On a cencom it says fuse the 2 8ga wires at 50 amps each,how are ya'll doing this? Do you use a block like this Stinger SPD5625 Four Position Fused Distribution Block Car Audio - SPD5625.
A fuse block will be on another fuse also.
I bought a cencom red without any wires. I think I found the anderson connectors I need. Tell me if I'm wrong.
10 ft. 8 gauge Power Supply Cable with 75 amp Powerpoles [PSC-08] - $18.99 This would be for the power comming in and but another one for the 40 amp outlet.
Powerpole to Bare End Adapter [PP-2-Bare] - $6.99 I would get 2 of these for the 2 20amp outlets and system power
If anyone has the pieces to add the TA function or other wires let me know.
Thanks
Andrew
LinkBack URL
About LinkBacks
2004 TAHOE
2011 Hyundai Sonata Turbo (traded for tahoe)
