Results 1 to 22 of 22
Like Tree1Likes
  • 1 Post By b8man
Thread: CanTrol
  1. #1
    Author of This Thread
    Junior Member
    b8man is offline
    Joined April 2011
    Washington State
    CanTrol
    I spent the last couple of days at Cantrol programming school. All I can say is WOW!
  2. #2
    ryanm is online now
    Joined May 2010
    Arkansas
    Is that fully available now?
    Is there any pricing available on it?
  3. #3
    Junior Member
    b8man is offline
    Joined April 2011
    Washington State
    It is available now, and there is pricing. You can only buy it from a whelen dealer who has gone through the training, and whelen is not including the software with the unit. The average end user will not be able to do their own programming, you have to take it to your dealer for programming.
  4. #4
    ryanm is online now
    Joined May 2010
    Arkansas
    Quote Originally Posted by b8man View Post
    Ah, ok. That throws it right out for me. We don't have one worth considering.
  5. #5
    Paramedic
    Hobbyist
    Medicman695 is offline
    Joined May 2011
    USA, MN
    So my understanding from the description on Whelens website is that the new CanTrol system is designed to be like an ambulance or fire trucks control system with the master sequencing and independent light control plus the added bonus of flash pattern programming and a siren. Is that an accurate assesment?
    Stay Safe!
  6. #6
    Junior Member
    Law Enforcement
    dpm9917 is offline
    Joined May 2011
    Englewood, CO
    CANTROL
    iT IS WHELENS NEXT GENERATION OF SERIAL CONTROL AND IS VERY EXPENSIVE MOST LIKELY OUT OF REACH FOR MOST DEPARTMENTS. IT WILL FORCE YOU TO USE ALL WHELEN EQUIPMENT AND WILL OFFER YOU COMPLETE CONTROL AND PROGRAMMING OPTIONS. WE ARE STILL 6 MONTHS OR SO FROM FULL RELEASE IF ALL GOES WELL WE TRAINED ON IT 3 MONTHS AGO AND ARE RUNNING A BETA SYSTEM NOW.
  7. #7
    Solvarex is offline
    Joined June 2010
    Canada
    TURN IT OFF.
  8. #8
    Law Enforcement
    John Hearne is offline
    Joined May 2010
    Pontotoc County, MS
    Quote Originally Posted by dpm9917 View Post
    Can you explain this some more? Are you talking about LED heads or other options? I'd think that if the Cantrol outputed the required voltage to a correctly attached wire, it would have to work.
  9. #9
    Newbie
    IslandFleet is offline
    Joined June 2010
    Honolulu, HI
    You are in no way "forced" to run all Whelen components...
    The use of certain Whelen products will allow you to take full advantage of what this system has to offer.
    Will the system work with other brand lightheads/speakers? Yes.
  10. #10
    Junior Member
    citypolice is offline
    Joined August 2011
    City
    How does it differ from CenCom Gold ???
  11. #11
    Junior Member
    b8man is offline
    Joined April 2011
    Washington State
    Quote Originally Posted by citypolice View Post
    The CenCom Gold has 12 output wires, the CanTrol has 19 output wires with a Can3 , and 43 output wires in the Can1. WeCan lightbars plug right into the box, and don't use any of the outputs. You should never again worry about running out of outputs. You can take all of the LED's on a vehicle, set them on steady burn and sync the entire car's flash patterns through the CanTrol. You also have a bunch of inputs, including analog inputs for things like temp sensors and photo cells. A bunch of the things that you used to have to do externally with diodes and relays, you can now do internally through the CanTrol programming. The Programming is intense, it is not just the simple user interface that the Cencom has, it is much more like writing code, which is why Whelen is requiring people to be trained on it before they will give you the software. Only dealers and municipalities who want to send a tech to training are going to be able to program the units. Even with the training, you can expect to spend many hours setting up any given program. The final result on a well equiped car is amazing. You can make any car look like a show car.
  12. #12
    Paramedic
    Hobbyist
    Joined May 2011
    USA, MN
    The CenCom Gold has 12 output wires, the CanTrol has 19 output wires with a Can3 , and 43 output wires in the Can1. WeCan lightbars plug right into the box, and don't use any of the outputs. You should never again worry about running out of outputs. You can take all of the LED's on a vehicle, set them on stady burn and sync the entire car's flash patterns through the CanTrol....
    I love it and want it!! So how much is the new system?
    Stay Safe!
  13. #13
    Senior Member
    Doug is online now
    Joined May 2010
    Maryland
    Any videos of past installs, by chance?
  14. #14
    Junior Member
    b8man is offline
    Joined April 2011
    Washington State
    Quote Originally Posted by Doug View Post
    I haven't installed one yet. I need one of the cities that I do installs for to step up and order the system first. List price for it is around $1700 for the Can1, so it is a big investment. I've seen a WSP car with it, and my Whelen Rep. has it on his demo car. Very cool.
  15. #15
    Dr. Dennis Stouffer is offline
    Joined May 2010
    Los Angeles, CA
    Sounds like another way to waste tax payer funds on unnecessary, over priced toys when current equipment works well. But then again, it keeps money flowing even if wasted.
  16. #16
    Law Enforcement
    Communications
    Professional Upfitter
    fleetcomm is offline
    Joined September 2011
    Tennessee
    I also spent the last two days in CanTrol training and I now know why they require the training because it is unlike any light controler you have used before. I ordered a blue/white wecan light bar and a CanTrol CAN1 two weeks ago and the car this week. I will post as soon as the car comes in and can get everything installed. I don't look for the car to be here before Feb. or march.
  17. #17
    Junior Member
    b8man is offline
    Joined April 2011
    Washington State
    Quote Originally Posted by Dr. Dennis Stouffer View Post
    I agree that for most people it would be a waste of money, but for those that will actually use the CanTrol to it's full potential, it is well worth the money. It is interesting when you look at it from the point of view of the evolution of emergency lighting. It used to be that the user would flick a switch, turn on his lights and siren, and that was it, he didn't have any other options. However, as lighting and siren systems got more complex, so did the user's involvement. The user had to decide what lighting he wanted under which conditions, and he had to make that decision in what could be a very stressful situation. The CanTrol is geared toward giving you the best of both worlds by limiting the decisions that the user has to make while maintaining the versatility of modern lighting systems. You can take the slide switch away, and make all of those changes without the user having to do anything. From a police standpoint, it could make a big difference to officer safety.
    Storm4200 likes this.
  18. #18
    Law Enforcement
    Communications
    Tennessee
    Well said.
  19. #19
    Senior Member
    Volunteer Fire Fighter
    Mrlunchbox is online now
    Joined June 2010
    Whitinsville, MA
    Quote Originally Posted by fleetcomm View Post
    Well said.
    Agreed!
  20. #20
    Senior Member
    Joined June 2010
    Whitinsville, MA
    Any pics of this system yet?
  21. #21
    Law Enforcement
    Communications
    Tennessee
    Here is the training box with the Cantrol in it. I will have the car in about 4 months and the equipment has already started coming in for it.DSC00410.JPG
  22. #22
    Fire/EMT
    Storm4200 is offline
    Joined November 2011
    NJ
    anyone besides AndyL got the canTrol system videos yet?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
