what are some good grounding points inside of a truck cab for a siren?
2001 ford ranger edge single cab
under the steering wheel and around the kick pannels (behind) there should be ground studs already there
thank you!
Basically anywhere that the vehicle has factory ground points. I am not trying to insult anyones intelligence but if you are not familiar with vehicle wiring be very careful. Just because a vehicle has a wire that is black in color does not necessarily mean it is a ground. When in doubt go straight to the battery.
-Adam
