #4
    fier23 is offline
    Joined February 2012
    Kansas City MO
    Quote Originally Posted by 3alarmRed View Post
    Galls.com sells a switch panel with 2 rockers and a neg push for flash pattern change. Simple and perfect for you.
  5. #5
    Newbie
    Joined July 2012
    Midwest
    Quote Originally Posted by fier23 View Post
    Thanks fier23 for the suggestion, but I would prefer to utilize switch locations that I already have in a overhead console.
    It looks like the mini rocker is only rated for 8 amps, and I believe I need around 15 amps to properly energize all four lights. Any thoughts on using a relay with the mini rocker? Might be long shot but in my mind the relay acts as a heavy duty switch supplying the current and the mini rocker actuates the relay??? Any and all suggestions are welcome.
  6. #6
    runesson is offline
    Joined August 2011
    Northern Europe
    15amps for a LED dashlight and two grill-lights? I would rather guess on 3-6 amps. If you give us the brand and model for the LEDs, we can probably give you better advice.
  7. #7
    Newbie
    Joined July 2012
    Midwest
    Quote Originally Posted by runesson View Post
    Extreme Tactical Dynamics
    Undercover 8 - Extreme Tactical Dynamics - Grill Lights
    The Fox Trot LED Dash Light - Dash light
  8. #8
    Veteran
    Law Enforcement
    Dealer
    Joined May 2010
    San Antonio, TX
    That right there is your problem...
  9. #9
    runesson is offline
    Joined August 2011
    Northern Europe
    Well, I have no experience with ETDs stuff and they are not stating any current draw one their web-site, but I still haven´t seen a TIR4-module (of which you have 4) that draws more than about 1 amp continious.
    Just to clarify:
    ....Can I use 1 on/off switch and the momentary switch to control everything?
    Do you mean "1" as in "a" rocker-switch you have installed or do you mean "the" rockerswitch that was attached to the dashlight wire?
    Most rockerswitches will handle 10 or more amps, but I don´t know what is used in the ETD unit.
    Anyways, by your description, it sounds like you have the wires mixed up. If the switch couldn´t handle the current, the dashlight shouldn´t have lit up.
    Hopefully, someone with experience on ETD can chime in on this.
  10. #10
    runesson is offline
    Joined August 2011
    Northern Europe
    Quote Originally Posted by MEVS06 View Post
    To clarify on behalf of MEVS06, for those who don´t have a lot of experience with warninglights: ETD isn´t known for quality.....
  11. #11
    runesson is offline
    Joined August 2011
    Northern Europe
    Also: what wires are you running to tha grill-lights? If they are too thin, the voltage at the lights may be too low.
  12. #12
    Newbie
    Joined July 2012
    Midwest
    Wish I had known that before I bought.... Oh well, stuck with it now.
  13. #13
    Newbie
    Joined July 2012
    Midwest
    Just to clarify:
    I guess I wasn't clear enough.....
    The rocker is mounted with the dash kit, it works just fine with the dash only. When I added the grill lights with the dash lights on the same switch is when I have problems.
  14. #14
    Veteran
    Collector
    Communications
    SireLite is offline
    Joined May 2010
    Conwy, Wales, GB
    Post some pictures.
    Jim - SireLite Thinking outside the box.
  15. #15
    Newbie
    Joined July 2012
    Midwest
    Just to clarify:
    The rocker that came with the kit works fine when its just powering the dash kit, the issue seems to be when the grill lights are hooked up. I wired up the grill lights in parallel with the dash kit. (Black - Black, Red - Red, and the white wires are tied in with the red for the selected pattern)
    I am surely open to suggestions> I thought the way I wired it should work; but I guess not.
  16. #16
    ERM
    ERM is online now
    Joined May 2010
    Omaha, NE
    Just connect the red and black wires to your dash light switch. Sounds like you are connecting ALL the sync wires and when one of the lightheads triggers the sync command, it's messing with the dash light. Try disconnecting the white wires from the dash light. That SHOULD solve your problem. The white wires should only be connected to your grille lights.
    All of your lightheads should not be pulling enough to cause any power issues from your switch. The only time you're drawing maximum power is when ALL the lightheads come on at once. Sounds like you're alternating your lights, so you're pulling half the amps. Hope that helps. Let us know what happens when you disconnect the wire from the dash light.
    Tony
    Creators of the first series of programmable flashers.
    http://www.fisos.net/
    http://www.ledguy.net
    The REAL Ledguy!
    Check out our clearance section of new and used lights and sirens. Click here.
  17. #17
    Newbie
    Joined July 2012
    Midwest
    Quote Originally Posted by ERM View Post
    Tony
    Thanks for help, I will try that.
  18. #18
    Newbie
    Joined July 2012
    Midwest
    Problem solved. Not exactly sure what went wrong, but with a new rocker switch all lights worked as advertised. Thanks for all the suggestions.
  19. #19
    If you crash you will be in a world of trouble with lights that don't meet SAE standards.... add something that does like a halogen throw light to CYA... good LEDs aren't cheap and cheap LEDs aren't good. I hate seeing people throw their money away on dangerous lights.
  20. #20
    Veteran
    Law Enforcement
    Dealer
    Joined May 2010
    San Antonio, TX
    Quote Originally Posted by JohnMarcson View Post
    This is why we frown on cheap non SAE lights such as ETD, STL, CPS. Those manufactures only care about taking your money. If they cared about the end users they would get the certifications, bit they obliviously don't give a crap.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Back to top
