Results 1 to 14 of 14
August 9th, 2012, 08:20 PM #1Author of This ThreadNewbie
- Joined April 2012
USA Minnesota8 PostsMotorola XTL2500 and Siren/PA kit
We have a Spectra VHF mobile radio (A5 head) with siren/PA in an older squad. We are migrating to the MN ARMER (7/800mhz) System and will be installing a new Motorola XTL2500 remote mount.
Can the old spectra siren/pa be interfaced with the XTL2500?
August 9th, 2012, 11:51 PM #2Suspended
- Joined May 2012
Charlotte NC21 Posts
August 10th, 2012, 11:14 AM #3
I've tested older amps on newer radios. They appeared to work fine.
Ryan
"Blessed are the peacemakers, for they will be called sons of God." Matthew 5:9
"Greater love has no one than this, that someone lay down his life for his friends." John 15:13
Any comments I make represent only my personal opinion and do not necessarily reflect the opinion of my department, employer, and/or any other third party.
TSFIYF
August 12th, 2012, 09:35 PM #4VeteranDealerProfessional Upfitter
- Joined May 2010
PG County, MD1,444 PostsStandard 9000 siren amps will work fine with the XTL line.
August 13th, 2012, 01:02 AM #5MemberVolunteer Fire FighterProfessional UpfitterVintage Collector
- Joined May 2010
Chattanooga,TN, Bryant,308 PostsYou will then need a special cable that goes from the XTL head to the DEK siren box. You should already have the DEK box, so just need the cable and you should be able to combine the 2 without much modification.
My best friend had an XTL-5000 with a VRS-750 and a siren setup, that he swapped from a Astro Spectra. He had to order the special cable for the DEK box and add a DEK box in his case.
Jordan,TCFD
August 14th, 2012, 10:35 PM #6VeteranDealerProfessional Upfitter
- Joined May 2010
PG County, MD1,444 PostsOr, you could just program the siren buttons to the head for the XTL and forget the DEK.
Less cables, less hassle.
August 14th, 2012, 10:42 PM #7MemberVolunteer Fire FighterProfessional UpfitterVintage Collector
- Joined May 2010
August 16th, 2012, 05:59 PM #8VeteranDealerProfessional Upfitter
- Joined May 2010
PG County, MD1,444 PostsYou can still program the buttons on the head for siren, you just need to have the enhanced mic to control the other functions.
Or you could leave the head alone and program the siren functions to the buttons on the enhanced mic.
May 7th, 2013, 08:12 PM #9Member
- Joined September 2010
New Jersey66 PostsI'm thinking about doing this with my XTL2500. I was looking at some of the old Astro Spectra boxes on ebay. What sort of cable would I need to go from the XTL to the siren box? And do I specifically need a motorola speaker or would any siren speaker work?
May 8th, 2013, 10:53 AM #10VeteranDealerProfessional Upfitter
- Joined May 2010
May 8th, 2013, 11:29 AM #11
So why is this worth the money instead of just adding a seperate siren? I had some FedGov vehicles come in that had the Motorola radio/siren systems and were abandoning them because they were too much of a PITA to use.
John D. Cummings
Safety Lighting and Equipment
38D Winthrop St
Rehoboth MA 02769
Phone/Fax 508-252-6900
JCummings@SafetyLightingandEquipment.com
www.safetylightingandequipment.com
May 10th, 2013, 09:31 PM #12VeteranDealerProfessional Upfitter
- Joined May 2010
PG County, MD1,444 PostsMost of the ones I have dealt with have never been programmed correctly by the radio guys. Depending on the set-up, some have a 2nd wildcard box for the lights and pressing buttons for lights and sirens is not easy for some folks without taking their eyes off of the road.
May 12th, 2013, 09:02 PM #13Member
New Jersey66 PostsAnd what cable do I need? Do the astro cables also work for an xtl?
May 12th, 2013, 09:46 PM #14Newbie
- Joined May 2010
Fl19 PostsIf you have a spectra (non-astro) you will need a new siren (model HLN1439 I believe is for the astro/xtl line) you will also need a new cable to go from the 2500 remote head to the dek, as the connectors are different. The part is odyssey control head to DEK (I forget the part number).
1Likes
LinkBack URL
About LinkBacks
Tons for sale
Today, 03:06 AM in For Sale or Trade: Warning Equipment
