Results 1 to 7 of 7
  1. #1
    Author of This Thread
    Volunteer Fire Fighter
    Communications
    First Responder
    bwoodruff is offline
    Joined August 2011
    Upstate NY
    Radio repeat (SVP LCS600)
    Heya folks,
    I'm looking at an SVP LCS600 from 911lights.com. Love SVP visual warning products, never used any audible warning (don't have the ability to run a siren).
    Has anyone wired one of these up? I'm particularly interested in the radio repeat feature. I have both a Uniden BCT15x and a Yaesu FTM-350AR that I'd like to be able to hook up so they can be made audible outside the truck. Did some searching but didn't find much.
    Also: any recommendations on speaker location? As I mentioned the important feature to me is the radio repeat. Here is what I'm working with:
    2012 Chevy Silverado POV (fire/EMS)
    Is there a less expensive solution for radio repeat (less expensive speaker maybe)? I'm not sure I particularly care about the PA/air horn.
    Thanks.
    Ben
    My posts and opinions are mine and mine alone and do not reflect/represent any organization I am affiliated with
  2. #2
    Veteran
    Professional Upfitter
    Dealer
    Vintage Collector
    PC Comms is offline
    Joined May 2010
    Living in the Poconos!
    OK, a couple of issues here. You would need at least a 100 watt speaker if you are going to do radio rebroadcast using the siren amp. As for hooking both a scanner AND a radio to the SVP unit, DON'T DO IT! You will blow out either one of, or both, of your radios. The way to hook one of them up is to use the external speaker leads from either radio and connect them to the input leads utilized for the radio rebroadcast. As for using a "cheaper speaker", you can simply buy a cheap PA speaker from Radio Shack and wire it to either radio with a switch to turn it on and off, but I can guarantee that it won't be anywhere near as loud as it would be with the SVP amp.
    All tyranny needs to gain a foothold is for people of good conscience to remain silent. - Thomas Jefferson
    Those that fail to learn from history, are doomed to repeat it. - Winston Churchill
    It's more difficult to LOOK busy than it is to BE busy. - My Father
    Don't take shit from ANYBODY!! - Again, My Father
  3. #3
    Communications
    First Responder
    Joined August 2011
    Upstate NY
    Quote Originally Posted by PC Comms View Post
    Okay, cool, thanks for the info.
  4. #4
    Veteran
    Jared @ 911Lights is offline
    Joined May 2010
    Pittsburgh, PA
    We did a similar setup for a customer with 2 radios and a scanner. We used a three position switch on the dash to select between the audio sources. I think we figured out a way to feed all the audio in at once, but the customer preferred having the switch.
    -Jared
    Jared Ross
    911Lights.com
    888-4-LED-LIGHTS
    Like us on Facebook for Special Discounts
    If we sell it, its made in America!
    Holding purchasing contracts for: Pennsylvania, Minnesota, New Jersey and parts of OH, TX, LA & MI.
  5. #5
    Communications
    First Responder
    Joined August 2011
    Upstate NY
    Quote Originally Posted by Jared @ 911Lights View Post
    -Jared
    Yes, a switch would be perfectly acceptable. Considering one source is fire/EMS and the other is amateur radio, it is unlikely that I would want/need both simultaneously (at least, outside the truck).
  6. #6
    Veteran
    Dealer
    Vintage Collector
    PC Comms is offline
    Joined May 2010
    There is a way to do it using polarized resistors, but I figured that if I went down that road it might be a whole different conversation.
  7. #7
    Veteran
    Joined May 2010
    Pittsburgh, PA
    Where is Sean when you need him?
    Jared Ross
    911Lights.com
    888-4-LED-LIGHTS
Posting Permissions
  • You may not post replies
  • You may not edit your posts
