Results 1 to 7 of 7
Thread: 02 silverado fire wall question
October 5th, 2011, 09:56 PM #1Author of This ThreadSenior MemberVolunteer Fire Fighter
- Joined November 2010
South Georgia687 Posts02 silverado fire wall question
Where would be the best place to drill a 1" hole into the fire wall to run wires? Thanks
Garrett Wooten
gdwooten@gmail.com
October 5th, 2011, 10:03 PM #2Author of This ThreadSenior MemberVolunteer Fire Fighter
South Georgia687 PostsForgot to include it's a silverado 1500
Garrett Wooten
gdwooten@gmail.com
October 5th, 2011, 11:23 PM #3VeteranVolunteer Fire/EMTLaw EnforcementProfessional Upfitter
- Joined May 2010
New Jersey1,207 PostsIn a spot that is clear on both sides. Usually next to a wire harness. There may probably be an unused plug in the firewall that you can use. Have you looked in the drivers compartment under the carpet?
October 5th, 2011, 11:38 PM #4
I went through the factory harness on the driver's side. It was a long time ago but I know I cut a slit in the top of the rubber grommet on the engine compartment side. Then I think I used a sharp pointed object to pierce through the other side of the grommet and feed the wire through. Just be careful not to hit any factory wiring.
October 6th, 2011, 04:45 AM #5
October 7th, 2011, 10:12 PM #6MemberFire FighterEMT
- Joined May 2010
MA190 Posts
October 7th, 2011, 10:14 PM #7Author of This ThreadSenior MemberVolunteer Fire Fighter
South Georgia687 PostsGarrett Wooten
gdwooten@gmail.com
LinkBack URL
About LinkBacks
My 2004 Chevrolet Z71 Suburban
Federal Signal Valor Lightbars 48"...
June 17th, 2013, 05:47 PM in For Sale or Trade: Premium Listings
