Results 1 to 9 of 9
Thread: Whelen CenCom
  1. #1
    Author of This Thread
    Junior Member
    jasonhill is offline
    Joined January 2011
    USA Texas
    Whelen CenCom
    I just got a whelen cencom from our local pd, all i have been able to find online is for the new ones. Does anyone have or know where to find info in it?
    Model # 01-0285910-00B
    Thank you
  2. #2
    Support Staff
    EMT
    EMT-BLS is online now
    Joined October 2011
    NY, USA
    What kind of info are you looking for? Install instructions, configuration, use...?
    A lie is just a great story that someone ruined with the truth.
  3. #3
    Junior Member
    Joined January 2011
    USA Texas
    Yep install and config. I dont know much about them.
  4. #4
    Volunteer Fire Fighter
    nluszcz is offline
    Joined December 2011
    Kentucky
    The Gold directions are the same as the Red, only difference is the plug for power, and its still quite easy to figure out. Just a different type connector. EVERYTHING else is the same, up to programming, and then its only minor differences.
  5. #5
    Support Staff
    EMT
    Joined October 2011
    NY, USA
    Here are the necessary manuals:
    Installation-Click here
    Configuration-Click here
    You will need the program from Whelen...A simple over-the-phone request should do it.
  6. #6
    Veteran
    Dealer
    Professional Upfitter
    SlickTop Solutions is offline
    Joined May 2010
    PG County, MD
    Since the Cencom Red is several years old, Whelen may or may not still have the programming software for it.
    Worst that can happen is you call them and they say sorry, no got.
    Dan
    Owner
    Slick Top Solutions
    www.slicktopsolutions.com
  7. #7
    Junior Member
    Joined January 2011
    USA Texas
    Thank you for all the help guys!!
    this unit is not able to run dual tone , right? I didnt see anything about it but figured I would ask.
  8. #8
    Senior Member
    bigcat is offline
    Joined May 2010
    Hartford County, CT
    I called whelen for the gold software and they said I had to call the rep for the region to get it.
    Found this on Elb though. The last post has links to the software. Not sure if they are the current version for each model but I downloaded the gold software and it works.
    Whelen Cen Com Gold Software
  9. #9
    nluszcz is offline
    Kentucky
    Yes Whelen has the Red software readily available. Send me a PM if you want me to email it to you.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Back to top
